Results 1 to 17 of 17
    May 2015
    Soma Juice Issues?
    Bought a 21.5 Soma Juice Brownstone a year ago and have broken 2 frames in the same spot over the last year. the company is most likely going to send me a 3rd frame but I am trying to decide if it's worth building up again.
    A little backround on rider weight and how i ride:
    I weigh 200lbs fully equipped for a long ride and I run the bike with a 120mm fork plus a dropper post for the descents. I ride colorado trails that are dominated by full suspension bikes and I tend to keep up or pass them on the descents. If any of you are familiar with the front range of colorado, the most recent frame broke somewhere while riding the loop at heil ranch. https://www.mtbproject.com/trail/52119
    I bought the juice because i thought it was a slightly more aggressive(fit up to 140mm fork) xc steel ss and i am worried i ride to hard for the frame
    That being said in the past I have ridden way less aggressive single speed setups without breaking frames(raliegh talus 4.0,Gary Fisher Rig,Spot Longboard, Karate Monkey)
    Just trying to decide if this is this the wrong bike for me and if I should just save up for a new karate monkey, niner SIR or spot rocker
    Any other soma juice owners having similar issues?
    Soma Juice Issues?-20170716_083238.jpgSoma Juice Issues?-20160826_095850.jpg
    Jan 2013
    My roommate has the exact same frame that cracked in that same spot. He just took it to a welder and had it fixed. He never got a response from Soma so count yourself lucky that they are sending you a replacement.
    wanna ride bikes?
    Oct 2013
    You seem to be substituting the term durable with aggressive. They do not necessarily go hand in hand. Sounds like you may need a stronger frame.
    Rigid SS 29er
    Fat Lefty
    SS MonsterCross
    SS cyclocross
    all steel
    Oct 2016
    That style of dropout (cast one from china, cnc'd ones from paragon, and everything in between) are a poor design, and the further you pull the wheel back, the worse it gets.
    The rear axle is located so far behind the seat stay that the seat stay becomes more of a leverage point rather than support for the dropout. All the force that is applied to the rear axle from riding is trying to rip the dropout apart (or off the chainstay).
    I would avoid EBB's also, if you are riding that aggressively, the EBB will have issues of its own.
    Look for a frame with a better dropout.
    Salsa's Alternators
    Spot's Kobe's
    Paragon Rockers
    Jan 2009
    It looks like you had the sliders pushed pretty far back, which would cause a lot of stress. Still, they should be strong enough to not break like that.
    The EBB on my ROS 9 was flawless. (but I hated the geometry.)
    Thorn in your Sidewall
    Vassago Jabberwocky
    WillWorkForTrail
    Jun 2012
    I'm 230 kitted up, and push pretty hard. I haven't had any problems out of my Brownstone, but I suspect my trails at their worst are not quite what your trails are. Most steel frames seem to be more XC like in their geometry (I know that's my impression of the Juice) but there are a few AM frames floating around out there. Maybe it's time to see if you can find something along those lines? In theory, an AM hardtail should be a stronger frame than an XC one.
    meatier showers
    Dec 1999
    I don't have a Soma but since you're considering other frames that are fun & durable may I suggest you consider Kona's steel Honzo. I've enjoyed abusing mine for 4 years and it has stood up to my 225ish pounds with aplomb. I believe the Honzo is made specifically for the type of riding you do.
    =s
    disciplesofdirt.org
    May 2015
    yea I would love a steel hanzo but it's a little heavy and the titanium hanzo is out of my price range.
    I'm going to go with the spot rocker since I can get 35% off with them and I think the frame is a little lighter than the new karate monkey.
    Sucks with the Juice since I really enjoyed it while it wasn't broken.
    So far no reply from soma but I am pretty stubborn so they will have a hard time ignoring me. That plus I have my old karate monkey to ride in the meantime
    Oct 2016
    I love my spot rocker. The seat angle is STEEP. It took my a little while to get used to it, but now I am not sure if I could go back to a slack seat tube angle. The Rockers are also really long bikes, they have similar top tube lengths as other bikes, but because of the steep seat angle the reach ends up being 20-30mm longer.
    It took a while to get mine dialed in, but zero offset seat post, 60mm stem, and the chainstays set to 435mm, its perfect. By far the best climbing bike I've owned.
    May 2015
    thanks for your setup info, thats where ill start when I get a frame figured out.
    Yea I demoed a large Rocker for the first time 2 years ago in Moab at outer bike. Rode it down Captin Ahab and it's been in the back of my mind since.
    NedwannaB
    Reputation: JMac47's Avatar
    Warranty bump
    Quote Originally Posted by Singletrackd View Post
    Did SOMA eventually follow thru with a frame?
    Inquiring mind(s)....
    Wait whuuut, who did he tell you that!?!?....
    Reputation: seat_boy's Avatar
    Looks like the new Juice (the light blue one) has those windows on the dropouts filled in. So at least they learned a lesson somewhere.
    NedwannaB
    Quote Originally Posted by seat_boy View Post
    Yeah that's the one I'm contemplating. Just curious on their CS response on this OP.
    May 2015
    they already did that on the second brownstone they sent me and you can see it in the 3rd picture..didnt add any strength to the area
    oh and customer service it horrible....i sent my frame out 4 weeks ago and am still waiting on the new one to come. they now will only deal with the bike shop that sold it to you which is a pain and if you order it online that means you have to mail it to the shop so they can send it to soma. On top of that they don't pay for shipping in either direction(they billed my PayPal account)
    not a pleasurable experience but there is a new frame on the way. but it's a pain to keep having to pay a shop to prep the frame and for shipping
    Nov 2017
    Do you know anyone who can weld halfway decent? They could put a gusset on top of the dropout and seat tubes, probably fix your problem.
    May 2014
    Call them *+1 (650) 871-8870
    Donít rely on an email when all you got to do is pick up the phone 😀 I have called them many times with questions on my b side and Wolvie and they never dodged me. One time took my number and called me back within 5 minutes.
    They have always been helpful to me.
    Jan 2018
    The pictures on the somafab.com website show close-ups of the dropouts. The new model definitely does have more material around the dopouts.
    Brown == 2014-2016 model
    Pale blue == 2017 model.
  1. New Juice vs. old Juice- Is it still the juiciest?
    By archtop44 in forum 29er Bikes
    Last Post: 05-21-2015, 04:00 PM
  2. Please post your Soma Juice
    By JC2niner in forum 29er Bikes
    Last Post: 01-30-2011, 02:44 PM
  3. SOMA Juice Build ??'s
    By MTSHANK in forum 29er Bikes
    Last Post: 01-25-2011, 02:57 AM
  4. Soma Juice vs Stumpjumper 29er EVO
    By WMBigs in forum 29er Bikes
    Last Post: 01-11-2011, 10:13 PM
  5. 2005 SOMA Juice
    Last Post: 01-03-2011, 10:29 AM
Members who have read this thread: 100
