Results 1 to 38 of 38
    zeebot
    Reputation: Spookykinkajou's Avatar
    some boone love and..
    brett spun me out a 21T cog in less than a week for my adventures down in the mountains this coming week.
    enjoy the pic. a beauty!
    from the east
    Reputation: Bicycle Rider's Avatar
    It's so clean...
    Wowzers!
    when you're not using that, you should strap it to the headtube, yes indeedy.
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Sweet looking!
    I have a 22tooth Boone.
    I figure it's lasted at least 1,000 miles so far.
    Not bad.
    My aluminum 19tooth King lasted about 3 months.
    My steel 20tooth King lasted great.
    Where are those naysayers who said the ti Boone woudn't last very long?
    I think I'll pony up for a 21tooth next time I need one. I'll try to man up for that now....
    Bikes not Bombs.....
    Reputation: SS Jerry's Avatar
    No Shark fins...?
    I have a 22T Boone cog that has shark fins on the teeth. How about anybody else. Did he change it out?
    JS
    Thanks to all of you for your friendships on this board..... -
    Change it out?
    Nah...what for?
    Mine is wavy on the teeth. Works great. I think the wavey teeth should rotate fwd.
    By the way.. it's pretty!
    Quote Originally Posted by SS Jerry
    I have a 22T Boone cog that has shark fins on the teeth. How about anybody else. Did he change it out?JS
    get down!
    Reputation: appleSSeed's Avatar
    sent you an email spooky about the 20T cog
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    34N 118W
    Reputation: Hollywood's Avatar
    sharked
    yep my are fin-ish.
    JS
    JJT
    JJT is offline
    Reputation: JJT's Avatar
    Quote Originally Posted by Hollywood
    yep my are fin-ish.
    Yeah, mine too.
    Think the shown one is better so you can swap it to wear it to the max..
    Boone Titanium Rings
    Reputation: btboone's Avatar
    The sharkfins usually help clear the chain in shifting. I've always had them on smaller cogs. We realized there's no need for them here, and on a fixed gear single speed, there's a reversed thrust on the teeth when you backpedal to decelerate. It made sense to keep them full height. They could be reversed too, but you would need to look through the spokes to see the polished double step. I hate when that happens!
    I don't think it matters about the teeth.. no matter what.. people stop me... I'm thinking there checking my bike out when they say..."What kind of cog is that? That thing is purrrrty!"
    It's like having your cake and eating it too. If you want a 22 tooth wide based cog...it's gotta be "dead sexy" too I guess...
    Quote Originally Posted by btboone
    The sharkfins usually help clear the chain in shifting. I've always had them on smaller cogs. We realized there's no need for them here, and on single speed, there's a forward thrust on the teeth when you backpedal to decelerate. It made sense to keep them full height. They could be reversed too, but you would need to look through the spokes to see the polished double step. I hate when that happens!
    JJT
    JJT is offline
    I can only see one solution: Polish both sides
    One gear to rule them all
    Reputation: 32seventeen's Avatar
    Are there any plans to make your cogs out of other materials, like Stainless Steel?
    Todd............. If you can't be kind, at least have the decency to be vague
    zeebot
    Quote Originally Posted by 32seventeen
    blasphemy!
    There's no plans for stainless at this time. The material's only one component of the cost. The stainless would still take the same amount of time to cut, would break just as many expensive cutters, and would take as long to hand finish, so they would have to be expensive too. The thinking is why not reduce 40% of the weight with ti if it will take that much effort. Stainless could be laser cut or stamped, but the cost of the equipment is major league, and the quality would not be the same.
    I was thinking more about durability, not cost. I have used Ti cassettes on my road bike and found that they did not last very long. The larger cogs were OK, but the smaller one were toasted very quickly. I don't have any direct experience with the Boone cogs. I love the look of the boone cogs, but how long do the ti cogs usually last?
    I need to get a 17t cog for my new king SS hub and I don't know if I should stick with a stainless king kog or get the bling bling boone cog?
    The titanium is as durable as stainless. They are very similar in properties except for the weight. The 6Al4V titanium has a hardness of 35 Rockwell C, which is pretty tough stuff. It can be flame hardened from there, but we've never seen a need for it. You would have to do some serious miles to wear one out. The biggest factor is the number of teeth the load can be spread over. Something like a large or middle chainring will essentially never wear out. I'm still riding mine from 1993.
    Brown Technologies
    Reputation: brett's Avatar
    Although stainless steel has a higher ultimate strength, it is a lot softer (lower than the Rockwell C scale will measure, but around 19 hrc). The hardness of materials is usually used to judge a material's wear characteristics. So, steel is real, but ti is harder in common sheet forms.
    Brett
    Brett finally brought me a cog with the wavy spacers to photograph. It's amazing what the reflection of a floppy disk and some yellow notebook paper can do. I'll post it to the website in my "spare" time.
    Boone XTR chainrings...
    Any news on plans to make an XTR spline fitting ti all in one ring/spider? I know you were looking at an XTR chainset a few months ago...
    Ian
    Brown Technologies
    Yes, we got those completed last week. We have the XTR and Truvativ Stylo splines now. The 34, 33, and 32 tooth versions are programmed, but we can make any size you want. If Bruce is listening, he can post a pic of the 34 XTR he took last week.
    Brett
    Ah yes. This must be the one.
    WAWE
    whoa
    Pinball Wizard
    Drool...
    How much are you asking?
    That is absolutely beautiful. I didn't see it listed on your web site. How much are you selling them for? If the price is close to the others on the web site I'd like to buy one. Email me if you can.
    get down!
    WHOA! I'd like one also, how much?
    if you're out, put me on the list @ michaelkauk@hotmail.com
    and if you're in email me cause I have to have that!
    in other news, Spooky I got the 20Tooth King Cog today, good looking out maing!
    What kind of hub are you use this on?
    I just got a Boone cog for a customer and it's loose on an AmClassic hub.
    Brown Technologies
    American Classic Hub
    Quote Originally Posted by SS_Belmont
    If anyone has an American Classic Hub I can borrow for a week, let me know. I reimburse shipping directly, or give sell a cog or ring for half price or something....
    Brett
    The splined outer chainrings will be $105, and are available in 29T, 30T, 32T, 33T, 34T, and 36T. I just put them on the orderform.
    I like Squishy Bikes
    Reputation: Hollis's Avatar
    One Spotted Spooky
    I spotted Spooky at the Pisgah campground & chatted a bit.
    I think he's having a good time...he mentioned moving to West NC
    This is him splainin' his only ride of the day (all 60 mileSS of it).
    His Magura brakes & WTB freewheel are kinda fried.
    The Boone Cog still looked good, even under all the mud.
    A dirty book is rarely dusty
    Reputation: TD64's Avatar
    And I would like to thank you very much for doing that--'cause I just ordered one (and a cog too)!
    TD
    (aka SS_MB-7)
    Reputation: 1speed_Mike's Avatar
    Quote Originally Posted by Hollis
    Can you please elaborate on the Magura Marta SL brake issue? I'm a disc brake junkie (I've owned way too many: Hopes, Formulas, Shimano, etc.) and am always curious to know the good-n-bad about all brakes, especially the Marta (which typically gets great reviews, but....)
    Ride Hard,
    Mike B. (MCM# 7.77)
    http://www.one-speed.com
    MKD
    MKD is offline
    What's the web address for Boone......?
    I can't find it after going thru several search engines. Thx MKD
    ... and if we just ...
    Quote Originally Posted by MKD
    Please accept this in the lighthearted nature it is intended..... =)
    LOL
    Now, scroll up to Boone's last post.... click on his username...where you can get more info about him...INCLUDING....his website...yay!!!!
    sorry, MKD...couldn't help it! =)
    you can try this too....
    Boone Rings on Google
    MKD
    MKD is offline
    Yeah, that's how I felt ...................
    Pretty funny. thx MKD
    1speed_Mike
    Quote Originally Posted by 1speed_Mike
    Hey Mike,
    I'm not exactly sure (I only know about Avid Mechs),
    but what I saw was the lack of lever action/travel.
    Left lever was solid like it had too much fluid.
    Right lever moved slowly...like it was full of molasses.
    SpookySean also said he needed new brake pads.
    Reputation: Thylacine's Avatar
    You know, as a designer, It's rare that I find items or products I think are awesome - products where I wouldn't change anything if I was designing them myself.
    The Boone stuff is one of them. Simply gorgeous. Major props.
    *checks wallet for spare hundred dollar bill*
    No longer member of the bike industry nor society, so don't hassle me.
    zeebot
    major delayed answer but here ya go. the pads were nearly new and completely wore through during that ride...they had about 1 hour left of riding before metal on metal. this is probably justified since i was riding in terrible conditions through lots of sand, dirt, etc for a very long time. jeremy's also wore through and he actually had to change them on the trail. they were juicy's and were 1 week old. the levers still havent recovered but seem to be getting better. right after the ride i could pull the lever in and i would have to push it back out to get it to return to it's original home. the rear still does it some but not nearly as bad. the front seems to have fixed itself.
    Reputation: Zen_Dude's Avatar
    Where can I get one of those 20 tooth cogs? can't find any info. Help.
  1. Gotta love this bike...
    By MTBsSd in forum Downhill - Freeride
    Last Post: 09-19-2006, 08:43 AM
  2. Not a hater ( I love Intense bikes)
    By yogreg in forum Intense
    Last Post: 07-21-2004, 02:10 PM
  3. Thoughts on Boone Ti cog
    By smudge in forum Singlespeed
    Last Post: 03-07-2004, 10:41 PM
  4. Storck, Boone, Syntace, Tune weights/pictures
    By Anders in forum Weight Weenies
    Last Post: 02-05-2004, 12:48 PM
  5. Boone cogs?
    By crux in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2004, 03:48 PM
