Results 1 to 12 of 12
    SS Chainring for 3-arm FSA Afterburner Crankset
    So, I have a 3-arm FSA Afterburner crankset that I have made SS... the existing small (30T) chainring is OK for now, but I will definitely want to go with a SS specific chainring pretty soon...
    Any recommendations?
    any issues with SSing 3-arm cranksets?
    Reputation: asphaltdude's Avatar
    Proprietary standard components are a singlespeeder's worst enemy.
    Ride more!
    Reputation: blackgriffen_1's Avatar
    May 2010
    Besides the fact that three bolts taking the full load of pedaling torque, the proprietary BCD is the downfall.
    I've never seen an aftermarket ring for the FSA 3-bolt pattern, so I'd suggest rotating the chainring and tweaking the bolt tightening pattern to try to eliminate your high/low tension variance, then just run a tad bit more tension than you would with a proper SS drivetrain. You shouldn't have any issues, but there will always be a possibility of throwing the chain.
    Hmmmm.. or just swap out the crankset...
    Thanks for the reply folks, kinda confirms what I was suspecting... that with a 3 bolt chainring I'm stuck with standard chainrings.
    May 2010
    Pretty much, too bad that's how it ends up. :/
    But in the end, you could hopefully recoup enough from selling the FSA crank to set yourself up with a decent 104 BCD crank.
    Best of luck, and let us know how it pans out!
    Jun 2005
    3 Bolt 86mm BCD Chainring
    We have chainrings to fit the 3 Bolt 86mm BCD and they are available in aluminum, stainless steel and titanium:
    Warhawk Industries - Specializing in Stainless Steel, Titanium and Aluminum Chainrings
    Hmmm... Warhawk... looks like a possibility!
    Looks beefy enough too!
    anybody else out there have opinions on the use of 3-bolt chainrings for singlespeed...
    My opinion is that usually us singlespeeders overestimate by a little bit how much torque we are putting on chainrings, chains etc... I mean geared riders stand up int he cranks too... I think we may exert a little more force, but not enough that I think a 3-bolt pattern is a problem, but I am curious if anyone has had a problem with this before?
    Moderator Moderator
    Reputation: driver bob's Avatar
    I had Mattias @ Hellore make me a Ti ring
    YEah, Warhawk offers a TI version as well... figured I'd try the Al version, see how it all jives, and then invest in TI if it works out.
    Jan 2013
    Any other options for the fsa 3 bolt cranks? I am converting my el mariachi 3 now and have a wheel, hub, and rear cog setup from an el mar SS. Not finding a whole lot of options for my stock fsa comet cranks with a standard 2x setup. I like the crank and bottom bracket as it has taken everything I have thrown at it geared and wanted to keep it. Is warhawk the only one making a 32 tooth 3 bolt? Also could I get decent gearing with either of my current rings on my 2x setup which is a 27/39?
    2013 Mukluk 3
    2012 El Mariachi
    2012 Specialized Carve comp (work bike)
    2005 Banshee Chaparral
    2008 Felt F4C (roadie)
    Reputation: Hudnut's Avatar
    Apr 2005
    It looks like FSA is now offering a single ring version of the afterburner specifically for 1x11. Any word on if they will offer just the 386 ring?
    AFTERBURNER SINGLE 28T, 30T, 32T, 34T, 36T, 38T CRANKSET
    Apr 2005
    I received an email response back from FSA. they said that it will be available late winter and that they are calling the chain ring "megatooth".
  1. Paid Spam:FSA Afterburner BB30 3x9 Speed Crankset.
    By Thatshowiroll in forum Cannondale
    Last Post: 03-17-2013, 06:31 AM
  2. Paid Spam:FSA Afterburner BB30 3x9 Speed Crankset.
    By Thatshowiroll in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-15-2013, 12:07 PM
  3. FSA Afterburner Compact 386 MegaExo MTB Crankset w/ BB $96 W/ fs 2x9 and 2x10
    By FireLikeIYA in forum Where are the Best Deals?
    Last Post: 08-21-2012, 09:56 AM
  4. FSA Afterburner 386 MTB Double Chainring Bolt
    By jburtonrider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-10-2012, 05:18 PM
  5. FSA afterburner 386 front chainring
    By kenny fluke in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-26-2011, 07:59 AM
