Results 1 to 17 of 17
Thread: SS Stem Length
    Ahhh the pain....
    Reputation: Raybum's Avatar
    SS Stem Length
    I'm in the process of building up a Lynskey Ridgeline 29r SS and trying to dial in the cockpit. My FS26r is setup more XC with a 120mm stem where the grips are slightly below the seat height. I'm tempted to setup up the SS the same way which would require a 110mm stem since the top tube is a bit longer. Should I be thinking shorter, more upright riding position for a SS ?
    Out spokin'
    Dec 1999
    Personal choice but I like my bars where they're comfortable for multi-mile standing. For me that's right about saddle height. YMMV.
    --Sparty
    disciplesofdirt.org
    Teen Wolf
    Reputation: cr45h's Avatar
    whatever is most comfortable, make sure you get a ss stem
    Low Rep Count
    Reputation: 1SPD's Avatar
    What ever works for you man. I simply set mine up the same as my xc. Running a 110mm stem simply because my tt is a tad longer as well. I have a 5 degree stem flipped upside down so the stem is almost parallel to the ground and I still ride a straight bar.
    Over the bars...
    Reputation: egggman's Avatar
    I set mine up based on bike fit at a shop. I was able to use a 35 degree inverted stem to drop my bars slightly below the saddle. I have no legs and all upper body, when switching to 29 it was an interesting trick to fit a bike comfortably.
    Ahhh the pain....
    what is a ss stem ? Never seen SS specific stems....
    Out spokin'
    Dec 1999
    Quote Originally Posted by Raybum
    He was giving the OP friendly flack for asking about a non-SS-specific item on the SS board. Happens all the time, usually accompanied by a wink and a giggle, and most frequently over on the 29er board.
    --Sparty
    disciplesofdirt.org
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    personal preference....low is good for me now though i guess at about saddle height
    i currently only have 1 SS and i run a 70mm stem...whatever
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Personal preference:
    When I converted my bike to SS, I noticed that I wanted a shorter stem: I felt my weight was too far forward when climbing out of the saddle.
    Others may have different experiences.
    Reputation: mitzikatzi's Avatar
    More importantly make sure it is a 29er compatible stem. 26er stems work but often fail due to not being designed to cope with the higher torque required on a 29er.
    local trails rider
    Aug 2005
    --Sparty
    Dunno about that in this case... the question is really about stem length, and some find they want a different cockpit/riding position for SS.
    Teen Wolf
    wink wink giggle giggle.
    Did I catch a niner+?
    I run a 100mm zero rise now but am going to a 120mm six degree rise on my Inbred (has shorter TT). I find I like to be more stretched out over a bike and get a drop bar feel is much more comfortable for me plus I get some serious speed on the DH.
    smell the saddle...
    Reputation: stumonky's Avatar
    Quote Originally Posted by Mr Pink57
    This is a good point.
    Zinn’s book has good reference on TT length and dialing in the saddle position to stem length. I even emailed Zinn to further define the math. It’s certainly a ‘feel out science’ in my experience. I am more inclined to dial in my TT length more precisely than stand-over height of a frame. I’ve ridden 16”, 17", 17.5”, 18”, and 19”. On the 16” I have to slide the saddle position all the way to back and purchased a longer stem. Similarly, on the 19” I had to use a shorter stem length. It’s all about finding that sweet spot IMO.
    Shinobi-Wan Kenobi Moderator
    Reputation: kristian's Avatar
    My Unit came with a 105mm and I hated it. I replaced it with a 60mm and everything felt WAY better. I can't belive that so many SS folks still use 100mm+ stems! Whatever works for you I guess...
    Reputation: arphaxhad's Avatar
    --Sparty
    +1 for me. A little shorter and a little more rise than my other bikes to keep me from "hunching" too much on long climbs.
    Let's ride
    Reputation: rensho's Avatar
    --Sparty
    +1 on this. High or low, my bars need to be where I can stand and pedal straight legged, without bending bending my torso. There are 4mi 2000ft climbs where I am, and you'll need to stand about 90% of the climb. Being hunched over for that time would kill me, and then I'd be walking.
    Additionally, I vote for short stems on 29ers. The steering is already slow. You stick a 100-110 stem on there, and it is glacial.
    I run a 90 now, and will go down to an 80.
