Results 1 to 10 of 10
    Fight the Kakistocracy!
    Reputation: veelz's Avatar
    New question here. Size of Lock-On clamp bolts
    I was wondering if anyone knew the size of the bolts in the ODI Lock-On grips. It seems that I have lost a couple of the ones that I had. Little buggers. Are they something that I can buy at the LHS (H= hardware)? Anyone else have this problem, or is it only me that needs to be buckled into the short bus?
    veelz
    veelz
    Gravity, not just a good idea, it's a law.
    The only one consistently and constantly applied, no exceptions.
    rejected
    Reputation: gspot's Avatar
    Good job! darned little buggers...
    go to your LBS and onto the LHS, and ask if they have any lying around. (LBS)
    when you go to the LHS, bring the lock on bit dealie with you, and just try a couple of bolts in the lock ons until you find the one you want. easy peasey.
    if you can't find a replacement, buy some new lock ons and/or grips.
    done and done.
    Idea! been there, done that
    Quote Originally Posted by gspot
    done and done.
    I already did that, lost one of the bolts in the process. I was hoping someone knew the size so I could try and find them online? The LHS didn't even have something that I could size them with.
    Scott
    veelz
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    Quote Originally Posted by veelz
    Scott
    The bolts are like M1.5 or something WAY WEIRD..... I called ODI and they sent me a baggie of like 5 extras for free - call them and I'm sure they will hook you up. If not drop me an email and I'll get you a couple.
    Later
    FF
    "If I'm leading, I'm bleeding."
    FF you rock
    Quote Originally Posted by Fast Freddy
    Later
    FF
    Freddy-
    if they are a little stingy on phone, I will email you, I could just get another top cap, eh!
    thanks,
    Scott
    veelz
    The Top Cap Guy
    Scott
    Check your mail!
    FF
    Vmc
    Vmc is offline
    x::x::x::x
    They're M3.5....
    veelz
    You can find them at a hobby shop - the type that sells radio controlled cars/boats/airplanes....
    thanks, I hadn't thought of that
    Quote Originally Posted by Vmc
    VMC, thanks for the info, I hadn't thought of a place like that for those parts, but now it makes perfectly good sense. I have the fortune of having Fast "topcap" Freddy helping me out this time, but will keep the info in my skull for future reference.
    veelz
    veelz
    Reputation: the Inbred's Avatar
    veelz
    i sent them an e-mail and never got a response...luckily someone sponsored by them hooked me up.
    thanks, I got some from Fast Freddy
    Quote Originally Posted by the Inbred
    As Always, Fast Freddy rocks!!
    veelz
  1. Need Help With Kona Dawg Size Selection
    By Darren in forum Kona
    Last Post: 04-17-2010, 07:24 PM
  2. Titanium Bolts
    By Phantomtracer in forum Weight Weenies
    Last Post: 03-04-2005, 01:55 PM
  3. Torque specs alloy bolts and lightening USE shim
    By dcm311 in forum Weight Weenies
    Last Post: 01-15-2004, 04:21 PM
  4. NEVER again loose rotor bolts
    By G-reg in forum General Discussion
    Last Post: 01-14-2004, 05:03 PM
  5. Quick ?- Clamp size for F. Der. on 5 Spot????
    By jncarpenter in forum Turner
    Last Post: 01-03-2004, 11:53 AM
