Results 1 to 8 of 8
    specialized 29er single speed
    here my new stumpjumper 29er singlespeed that i built
    Great minds think alike cause here is my new Stumpjumper Single Speed
    SSolo, on your left!
    Both look nice, what are the specs?
    Get off the couch and ride!
    Quote Originally Posted by Natedogz
    Specialized Stumpjumper Marathon 29er
    RST M-29 fork at 80MM
    Woodman headset
    WI ENO cranks with a 32 chaining front
    Crank Brothers candy pedals
    Shimano Bottom bracket
    Bontrager post
    Ritchey Pro stem and bars
    Ritchey Rocket V saddle
    Oury grips
    Avid BB7 brakes with Speed dial levers
    Kick Ass Cogs 21 tooth rear
    Front tire Panracer rampage 2.35
    Rear Tire Bontrager Jones 2.25
    I took the wheels, stem and bars from my old Redline Monocog flight
    stump jumper marathon 29er size 17
    bontrager race x lite wheels
    bontrager switchblad carbon forks
    bontrager bars
    fsa stem 100mm
    avid juciey ultimate white front 160mm rear 140mm
    truvativ stylo cranke 175mm 32mm
    kendra small block
    Sounds like you got a lighter build than mine. I was on a budget so I did alot of swapping from my Redline. My wheelset weighs a ton but they roll so that are going to stay on there for a while.
    i was going to put on a noir crank till i found out the price
    I went with the ENO's and love them so far. My big heavy spot is my wheel set. They are the stock flight set, kinda boat anchors but again they roll so it is ok. I have not heard of noir cranks I will have to take a look at those. Ok jut googles and understand why you did not stick those one there.
