SS Chain Advice
Printable View
  • 02-11-2013
    kdaly1
    SS Chain Advice
    I have a 13 Trek Superfly AL Elite that I converted to an SS. My chain broke this weekend and I was able to fix it to get back to the car. I dont feel confident and want to get another one. Any suggestions on a real reliable chain that can take a beating? I run a 32 x 18. Thanks Guys/Gals
  • 02-11-2013
    Sparticus
    Originally Posted by kdaly1 View Post
    i have a 13 trek superfly al elite that i converted to an ss. My chain broke this weekend and i was able to fix it to get back to the car. I dont feel confident and want to get another one. Any suggestions on a real reliable chain that can take a beating? I run a 32 x 18. Thanks guys/gals
    sram pc-850.
    =s
  • 02-11-2013
    kdaly1
    10-4 Thanks. Just bought it on newegg.com Didn't know they did bike parts now too...
  • 02-11-2013
    zorro
    I've been riding the Cutter Asymm Single Speed Chain. I know some peeps don't like it, but it's been working for me. Mind you I'm far from a clydsdale.
  • 02-11-2013
    jetboy23
    Almost any 3/32" chain will work for SSing as long as your chainring and sprocket are that size. If 1/8th, just get a KMC k710 and be done with it.
    All depends on how much you want to pay. I've used Sram 8 & 9 speed chains. The powerlinks make it easy to remove and fix trailside. I've never had one break on me. Now i run KMC chains. 8.83 & z610hx. So far, the 610 is wearing better than any of the others i've run. KMC's listed can usually be found from $8-12.
  • 02-11-2013
    kdaly1
    Great to know thank you very much! Glad I asked!
  • 02-11-2013
    ride_bikes
    The best chain I've used by far for road and trail is...
    KMC Z610HX DropBuster BMX Bicycle Chain (1-Speed, 1/2 x 3/32-Inch, 112L, Silver)
  • 02-11-2013
    stremf
    I personally use SRAM 8-speeds, but far more important than the chain is the chainline. Make sure you've got that dialed in, as it can destroy just about any chain and ride.
  • 02-11-2013
    michaelscott
    I'm a fan of KMC's just because you can take the chain off with your fingers (instead of some sort of proprietary tool like Shimano) for cleaning. I heard SRAM also has this feature but have never tried one of their chains.
  • 02-11-2013
    Bike Whisperer
    Another KMC 610HX vote. Cheap and durable!
  • 02-12-2013
    Chainstretcher
    I run the KMC X9 Gold. Much lighter than the stock one and super strong. I snapped my other one a few weeks ago and I only have a few miles on this one. I did some pretty big climbs and at 242 LBS I really stand on those pedals.
  • 02-13-2013
    kdaly1
    Not sure why my order didn't go through but I got the KMC K710 this time around as it was a little cheaper. Hope it works out. Thanks guys
  • 02-13-2013
    jetboy23
    Are you running 1/8" drivetrain? If not, you may have some slop with a 1/8" chain (k710) and 3/32" chainring & sprocket. The k810 is the 3/32" version of the k710, fyi.
  • 02-13-2013
    TroutBum
    sParthoLomus is all knowing. Dude know's a bit about things & stuff. There ain't many things more durable for 250 pesos than a SRAM 8 speeder, 'cept maybe a Surly cog.
  • 02-14-2013
    kdaly1
    10-4 Perhaps, I'll get both and have my LBS advise me what I have and install the correct one. Thanks for the heads up.
  • 02-14-2013
    blum585
    I run a Sram 951 (9 speed) light, cheap and strong. I switched to a KMC gold chain and snapped it in less than 3 hours (from new). 951 works and lasts long.
  • 02-14-2013
    Sparticus
    TroutBottom, your blatant attempt to snag some +rep failed. Sez mtbr:
    "You must spread some Reputation around before giving it to TroutBum again."
    Don't worry, I'll hit ya asap. :D
    Meanwhile your usual monthly check is in the mail...
    --sParty
  • 02-16-2013
    bart bakker
    The KMC 610 is a good cheap option but the KMC X1 will last at least 2 times longer and looks better because of the nickel plating. It takes up less dirt as it has a smoother finnish.
  • 02-16-2013
    jetboy23
    My 610 still looks new after about 700mi and is also nickel plated. I do live in SoCal and mostly deal with dust. Rock n' Roll Gold and Finishline Ceramic Wax keep it clean and running quiet. I don't know where you get 2x longer for the X1, but, for $10-12 you can still buy two 610's and save money. My 610 is wearing great as well and will probably last over a season for me.
  • 02-17-2013
    perttime
    Er... What ?
    How do you shorten your KMC chain, so that it is the right length for your bike?
    You can use the KMC or SRAM quick links with Shimano chains.
  • 02-17-2013
    michaelscott
    Originally Posted by perttime View Post
    Er... What ?
    You'd have to use a chain breaker tool to initially set the length- but after you can just take it off by hand.
  • 02-17-2013
    S.O.B.
    Another +1 for SRAM chains. I am currently using a 950, but sometime use the 850. Never broken one (and I ride a lot of miles and with a lot of elevation). The only chain I have every broke is a KMC. Can't remember the model, but it was one of those superlite chains with hollow pins and spaces between the linky thingys, so not a big surprise there.
    Like previously mentioned, know what your drive train will allow for. If you are running a cog or ring cut for 1/8 then do not run a 9 or 8 spd. chain.
    I currently run an HBC front ring and King cog. Soon I will be switching to a e13 ring and an Endless cog (along with that SRAM 850).
    Good Luck with whatever you go with.
  • 02-18-2013
    perttime
    Yup.
    A chain breaker tool isn't proprietary Shimano, KMC, SRAM, or Campagnolo, though.
  • 02-18-2013
    SlowPokePete
    I've always been happy with SRAM 971's.
    SPP
  • 02-18-2013
    briscoelab
    Sram 870 or 890. Sometimes even 830 bulk chain if I need a chain in a pinch.
  • 02-18-2013
    rglsr
    SRAM 870 8 speed chain, running those SS for years, never a problem.
    Quick link is nice to have. You'll need 3/32" chainrings, 1/8" won't fly.
