Results 1 to 18 of 18
    Feb 2006
    SS one or two brakes
    I was thinking to just leave the rear brake on my ss to save even more weight. What do you think? Thanks.
    organically fed
    Reputation: w00t!'s Avatar
    Totally. Worst case scenario, just jam your Vans in between the tire and seatstays.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I wouldn't.
    On trails, two brakes gives me much better control of my speed... in the few spots where I get up to any speed If I only had one brake I would never dare let my bike go fast
    In traffic, two brakes just gives me way shorter stopping distance, to avoid hitting careless drivers and pedestrians.
    SSolo, on your left!
    Quote Originally Posted by w00t!
    LOL
    Quote Originally Posted by perttime
    I wouldn't.
    Yes, two brakes!
    Get off the couch and ride!
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Stick with one brake. On the rear. It keeps these threads to a minimum.
    you would be much better off going out without any water at all. Lets face it , a couple of pounds slushing around on your back isn't helping anyone, is it ?
    I'm feeling dirty, you?
    Reputation: jonowee's Avatar
    Unless you a dirt jumper in a familiar jump park, add both brakes please.
    Want some braking, bar-spinable without over-fiddly gyros; you can try one of these... http://www.gussetbikes.com/gusset/pr...hp?id=HSGU*NFS . Obviously you'll need a front disc brake.
    Horrible, useless idea.
    Front brake for stopping, rear brake for control.
    V-Shaped Rut
    Reputation: big_slacker's Avatar
    Remember that on a bike its rotating mass that has the most effect on how you ride. Otherwise its just easier for you to lose a pound than it is to buy $500 worth of stuff to save a pound. Or in this case make your bike a death machine to save a few grams.
    So, if you want to save rotational weight, get rim brakes instead of discs. But get two of them.
    Reputation: ernesto_from_Wisconsin's Avatar
    six brakes
    Just think of all the grams you will be loosing from knocking your teeth out and bleeding all over the place.
    Brakes are not the place to shed weight.
    Pound 30-40 ounces of water before your ride and loose all the water weight, like someone else mentioned above and only ride with guys who carry tons of tools and spare parts. If you have a mechanical they have everything you need and you don't need to carry anything
    Where's Toto?
    Reputation: endure26's Avatar
    Go fixed and leave 'em both at home
    Chronic 1st-timer
    Dec 2005
    leave the seatpost & saddle at home as well.
    Only lamos need to sit.
    Trailwrecker at large
    V-Shaped Rut
    Strangely enough, this year I had half a ride with no seatpost, saddle or chain. I'm guessing that makes me at least twice as hardcore as anyone on here.
    Quote Originally Posted by lubes17319
    Bike Snob
    Reputation: can't get right's Avatar
    May 2005
    Quote Originally Posted by big_slacker
    Or just the worst mechanic
    V-Shaped Rut
    Quote Originally Posted by can't get right
    Thats far closer to the truth.
    Reputation: Velobike's Avatar
    Quote Originally Posted by Markleo
    Idiotic idea, that's what I think (unless you ride only uphill).
    Latitude: 5736' Highlands, Scotland
    Mtbr
    Reputation: dbo43867's Avatar
    One of my super reliable Formula K18's gave up on a downhill trail. Bled six months ago, only a year old. It was on a downhill section. Thats why you should keep both of your brakes.
    2008 Rig
