Results 1 to 19 of 19
    Bollocks
    Reputation: Surly Gentleman's Avatar
    Aug 2010
    smaller rear or larger front...
    so when it comes time to change the gearing, prices aside, is it better/easier to change to a smaller rear cog or a larger chainring. does it really make any difference?
    also, obviously the chain will need to be shortened/lengthened depending on which way i go. assuming i might want to change back to the original gearing, can i add/subtract links or should i get a chain for each?
    thanks.
    Reputation: monzie's Avatar
    Changing the chain ring is the way to go. Generally, subtracting one tooth from the cog will yield the same amount of change in gearing as adding three to the front; so you get more incremental change from changing out the chain ring. Also, it's cheaper.
    You can add/ remove links with a chain tool. It's not hard at all, just don't push the pin all the way out of the chain. It's a weird process to try and describe in words without a visual. I'm sure there is video instruction on the internet somewhere though. As for a tool, get something along the lines of the Park Tool Master Chain Tool or the Pedros Pro Chain Tool.
    Bollocks
    Aug 2010
    Quote Originally Posted by monzie
    great advice, thanks.
    i have the tools needed, etc and have worked on chains before so it looks like i'm good to go
    Reputation: Just1Gear's Avatar
    Jan 2011
    I've normally changed out the rear cog, to me it's easier than removing the crank arm and 5 crank bolts and reassembling. Also, the cogs I've purchased were most always less expensive than a chainring....
    Bollocks
    Aug 2010
    Quote Originally Posted by Just1Gear
    thats a good point.
    Reputation: amishscum's Avatar
    Nov 2006
    Agreed. I find it much faster to swap out the rear cog. Plus, I can use the same chain length across 3 cogs (16, 17, 18), so I don't have to break the chain.
    When I'm forced to change my chainring (due to wear), I don't have to remove the crank arm. Not sure why Just1Gear has that problem. I'm also running a 5-bolt, 94bcd spider, ring in the middle position.
    "I like skinny jeans. Sometimes I wear them to the mall to get an Orange Julius." -Chim Chim
    Bollocks
    Aug 2010
    Quote Originally Posted by amishscum
    are you using a tensioner that allows you to use the same chain?
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    only on your 48/16 track bike
    Nov 2006
    Quote Originally Posted by carlos9
    Nope. Sliding dropouts. Actually, mine are called "rocker" dropouts, but it's the same concept.
    Bollocks
    Aug 2010
    ahhh. yeah, unfortunately i have vertical dropouts and got lucky off the bat with finding the magic chain length for my first gearing set up. i'd really like to avoid a tensioner if possible, which was why i mentioned shortening and lengthening the chain...
    nothing to see here
    Reputation: Stevob's Avatar
    What is your current gearing?
    I see hills.
    I want to climb them.
    Bollocks
    Aug 2010
    Quote Originally Posted by Stevob
    32x20
    nothing to see here
    32x18 might work and depends on how tight your current chain is, but you'd need to take a full link out and add a half link.
    Do you know your chainstay length? If not what frame/year is it?
    I see hills.
    I have always swapped out rear cogs to figure out my gearing. I bought a pack of super cheap sprockets of different sizes and I also took apart an old cassette that had indivdual cogs rivited together. Once I found the gearing I liked I bought a nice single speed cog. It was the cheapest and easiest way to find the right gearing.
    But I used a chain tensioner. I was at a magic gear but didn't trust it as if the chain stretched I would need a tensioner. And even with half links I think if you had a magic gear and tried to go down one or up one tooth you would loose the magic gear. One chain link is about 1" and a half of chain is 1/2". So if your gear change isn't exactly in 1/2" (half link) or 1" if using full links then you will loose your magic gear.
    Bollocks
    Aug 2010
    the chain is perfect right now, probably less than 1/4 inch of play. i already have a half link in there, so i guess i could just take it out?
    its a '93 marin bear valley. no idea on the chainstay length...
    is there a "formula" where 1 tooth [either front or rear] = a certain change in chain length?
    nothing to see here
    It's a little bit of a grey area, but for each increment in teeth, the chainlength changes by approximately 1/4 of a link (remember that one full link = 1"), and that is then split in half again to determine chainstay length. So one tooth = approximately 1/8" alteration to chainstay length.
    So if you increase the overall tooth count front and rear by 4 teeth, you'll need to add one full link. But there's a bit more complex geometry to consider than just that.
    Have a play around with this link.
    Google was not my friend in finding out the chainstay length on your frame.
    Someone please correct me if I'm wrong.
    I see hills.
    Bollocks
    Aug 2010
    thats all helpful info, thanks again. i couldn't find the chainstay length either. i'll probably end up just messing around with it and see what happens.
    Keep in mind when switching things around that smaller cogs will wear faster and increase the possibility of chain skippage. However, this would more likely occur when you get into cogs with less than 16 teeth...uncommon in mtbing I suppose.
    Jan 2011
    Hmmm, I guess your right, I don't HAVE to remove the crank arm.....I guess the times I've changed the chainring I've already had the arm off for something else anyway.
