Results 1 to 24 of 24
    May 2010
    Small cog on SIR9... any luck? (chainslap)
    Hey guys,
    I have been running 32/15 for a while and recently switched from a monocog to a sir9. I have been getting chain slap on the underside of the chainstay when climbing and going over bumps. Now, it is pretty much a new chain still (100mi) and I keep tightening it after every ride so I am hoping once most of the stretch goes away this will stop. However, I don't want to run it so tight the cranks bind and I have seen another post on mtbr.com that seems to indicate I should run at least a 17t.
    I don't want to go up unless I have to... but I don't see the sense in damaging my frame in the meantime. Has anyone had any luck?
    P.S. I just centered the chainring a bit so maybe that will help me run it tighter without binding. I also noticed my surly cog on my stans hub has some play to it if I squeeze the chain... does that sound normal?
    Just run a chainstay protector if you're worried. Chain slap isn't going to cause any issues, except paint chips.
    Reputation: rob1035's Avatar
    what about a larger front chainring and cog combo? 35:17 or something?
    Quote Originally Posted by driver145 View Post
    Can you elaborate? Is the cog loose on the hub?
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Quote Originally Posted by rob1035 View Post
    I am running 36x15 on a 2010 SIR and there's no chain slappin goin on... didn't happen when I was running 34x15 either.
    May 2010
    In regards to the cog play on the hub body, if I squeeze the chain tight I can see the cog move slightly. Maybe 1 mm. But it does make the chain slacker...
    Also, I think the chain is mostly hitting the braze-on which I could care less about. It's also hitting the frame slightly though which I don't want rusting. I was also wondering if hitting the braze on could damage the chain over time but I guess it's pretty slack when it hits so maybe not...
    Oct 2012
    I've noticed my surly cog also shifts a bit on the freehub body. It causes a slackening in the chainline and tightening elsewhere. Usually, I find that I get one really tight spot and one loose spot from it. I thought I was going crazy as my chain tension will change a lot if I'm mashing hard, but it seems like this is the issue
    I haven't figured out how to stop it but I think it's caused by the splines being slightly different size than those on the hub.
    Certainly is annoying.
    Sounds like the Surly cog tolerance is off slight from your freehub. FWIW, I run Endless cogs, and on most hubs they are perfectly fitted, and some hubs (i9 for sure), they are "tight" requiring a little file work.
    Oct 2012
    I've been kicking myself a bit for not getting an endless cog for that very reason, but I was a bit concerned about how the aluminum cog would wear compared to steel. Perhaps the next one, I'll try endless.
    May 2010
    Well thanks for the replies. I will keep playing with what I got for now.
    I would like to try another cog if this doesn't work but then again I might just be throwing money at an idea that won't pan out.
    Gotta pay to play
    Reputation: michaelscott's Avatar
    Got any pics of your chain?
    May 2010
    Michaelscott: Not at the moment (on my phone).
    Also after the last ride it is now slack enough I need to remove a link and start over with the EBB (although on the monocog I would ride it like this or even much looser w/o concern) BTW I ran the EBB through its lower rather than upper range this whole time.
    May 2010
    This is how it looks after my ride today (this is the loosest position in the pedal stroke). It was slapping today too. The EBB is maxed out (I can of course remove a link though and start over). Honestly though, I don't even like how tight it is. I can hear and feel the chain straining through part of the pedal stroke where it is tightest. Here is the big problem though; I can put my weight on the pedal and lift the chain up to the frame even at the tightest spot in the pedal stroke... so even if I get a better cog it won't solve this problem...
    Either I need to deal with it (with or without a protector) or go bigger...
    It sounds like people who got away with a 15t were running bigger chainrings which also makes you wonder what the application was in the first place and if chainslap would have ever been an issue. It only does it when I am mashing fast uphill over bumps and the rear tire starts hopping around... Like trying to get up a sudden steep climb full of roots as quickly as possible.
    Also, I am 185-190lbs, so that might be a factor...
    Attached Thumbnails Attached Thumbnails Small cog on SIR9... any luck? (chainslap)-img_0224.2.jpg
    Maybe a new chainring is in order? Might be the picture but that one looks a little worn...
    Weird symptoms for sure...
    May 2010
    It is just dirty. I WD40'd it before I put it on this bike and it shows zero wear to my eyes. It is a surly stainless steel chainring. Also the taller than usual teeth make them look skinny.
    Edit: I just cleaned off a few teeth to take a better picture and they are showing some wear but doesn't seem that bad to me... although that is a fairly uneducated opinion.
    Attached Thumbnails Attached Thumbnails Small cog on SIR9... any luck? (chainslap)-img_0226.2.jpg
    Gotta pay to play
    That is strange dude. The chain looks plenty taunt. You only use the EBB to tension correct? Vertical dropouts?
    May 2010
    So here is a (crappy) picture with me mashing on one of the pedals with brakes on. If you compare this to the other picture I posted the distance to the braze on has practically doubled... so if I hit a bump at the same time it makes sense the chain will come up and hit...
    I am tempted to knock off the braze-on and just go over it with touch up paint and then put a clear chainstay protector over the whole thing... will still be annoying though. A quiet ride is one of the perks of singlespeeding...
    Attached Thumbnails Attached Thumbnails Small cog on SIR9... any luck? (chainslap)-photo-1-.jpg
    I really think you'll be better off with a larger cog and chainring combo.
    However, that tension issue is really confounding....
    Gotta pay to play
    It looks like chain stay curves over the top of the dropout area. Or maybe it is just the angle of the picture.
    Is this where the contact is happening?
    From this angle it also looks like your chain has some slack to it.
    Like Rob and others have said- probably just need to run a larger cog
    Damn Fool
    Re: Small cog on SIR9... any luck? (chainslap)
    My guess is that frame flex is the culprit and the solution is a bigger cog and chainring.
    I get a similar change in chain tension on the bottom part of the chain when I stand and crank on the pedals.
    Fwiw, I've heard a few bigger guys around here describe their SIR 9s as "noodly" . Not that it means much, but your issue could be an unholy combination of small gearing, a flexy-er frame, and monster legs....
    Sent from my DROID RAZR HD using Tapatalk 2
    It's not about being better than others, it's about getting the best out of myself.
    Apr 2013
    I agree it can only be frame flex and larger cog/chain ring is really sort of a band-aid. I'd assume with that much frame flex there is a good chance that when it flexes enough and you hit a bump while mashing one of these days you're going to drop a chain...
    It may be worth contacting Niner about this. I have seen frames over the years that somehow skipped the heat tempering phase of the manufacturing process.
    Next alternative (not what you want to hear) would be to find another frame that is stiffer and won't have the same issues.
    Gotta pay to play
    Quote Originally Posted by rideorange525 View Post
    Jones baby!
    Reputation: J.B. Weld's Avatar
    All frames flex, and the right amount of flex is a good thing- especially on a ridged SS. I think you just need to go with a bigger ring/cog combo and everything will be peachy.
    Until you get this issue resolved I would just wrap something around the chainstay and set the chain at the correct tension and live with it. Running a chain that tight will ruin your hub and bb bearings, and also sap power.
    May 2010
    Thanks for all the help guys.
    I am happy with the amount of flex the frame has. It is a little more flexy than the monocog but in a good way. I can make it 33/16 with parts I already have (by stealing them from my other bikes). I will try that and then I will know if I can get away with 34/16 or if I have to go with 36.
    May 2010
    I was lazy and tried 32/16 instead of 33/16. It is much better but still hits in a few sections of my local trail (I would say its hitting about 20% of what it was before). I cannot decide what I want to do yet... so I guess I will try 33/16 now.
  1. Replies: 0
    Last Post: 06-20-2013, 09:09 AM
  2. Podium Chainstay chainslap --advice needed
    By rdhfreethought in forum Knolly
    Last Post: 06-11-2013, 11:21 AM
  3. Chainslap and chain damage question
    By MTBCanuck in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2012, 02:13 PM
  4. Chainslap help needed
    By BritOnTour in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-25-2011, 11:39 AM
  5. Worst luck or best luck with my Yeti ASR?
    By tonyinatlanta in forum Yeti
    Last Post: 07-19-2011, 01:05 PM
