Results 1 to 6 of 6
    Jun 2013
    SISS Bianchi , advice needed please :)
    Hay does anyone know if there is a converter bracket or something so i can run this bianchi siss geared? Ive always been a DH rider then xcountry/allmountain so i dont really know much about bikes like this. now ive moved to the US and a big city and only have tame single tracks around me. found this bike super cheap and want to mess around with it little, any advice would be awsm.
    Cheers, TysonSISS Bianchi , advice needed please :)-photo-19-.jpg
    Reputation: blackgriffen_1's Avatar
    May 2010
    Yes indeed!
    I fully endorse using this Problem Solvers chain tug, or the similar DMR product:
    Amazon.com: Problem Solvers Chain Tensioner with Derailleur Hanger: Sports & Outdoors
    The only problem with such solutions is that they're intended for a 10x1mm solid axle to pass through them, then be bolted down when securing the wheel. Instead, you could use a Surly Tuggnut QR adapter washers
    Amazon.com: Surly Tuggnut QR adaptor washer: Sports & Outdoors
    to step down the diameter of the axle hole to the size of your quick release skewer, and then everything works!
    I used the Problem Solvers tensioner to do a geared conversion of a single speed road frame with track dropouts, but in that case I also had to stretch the dropouts to accommodate a geared wheel. In your case, a geared wheel in the dropouts and a derailleur bolted onto that chain tug will do it.
    Of note: since you don't have any cable stops or braze-ons for a rear derailleur cable/housing, you'll have to run a full housing from shifter to derailleur. While you could use two of these Problem Solvers cable stops mounted on the top tube to take out that section of housing, it's much easier to just zip tie or tape the housing along the top tube, down the drive-side seatstay, and to the derailleur.
    Also, since you will have a quick release rear wheel, I'd suggest running the wheel all the way forward in the dropouts, that way you're not relying on the clamping force of the quick release skewer to stop the left side from moving forward in the dropout (since the right side is held static by the tensioner).
    Hope this helps!
    I'm just messing with you
    Reputation: wv_bob's Avatar
    It's almost a shame to put gears on a Sexy Italian Single Speed
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Reputation: dbhammercycle's Avatar
    Quote Originally Posted by wv_bob View Post
    Agreed.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Jun 2013
    LOL... ive been thinking the same, ive been geeting grief from my bud here whos a ss guy. guess im guna just have to not be such a lazy mofo. def still want to sas it up a little
    Jun 2013
    Cheers for all the info bro, i appreciate you taking the time.
    Cheers, Tyson
    Quote Originally Posted by blackgriffen_1 View Post
    Yes indeed!
    Of note: since you don't have any cable stops or braze-ons for a rear derailleur cable/housing, you'll have to run a full housing from shifter to derailleur. While you could use two of these Problem Solvers cable stops mounted on the top tube to take out that section of housing, it's much easier to just zip tie or tape the housing along the downtube, down the drive-side seatstay, and to the derailleur.
    Hope this helps!
  1. Bianchi?
    By philip404 in forum All Mountain
    Last Post: 05-11-2013, 08:51 AM
  2. My (new to me) bianchi SOK
    By voodoochild in forum Singlespeed
    Last Post: 07-02-2011, 08:37 PM
  3. The New 2011 Bianchi SS...Only 19 lbs!!!
    By Your Bike Sucks in forum Singlespeed
    Last Post: 06-11-2011, 07:23 AM
  4. Bianchi Osprey help?
    By cutiecat6675 in forum Beginner's Corner
    Last Post: 05-11-2011, 08:14 AM
  5. How does this bianchi look? ($350)
    By mmik in forum Singlespeed
    Last Post: 02-22-2011, 03:38 PM
