Results 1 to 9 of 9
    Eat More Dirt
    Reputation: Westrider7's Avatar
    Feb 2006
    SS chainrings for XT-770 crankset
    I need some advice on some non-ramped SS rings I can fit on the XT-770 crankset. Last I remember the fancy carbon spider that Shimano uses on this crankset makes it difficult to fit other brands.
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    You sure you named the right crank? XT M770 has an integrated aluminum spider that happily takes the ubiquitous 104bcd...
    Eat More Dirt
    Feb 2006
    Quote Originally Posted by zaskaranddriver View Post
    Ya, it is a 4-bolt 104 bcd. I just thought the interface was goofy/proprietary for some reason...
    Reputation: Nater's Avatar
    It's the ring spacing that is goofy.
    If you're looking to run the M770 rings on a different crankset you may run into trouble.
    If you're looking to run a different set of geared rings on the M770 cranks you may run into trouble.
    I think many SS rings will work fine. I'm using a Surly stainless 34 tooth on mine no problem.
    Eat More Dirt
    Feb 2006
    Quote Originally Posted by Nater View Post
    Ok, I thought I remembered running into that issue in the past. I just wanted to double check before I ordered an new chainring. I am eyeing a homebrewed ring at the moment and they don't mention a compatibility issue so I hope it goes on smooth.
    Mtbr Forum Sponsor - Homebrewed Components
    Nope, it'll bolt up just fine!
    Eat More Dirt
    Feb 2006
    Quote Originally Posted by ISuckAtRiding View Post
    Ahh, look at that, its the homebrew dude right there!
    I am going to put one of your pink chainrings on my bike, with a gold chain, on a blue Karate Monkey. It's gonna be cherry. I'll send a pic.
    D.M.S.R.
    No issues with a 104BCD. Just use some shorter chainring fasteners.
    That's not a stock finish...
    Some yummy crank porn there!
  1. New Chainrings vs New Crankset
    By williaty in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-04-2010, 11:48 AM
  2. Replace chainrings vs whole crankset?
    By hootsmon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-08-2009, 04:38 PM
  3. chainrings for older XTR Crankset
    By Gonz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2006, 11:25 AM
  4. Chainrings for XT M760 crankset?
    By cbratt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-23-2005, 06:26 PM
  5. Chainrings for XT M760 crankset?
    By cbratt in forum Where are the Best Deals?
    Last Post: 11-21-2005, 09:40 AM
