Results 1 to 8 of 8
    Sizing question for Jabberwocky (sp?)
    I am looking to build up a Jabberwocky, and am wondering what size frame I should order. Based on Vassago's website, a medium is the one for me, but I am right at the top of a small as well. I have heard that when you are between frame sizes, you should go small and adjust with stem/bar/post, which makes perfect sense. I am 5'10" with a 29" inseam. What do Jabberwocky owners recommend?
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    I'm 5'9" with a 31 inseam. I ordered a small--16 inch. Haven't had a chance to ride it yet, but I have it mocked up and the frame feels the right size.
    I'm a hair taller than you with 32.5" inseam and got the medium. If I were any shorter, I'd be better off on a small. Also, I prefer a slightly larger frame with a short stem. Personal preference, though.
    i'm with pnut. this frame handles better to me with with a short stem and longer top tube
    openwound
    Reputation: voodoochild's Avatar
    I am 6' with a 32" inseam. On a large. I also prefer the longer top-tube/short stem set-up notion. Stand-over height is not an issue for me on this frame.
    Reputation: FlynG's Avatar
    5'9" 31" inseam.
    Small Jabber with a straight seat post, Ragley bars with a 90cm stem.
    Works good.
    Flyn G
    Thanks everyone for the replies.
    5'10" with 30" inseam. Medium is perfect for me. I've run between a 90mm and 130mm stem and both feel good.
