Results 1 to 7 of 7
    viva la v-brakes!
    Reputation: FishMan473's Avatar
    Jan 2003
    New question here. SS specific chain rings?
    I have a converted vertical drop-out set up on my SS which ALMOST works perfectly with a 34x19 set up (no tensioner). Trouble is there's a little slack in the chain and it falls off a couple times each ride.
    I thought I heard something about someone making SS specific chainrings with longer teeth. Do they really exist? Might this help my problem? Right now I'm using a pretty beat up old Vuelta chain ring. It was bent pretty bad at one point (I think I straightenedit out all the way) and some of the teeth are growned down or bent, which is obviously part of my problem.
    FYI I had a Singleator on this bike once and it was a lot more of a pain in the ass then the set up as it is now, so I have no intention of going that route again.
    Thanks,
    I have a car. I made a choice. I ride my bike.
    Bikes not Bombs.....
    Reputation: SS Jerry's Avatar
    Onza Buzz Saw in Stainless steel
    I like the Onza Buzz Saw in stainless, no ramps, and pretty beefy. A bit hard to find.
    JS
    Thanks to all of you for your friendships on this board..... -
    The name's Norm...
    Reputation: maSSpayne's Avatar
    Salsa rings
    Salsa Chainrings work great. A lot of us use these. No ramps or pins on the standard. Go to AEBikes.com. Good prices too!!
    http://aebike.com/site/page.cfm?PageID=30&Category=98
    cause it's fun
    Quote Originally Posted by FishMan473
    Thanks,
    a BMX style chain ring might work. Go to your LBS and see. As for the dropping the chain - Get ENO!
    bus driver wanna be
    my salsa 34 tooth works fine but thats on a surly 1x1 with a converted xt casset rear hub.
    surly has some coming out in june(steel) i dont know if teeth are longer though
    viva la v-brakes!
    Jan 2003
    Spot?
    The rings I was thinking about was Spot brand SS rings. Anyone know if these are any different from the Salsa offering, or anything else for that matter?
    Thanks,
    FishMan
    Reputation: SSSasky's Avatar
    Good job! Envy
    I'll once again harp on Envy rings from vancouver. Very well made, very beefy, and quite affordable. Highly recommended. I run a 38 tooth on my Monocog. The machining is impeccable, and they're indestructibly beefy, yet light.
  1. Calculating chain length for a SS conversion
    By od_the_roadie in forum Singlespeed
    Last Post: 04-02-2004, 03:58 PM
  2. chain rings that work with tuvativ stylo?
    By strongislandsser in forum Singlespeed
    Last Post: 03-24-2004, 05:29 AM
  3. > 1/8" chain stretch - time to replace the chain rings?
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2004, 05:05 PM
  4. SS specific rear wheel or no?
    By namaSSte in forum Singlespeed
    Last Post: 03-08-2004, 02:05 PM
  5. Should I get SS specific rings...
    By Casual Observer in forum Singlespeed
    Last Post: 02-25-2004, 03:44 PM
