Results 1 to 16 of 16
    SS with more than 100 mm Fork
    Hey gang. I just did a SS conversion to my geared frame and am digging it on the road. I am looking forward to trying it on the trails this weekend.
    While looking at all of the pics thread I see that most of you are running either rigid forks or 100 mm sus forks. Is anyone running 120 mm to 130 mm sus forks? Can you get the leverage needed for climbs with this setup?
    XC forks are fine where I live but that is all I have ridden for over 10 years and want to try something different.
    undercover brother
    Reputation: tangaroo's Avatar
    Although I just threw gears back on, I was running my transAM SS with 150mm up front. Climbing was fine, although it was no XC bike.
    If the bike was made for that fork ,then single speeding isn't going change anything.
    Reputation: ChaosCelt's Avatar
    Feb 2013
    I am building up an Inbred that is rigid but OnOne says that it will work fine with a 120mm so i'm going to be buying one when my wallet recovers. I prefer rigid for most of my riding but i'm a big guy and i like to fly when i get the chance so having it as a back up will be nice.
    ChaosCelt, I have a 29er Scandal(100 mm max fork) now and am considering getting a 456 to run SS, convert to 650b(already have the wheels) and put a 130 mm fork.
    WNC Native
    Reputation: nitrousjunky's Avatar
    I had a Canfeild Yelli Screamy setup SS with a 120mm Micro TI fork for a bit, that was a fun SS setup. I had a long debate between 100 or 120mm fork for my custom SS frame, I went 100mm but I think 120mm would have been sweet as well.
    Yelli
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Reputation: The STIG's Avatar
    i ran a 120 on my 456 carbon, climbed and rode great!!!
    Feb 2013
    Quote Originally Posted by missioncontracting View Post
    That is sexy, I've fallen in love with my Inbred considering my level of income it was priced right.
    To the OP, alot of what i've seen on squish forks is based on weight. For instance my roomie is 5'0 and 125lbs soaking wet i watched her ride a 100mm fork and it NEVER moved. Me on the other hand i stand 5'9 at 250lbs and i ride hard so i'm prone to bottoming out a 100mm (albeit an entry lvl). So that's something else to consider. Though definitely get remote lock out makes long climbs so much easier.
    Reputation: Stopbreakindown's Avatar
    Voodoo Soukri with a 120mm fox. Handles great!
    Yelli with 120 up front
    which replaced a Hooligan with 115 up front
    run what you want and have fun!
    Reputation: blackgriffen_1's Avatar
    May 2010
    I run a Pike 100-140 that works just dandy, although I'll say that with proper climbing form, your upper body shouldn't be transmitting force through the cockpit and compressing the suspension anyway, so focusing on that aspect makes you a better all-around rider.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Ran a 120mm Reba on my El Mariachi and now have it on my Highball...no problems.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Jun 2010
    Kona Honzo with 130mm Revelation up front, having no issues at all.
    Mostly a rigid SS, sometimes a geared HT
    Reputation: Jack Burns's Avatar
    Not to be a buzz kill at all, but make sure that your frame is up to it, like Rangeriderdave said in the third post above.
    It's a reminder to me as well.
    Reputation: Andy R's Avatar
    Nov 2008
    Quote Originally Posted by Sorcerer View Post
    But that's hit a tree or something head-on, the same would probably have happened if it had 440mm rigid forks fitted. The first thing that will happen in a situation like that is that the forks will bottom out - so the compressed length is the lever, not the extended length.
    Reputation: Captain_America1976's Avatar
    Mar 2005
    Nimble 9 with a 120.
  1. OPINIONS: Aluminum rigid fork or suspension fork for 9yr old's bike?
    By dragbike in forum Families and Riding with Kids
    Last Post: 05-09-2013, 05:06 AM
  2. Replies: 21
    Last Post: 01-13-2013, 09:06 PM
  3. Replies: 0
    Last Post: 07-24-2012, 07:22 AM
  4. Replies: 5
    Last Post: 09-12-2011, 04:13 PM
  5. Salsa Cromoto 26" fork to replace 100mm travel fork
    By rth009 in forum Shocks and Suspension
    Last Post: 01-03-2011, 09:51 PM
