Results 1 to 36 of 36
    Oct 2010
    Singlespeed Conversion Kit
    I am looking to convert to single speed. I am considering either the Surly conversion kit or the Wheels Manufacturing conversion kit. The Surly kit is approx. $15 - $20 more. Does anyone have any experience these or any other kit? Also, what some good chain tensioners out there for vertical dropouts.
    Reputation: SeaBass_'s Avatar
    Surly kit with a Surly cog is a decent set up. The spacers allow you to get your chainline perfect. Try to find your magic gear before you go strapping a tensioner on, if not, the Surly Singleator is passable. Gee, I sound like a Surly Shill, don't I????
    meatier showers
    Dec 1999
    Quote Originally Posted by SeaBass_
    Can't believe you didn't tell him to get the "search" kit.
    --sParty
    disciplesofdirt.org
    Avoid a sprung tensioner. Once you go single speed, why keep relying on a spring to keep your chain tensioned?
    This is what you want:
    http://www.jensonusa.com/store/produ...Combo+Kit.aspx
    --sParty
    I'm in a good mood today for some reason . Besides, that's the set up I used when I first got into SS.
    +1 on avoiding the sprung tensioner as well. Forget what I said about using the singleator. I remember now I wound up using a zip tie on my singleator to get adequate push-up tension and chain wrap. Then after getting sick of that set up, I took a dremel and made the magic gear work. Be very careful if you go that route though!
    Singletrack Slayer
    Reputation: DavidNeiles's Avatar
    Quote Originally Posted by bad mechanic
    True, but not if you got a FS rig like me
    Attached Thumbnails Attached Thumbnails Singlespeed Conversion Kit-sortiess.jpg
    ~~~~~~Singletrack Slayer~~~~~~~
    Mtbr Forum Sponsor - Homebrewed Components
    how about the soulcraft kit?
    Quote Originally Posted by ISuckAtRiding
    The Soulcraft tensioner is nice in theory, but is quite difficult to set up in practice. It's quick release is neat, but not worth the hassle for me. The are better tensioners available for less.
    Did I catch a niner+?
    When I needed a tensioner I used the Sette one with the rollers, in a 32x20 I could fix it into the "up" position which was ideal to wrap the chain around the rear cog. However looking back I would rather have something like the Yess tensioner at my BB vs my rear cog.
    Category Winner
    Reputation: teamdicky's Avatar
    WWW.TEAMDICKY.COM
    I get paid 3¢ every time I post on MTBR.
    Quote Originally Posted by teamdicky
    It seems like a solution in search of a problem. There are already several excellent tensioners in the $45 range, like the DMR STS or the Rennen Rollenlager (plus they're made from aluminum, not plastic). Also, rigid tensioners (not sprung) have already proven themselves and shown a spring is simply not needed. I just don't get it.
    "BONER is named after it’s designer Thomas WOOD"
    Interesting, but not for $45. As the article states:
    "spring loaded tensioners are FINE if you intend to convert your ride for the purposes of TESTING the waters of single-speed. As a long term solution…their relevance deteriorates.
    Does seem a big improvement over the Singleator. More of a "Set it and Forget It"
    If you must run a tensioner (which I would also avoid), the Rennen Rollenlager is a very good solution, you won't believe how beefy it is and how well it works. Good luck!
    2011 Cannondale Flash Carbon 2
    2010 Redline Monocog Flight
    2010 Specialized Roubaix Expert
    2011 Cannondale Jekyl Ultimate
    DMR offers a nice kit with a non spring tensioner.
    I was going to post a link but the address was to long. Just google it.
    Reputation: PoisonDartFrog's Avatar
    You mean this?
    And regarding the Boner... they came up with a simple, elegant, and inexpensive (ie plastic) solution, then completely lost their minds when they priced it at an SRP of $45, which is "less than some of the fancier tensioners on the market". So in terms of marketing and competition, they are branding themselves as an inexpensive premium tensioner, but also trying to sell simple.
    Price it at $20 and pitch it as being superior to tensioners at 2-4x the price. It's injection molded plastic, for pete's sake.
    yep, that one. I should figure out how to make insert a link like that.
    Birdman aka JMJ
    Reputation: Birdman's Avatar
    Quote Originally Posted by PoisonDartFrog
    More likely machined plastic. Pretty easy to machine, based on the geometry. I wouldn't drop a few thousand bucks to get a mold made for that part.
    Machined or molded, $20 seems about right.
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    Quote Originally Posted by Birdman
    the only components NOT manufactured domestically are the pulley wheel and (perhaps) the mounting hardware (that supplier is not finalized).
    the QR end, the shaft and the tensioner body are all manufactured in NA.
    the body is not as simple a machine job as you might expect. to make the most of the design and the specific properties of acetal, a number of the surfaces are beveled and there are a few (thickness) variations NOT visible in the photos.
    waste is another issue. when the material is CNC'd you can't simply lay-up in the most cut-efficient manner, you have to mind the grain...with a mold, this isn't an issue.
    first batches will be completed in hundreds, so it makes sense to stay with CNC, future batches could be molded. either way, when the batch quantities increase i would expect the srp of the tensioner to drop somewhat...50+% is unlikely. without shifting production to TW.
    anyone interested in exploring a partial (or complete) barter-for-mold consideration can email me directly; peter@misfitpsycles.com
    Expert of the Internet.
    BECAUSE I SAID SO
    Quote Originally Posted by nogearshere
    stuff
    So what does the Boner offer me which the Rennen or DMR doesn't?
    Misfit Psycles
    Mar 2005
    typically i would agree to disagree but i think yours seems like an opinion in search of an argument.
    'excellent' tensioners? good at best.
    1) the fixed arm requires regular adjustment to compensate for chain 'stretch'.
    2) the fixed arm does not allow for tolerances in chainring or cog diameters. riders must find and tolerate a compromise between these tight and loose spots.
    3) the fixed length and fixed angles of the arm restrict the type and application of the conversion. for example, frames with chainstays that are (low) in relation to the hanger (center) cannot be converted or it must be done in the push-down configuration.
    aluminum over 'plastic'?
    i suppose that depends on the science or engineering you are considering, either way, selling one arbitrarily over the other is no less shortsighted then providing the nod based on colour.
    i sell approximately 400 spring-type tensioners (like so) and 100 fixed-type tensioners (like this) per year. the price differential is a mere 7$ (25 vs 32).
    over the course of 5 years i have only taken back 2 spring loaded tensioners and i have only exchanged 2 fixed tensioners (for spring style). what i mean is, i think most people know what it is they are buying and they understand the limitations of any tensioner.
    i have experience converting a range of frames for a range of purposes through a range of budgets, maybe that matters, maybe not.
    we set out to design a tensioner, based on experience and feedback. we set out to offer a substantial improvement on what was available...at a reasonable price...made domestically if possible.
    by point of comparison, tensioners i consider 'excellent' (YESS for one) cost upwards of 80$.
    we attacked what we considered the two achilles heel(s) of current tensioners, FIXED ARMS and SPRINGS.
    in order to eliminate the necessity for moving parts (like springs and pulleys) we needed a material with no memory and a crazy fatigue life. aluminum (i do love it) is not appropriate for this application.
    maybe the DMR style is all you need. i'm not naive, i expect it will be ALL a few other people need too.
    but i fail to see how a product that eliminates specific failures in design, limits compromises and costs no-more is a bad thing.
    those interested can read more on the design concepts HERE and HERE.
    BECAUSE I SAID SO
    You produce frames which use sliding drop outs, which have the same issues you list above. Why not use fixed dropouts with a Boner?
    Misfit Psycles
    Mar 2005
    excellent.
    i appreciate that you did that research.
    first. chain tension is measurably more important on a converted bike then it is on a singlespeed specific frame. ss specific frames have a fixed chainline and tend to be assembled using ss specific parts while the converted frame has a chainline that is estimated by the user/installer (through spacer placement) and tend to be assembled with existing chainrings and (possibly cogs). these rings/cogs are ramped and are much more prone to jumping...higher tension resists that.
    second. the use of any tension system that requires the chain contact any surface other than the ring and cog (spring, fixed or a boner) suffers from a level of inefficiency.
    third. evolution. it takes time. would i consider a change? sure. i just don't think that is a better solution TODAY. incidentally, i DID prototype the Boner on a diSSent frame.
    BECAUSE I SAID SO
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    Quote Originally Posted by Mr Pink57
    Sette here too.
    Reputation: tmas's Avatar
    The Boner provides nearly constant chain tension (to the limits of a spring curve) throughout 360° of crank rotation, which a purely fixed tensioner such as the Rennen or DMR cannot. Also, it manages to do this without adding any extra moving parts compared to the aforementioned products.
    The Boner is not made from the same crap plastic that they make dollar store toy swords from - the material is a carefully selected engineering material that has specific properties regarding creep and fatigue life which are perfectly suited to the design - demands that dear old aluminium can't meet for this application.
    To paraphrase nogears, it is true that an SS frame, whether with sliders or an EBB, cannot compensate for out of round rings, or chain stretch. However, if you're going to add inefficiency by using a tensioner or other form of idler-type device, why not deal with another problem (chain length) while you're at it?
    Finally, a solution looking for a problem? I suppose if "good enough" is all you're looking for, then you could be right...But that argument could be made for elastomer-sprung forks, early-nineties style helmets, or 7-speed drivetrains with non-ramped or pinned cassettes/rings.
    Quote Originally Posted by tmas
    I was going to leave it, and nogearshere made good points, but this argument is just crap. If the tensioner is durable and keeps chain tension, then yeah, it really is good enough. There aren't any glaring issues with them. The same can't be said of your list.
    I don't think you "left it," when you shortened his post to quote "stuff" and then asked what improvements the Boner offers, despite his raising good points. I clearly recall riding the old things I listed, and I remember them working...the newer alternatives are a little lighter, a little smoother, and a little more stylish. If the Boner offers an improvement, however incremental, at a comparable price, then it seems a little silly to dismiss it because current systems are "good enough." I'm not saying everyone needs to throw their current setup in the garbage because this one is infinitely better, but if there is any room for improvement for a new product, I don't see why it shouldn't be taken advantage of?
    Mar 2006
    why not spring tensioners?
    Just curious why a spring tensioner is so bad? I hate having a thing there at all, but it is a soft tail that was never intended to be a single. Thanks Jefe
    Misfit Psycles
    Mar 2005
    Quote Originally Posted by wookieone
    spring tensioners have weaknesses.
    personally, i think they are a fine compromise (for the $).
    now in your specific case (soft tail)...it is a better than fine solution.
    BECAUSE I SAID SO
    Don't think this is personal, because it's not. I shortened his post to "stuff" because it's annoying when someone quotes a long post, but wanted it known I was replying to him.
    This gets into the evolutionary life of products, which is a fun topic on it own, but not really related to this. All the products you listed still had revolutionary leaps to go, before settling down to relative stability.
    that thing looks similar in principle to my tensioner i made a while back, except i had a titanium flex plate instead of plastic. What exactly are the details of your patent? Hopefully there's no infringement
    meatier showers
    Dec 1999
    You got a boner!
    ("That's what she said...")
    --sParty
    disciplesofdirt.org
    Boner, interesting product. Questions for you:
    1) How do you prevent QR, deraillure bolt, spacer, pinch bolt or whatever it comes with from gauging/stripping the plastic interface?
    2) If the plastic is that hard, wouldn't it be brittle? Have you tested in a season of winter riding that involves -20F temps with constant banging? I've gone through like 5 Cat Eye brackets in winter where trying to detach the unit snapped plastics. Plastics in cold temp don't behave nicely.
    3) Can't you make it with golden color for blingers (not me), or black for stealth? I get the boner part but white is, well, not my color. Don't tell me to paint it:-)
    Misfit Psycles
    Mar 2005
    Quote Originally Posted by hatake
    3) it is (technically) available in colours. the specific grade we specified (to answer your first two questions without actually being specific) was white*. in the event that we go with mold based production colour batches could/may be made available.
    *the natural colour of the material is white - so for prototype and initial production needs we did not want any additional factors (such as colour) influencing results.
    BECAUSE I SAID SO
    Any word on when this will become available? I am definitely interested in trying one. The theory behind it makes sense.
    You got a boner!
    --sParty
    Hey! mine came out first, so if anything, they have an Erection (that's what i call mine... sounds a bit classier. I mean, come on..... we're all adults here.)
    meatier showers
    Dec 1999
    LOL! Erection is a great name for a tensioner! Should prove popular with the wimmins.
    --sParty
    disciplesofdirt.org
