Results 1 to 6 of 6
    Standard or compact drive
    Is there any reason why you should chose either for a singlespeed?
    I plan on running 34 or 36t ring.
    Reputation: >>ECB<<'s Avatar
    Compact vs. Standard
    Quote Originally Posted by nubber
    Compact BCDs are generally preferred for singlespeeding, because they can take smaller rings than standard BCDs (i.e. 29T vs 33T). Besides, lower gears are easier to get by changing to smaller chainrings than by installing larger freewheels; the former take less work to swap, and are more available.
    If you're set on a 34T minimum up front, you can run standard. However, this will limit your ability to gear down if the need arises.
    ECB
    Reputation: Brandon's Avatar
    I'd say go compact, you can get basically any size ring you need that will bolt up to compact but like already mentioned your smallest ring for standard is 33t.
    Reputation: shiggy's Avatar
    Dec 1998
    Or go with a Profile Racing crank. You can swap between 110 or 94 spiders or use BMX chainwheels. Profile offers chainwheels from 24t to 46t in one tooth increments.
    mtbtires.com
    Reputation: Cygnus's Avatar
    Go big...
    standard, that is, if you expect to ride on the road or fast trails and want to go with a steep (high ratio) gear set up. just for fun, i'm going big and fast on one of my bikes at 42x18. can't climb, but i'm fast on some flatish, non-technical trails. elsewhere, i've found standard 34 or 36 chainrings to be really versatile.
    Retro Grouch
    Reputation: aka brad's Avatar
    It's a coin toss..
    Sure you can go with a smaller CR with compact but it's not that big a deal. For every tooth on a cog or freewheel, your looking at two on the CR. I also worried about the smaller CR when I bought my standard crank, but the price was right and I've never looked back (or needed a 32:22).
    1G1G, Brad
  1. New forum lacks standard Horst discussion
    By Soupboy in forum Bike and Frame discussion
    Last Post: 01-19-2004, 12:31 PM
  2. Spline Drive Nipples: Weight
    By GrosGarage in forum Wheels and Tires
    Last Post: 01-15-2004, 07:00 PM
  3. retro bike 2 wheel drive
    By firebikez in forum Vintage, Retro, Classic
    Last Post: 01-15-2004, 08:46 AM
  4. Some pictures from this morning's drive....
    By screampint in forum Passion
    Last Post: 01-14-2004, 10:18 AM
