Results 1 to 10 of 10
    Reputation: PnoyPride's Avatar
    May 2013
    Spacers for a single speed
    Hi everybody. I have a question about spacers. I want to change my cog to a 19t on my specialized carve sl but I cant find the right spacers. I got a surly 19t cog and the base of that cog is thicker than the stock 20t cog. I tried my lbs but they dont have any. What should I get and where? Thanks!
    Reputation: jetboy23's Avatar
    Look here for DIY - Cheap DIY Spacer.
    Or.... order from an online source . LOL.
    Apr 2013
    If the LBS doesn't carry dedicated SS spacers you can also see if they carry any 10 speed or 8-to-9 speed adapters and put a few of them on. Otherwise just order a kit up online.
    May 2013
    Quote Originally Posted by jetboy23 View Post
    That is genius! Thanks!
    Reputation: PoisonDartFrog's Avatar
    If you are in the States, go to a local home improvement store and get a short section of 1-1/4" I.D. Schedule 40 PVC; this fits perfectly over a free hub. Then use a miter saw to cut to whatever width you need. Works great, so long as you have the ability to cut it straight (hence the miter saw suggestion).
    And if white plastic is displeasing to your aesthetic sensibilities, you can always pick up a can of spray paint as well.
    Mind your own religion.
    Quote Originally Posted by PnoyPride View Post
    Just buy a surly spacer kit.
    Spacer Kit | Parts | Surly Bikes
    Endless bikes also makes a cool spacer set:
    Fibonacci Spacer Kit:
    Endless Bike Company | FIBONACCI SPACER KIT
    Reputation: Nubster's Avatar
    Or how about something like this? Not sure how well they work but seems you'd get maximum adjustability with something like that.
    Universal Cycles -- Gear Clamp Single Speed Kit
    May 2013
    Thanks guys! I appreciate that.
    strangely the plastic spacers from a shimano BB fit on the freehub, just pop down to your LBS and score yourself a whole fist full as the BB's don't last long and are a throw away item. I used an alloy one from my CK BB to go next to the lock ring as the plastic one was too soft.
  1. Replies: 12
    Last Post: 09-17-2011, 04:19 PM
  2. Convert a Single speed hub to a 9 speed cassette
    By dasnakenyc in forum Singlespeed
    Last Post: 06-29-2011, 02:36 PM
  3. single speed hub to six speed gear
    By oldphaty in forum 29er Bikes
    Last Post: 06-25-2011, 01:29 PM
  4. Single Speed Specif Hub vs standard with spacers
    By rjhartman3 in forum Singlespeed
    Last Post: 05-20-2011, 10:34 AM
  5. Alfine 8-speed or Single-speed?
    By bwheelin in forum Bike and Frame discussion
    Last Post: 05-19-2011, 08:09 PM
Members who have read this thread: 4
