Results 1 to 50 of 50
    Reputation: playdead's Avatar
    SS chains the only way to go?
    are SS chains the only way to go with a single speed?
    If so, why? Other chains can't take the amount of torque? Will they either break or fall off?
    If not, what kind of chain are you running?
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    why is torque higher?
    I run a kmc z-72 w/ no probs
    Honestly... ahh I give up
    Reputation: tamen00's Avatar
    I have had terrible luck with all of the SS chains I have tried. I have been running SRAM 8 speed chains for several years and have had really really good luck with them (and they are pretty cheap)
    "why is torque higher?"
    Not sure if it is.
    z-72... is that a SS chain?
    ~Disc~Golf~
    z72...
    it's an inexpensive 8-speed chain
    I keep getting them because they're cheap and I dont break them (I don't break other brands either so...)
    they shift fine on my gearie too (side note - if it matters)
    is buachail foighneach me
    Reputation: sean salach's Avatar
    sram 8sp for me. works like a charm.
    Reputation: scooter916's Avatar
    i run the full nickel plated sram 9spd chain on my old single speed, that way if I do happen to break a chain (happened once long ago on a severely worn chain) I can steal a few links from a geared riding buddies chain to limp home.
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    Out spokin'
    Dec 1999
    Same here. --Sparty
    Quote Originally Posted by sean salach
    disciplesofdirt.org
    Reputation: boomn's Avatar
    same here as well
    Nice. This is helpful info.
    Gracias
    Ovaries on the Outside
    Reputation: umarth's Avatar
    search function...
    ~Disc~Golf~
    Quote Originally Posted by umarth
    search function...
    impersonal
    Reputation: asphaltdude's Avatar
    +1 for Sram 8-speed chains.
    KMC Z610HX SS chain is nice, but the master links sucks.
    Ride more!
    Quote Originally Posted by highdelll
    impersonal
    "SRAM 8 Speed"
    "+1 8 speed"
    Is that personal? You can read that on any of the bimonthly threads about what chain to use. Have you noticed this is an internet forum?
    ~Disc~Golf~
    "SRAM 8 Speed"
    "+1 8 speed"
    I had not.
    My bad
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    dont get the z 51 for an SS chain, it stretches too fast
    "If women don't find handsome , they should at least find you handy."-Red Green
    Master Gardener
    Reputation: Velokid1's Avatar
    May 2005
    Quote Originally Posted by tamen00
    Tom- which model do you usually run? Which chainrings and cogs (out of curiosity)?
    I've been looking for something outside of the few 1spd chains that are on the market.
    Sram 8 spd
    Birthday Collector
    Reputation: ATBScott's Avatar
    SRAM 8-spd stuff is really strong and you will likely never have a problem with it. Scooter916 has a good point, but if you carry a couple links of your own, then you are rocking regardless of what chain you ride and if you are solo too! I run SS chain (1/8" vs. 3/32") only because the cogs and ring teeth are wider and will last a lot longer, if made of comparable materials...
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    Quote Originally Posted by playdead
    Not sure if it is.
    The torque is potentially the same, just way more often on a SS. On a geared bike, when you shift down, you're sparing your legs, and the drivetrain that "max force" load. On a single speed, you don't have that option, so things wear out faster.
    Maybe it's just my imagination but my Surly ring seemed to get wedged in between 9-sp chain plates, maybe because 9-sp is narrower? I'm on 8-sp Sach chain from the 90s that came off an old bike. No issue for 9 months now.
    Quote Originally Posted by hatake
    Yep, 9spd chains are narrower. Surly only rates their MTB rings for 8spd chains (see here)
    SRAM 8spd chain for me.
    If a half link is needed, then it's the Gusset half link with a pair of KMC Z610HX-C/L master links. Stay away from the KMC half links as they're more trouble than they're worth.
    Sram PC-1 Nickle
    Daryl
    SRAM 8-speed. I also carry a spare SRAM masterlink and a lightweight chain tool. I have never needed it for myself, but have bailed buddies who broke their chain on their deraileur bikes.
    Funny... the only chain I've ever snapped was a SRAM PC-58 8 speed chain. 32x22 gearing and a pedal kick... SNAP.
    Never again will I buy a SRAM multi-speed chain. If I can't trust it, it doesn't go on the bike.
    Quote Originally Posted by sunset1123
    oh well, more chains available for all the rest of us
    I am a total sram hater but even I have to admit that the 870 is a great SS chain. Is it just me or are the Sram 9spd chains way over priced? Doesn't the 971 look just like a slightly narrower 870. Only the 870 is way cheaper. Infact shouldn't the 9speed be cheaper since there is less metal there. Maybe they actually discounted the 870 but I doubt it since its more likely that they just make more money on the 971.
    Mtbr Forum Sponsor - Homebrewed Components
    i think my next chain is a KMC K810SL
    Reputation: byteMe's Avatar
    +1 for SRAM 8 speed
    don't try this at home
    Reputation: moschika's Avatar
    what's a single speed chain?
    i've been using cheap kmc chains the last 10 years that come in the red or blue box and cost about $7.95 and last about 2-3 years before it breaks or stretches too much. don't know if it's a 6,7, or 8 speed chain or what model number, just that if the box color matches the price, i'm good.
    will you rep me?
    6,7,8 speed chains all be the same 3/32 width. A true single speed chain is a real fat 1/8".
    Quote Originally Posted by bikerjay
    A true single speed chain is simply one with straight plates. BMX bikes use 1/8" chains, there's no reason to use one on a mountain bike.
    and don't mix rings and cogs designed for a 3/32 chain with a 1/8 chain. Even with perfect chainline and tension it will come off, well, at least that was my experience.
    Quote Originally Posted by byteMe
    ran it like that for years without dropping a chain once.
    not the best idea but it was a free chain and i like free stuff.
    i have used a 3/32 fixed gear setup on my commuter with a kmc 9spd chain for years now, and never had a single issue. i'm pretty rough on that chain too. i'm 200lbs, and i skid/skip all over the place.
    King Pin
    Reputation: xrmattaz's Avatar
    Good job!
    I'm still utilizing my old stash of SRAM PC7X chains....the gold color is long gone from the sideplates on all four SS bikes.
    These were supposedly reintroduced?
    At 6'5" and 240, I tend to break the 8spd. SRAM chains mentioned. I'm really rough on the PC7X's, all four are >5 years old, now.
    Master Gardener
    May 2005
    Anyone else have more trouble with their cogs/chainring teeth getting splayed/worn than with chains breaking? I've never broken a chain on a SS but go through chainrings/cogs way too often.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by Velokid1
    Chain tension ?
    I had the same problem until I reliazed that i was running my chain a little too loose, once i started running the chain tighter my cogs and chainrings started to last way way longer than before
    Master Gardener
    May 2005
    Thanks guys... I am a bit anal about my chain tension so I wouldn't suspect that was the problem, but could be.
    Quote Originally Posted by asphaltdude
    But please, DO NOT buy the PC-830.
    5 rides, of which only 1 in the mud, and it's already stretched more than 1%.
    Ride more!
    Time to go farther
    Regular 9 speed chains with a powerlink. I'm pretty weak though...
    Edit: 8 speed work fine too and are a little cheaper, a little heavier.
    On-One Lurcher SS
    Speedway Cycles Fatback Ti SS
    1984 Trek 560
    http://slipangles.blogspot.com/ - It's supposed to be fun
    one chain loop
    Reputation: fishcreek's Avatar
    +1
    SRAM 8spd, PC-68 to be exact.
    everything sucks but my vacuum cleaner.
    Dudette
    Reputation: petey15's Avatar
    Glad someone started this. Been converting an old Diamondback Sorrento to SS. Got a DMR tensioner and had gotten a singlespeed chain. Then it says on the packaging that you should use a 8 or 9 speed chain with it. Huh? Well, maybe that's the case, because have not been able to get that thing to work properly at all the minute you put any kind of tension on the chain. The tensioner flexes something fierce. Any ideas?
    Quote Originally Posted by petey15
    I haven't use that specific brand of tensioner, but with those roller style tensioners a true 1/8" singlespeed chain could be wide enough to bind against the sides of the roller. Also make sure you have a good straight chainline from the front to the back and that the tensioner is properly lined up with that chainline.
    If that isn't it, just tighten the derailleur hanger bolt harder
    Retro Grouch
    Reputation: aka brad's Avatar
    Check out my chain faq. I used to cut and past the whole thing, but I'm guessing a link might be better. Let me know what you think.http://onespeedbiker.blogspot.com/20...chain-faq.html
    Just one more rep and I get the toaster!
    V-Shaped Rut
    Reputation: big_slacker's Avatar
    The only chains I've broken were using improper links. (AKA the "hammer an old pin in to add a link the night before a ride" method.) I broke that one running 32/20 on a 26", meaning not a lot of torque.
    Other that that, 32/18 on a 29er running a 9 spd SRAM. Its plenty strong for hammering up steep stuff, and stronger riders than I do the same. Take care of your chain and it will take care of you.
    ~Disc~Golf~
    Quote Originally Posted by big_slacker
    WORD!!!
    A properly pinned cheapie-chain should hold most stress that anyone can deliver to it
    Retro Grouch
    I would not judge a chain on the first couple of rides. Using an EBB, I notice a chain will lengthen quite a bit the first time it is used; this may be due to the factory lube being forced out of the chain. OTOH this mtbr reviewer seems to agree with you..
    Submitted by danger gadget; a Weekend Warrior from Wellington New Zealand
    Date Reviewed: March 31, 2009
    Favorite Trail: Swiss Wall Morzine
    Duration Product Used: 3 months
    Price Paid: $10.00
    Purchased At: CRC
    Strengths: Can be used as a door stop afterwards. Highlights of my time using it included removing it from my bike for good.
    Weaknesses: Incredibly weak construction. Wears faster than any chain I've seen in my short lifetime - mine was destroyed in just over three months. Once it's worn, it will destroy your other components. My bike doesn't even have a deurallier and it's still bad!
    Similar Products Used: SRAM PC 850, PC 58, PC88.
    Bike Setup: Ibis Mojo with Rohloff rear hub, 44 tooth LX ring.
    Bottom Line: Just pay the extra for one of SRAM's better chains and you will definitely save money in the long run. This one just isn't built to last. Not only does it wear quickly, individual links break down into pieces, and the whole chain will then quickly wear your other components.
    Value Rating:2 Overall Rating:1
