Results 1 to 9 of 9
    Reputation: Casual Observer's Avatar
    Singleator, up or down?
    Just put together my new SS (new frame), and notice I get a lot of frame slap from the Singelator (in addition to losing the chain bumpy stuff, but I think that is caused by a too lose chain). I have it set up so it pushes the chain downward? Should I change the setup so it pushes upward?
    ST (a SS newbie)
    semi-evolved simian
    Reputation: Mine'sAPint's Avatar
    Quote Originally Posted by skinny-tire
    ST (a SS newbie)
    Up is preferable since you get more chain wrap on the rear cog, but...
    You shouldn't be getting frame slap (you mean the chain slapping on the frame right ?) with the Singleator. Did you use a cone wrench to put loads of tension on the chain ? That thing should barely move.
    Actually, it's the singelator that is slapping the frame. I never had a problem on the old rig. However, I'm wondering if I tighten the chain some if it would fix the problem (I think it's a link too long). I may also change the set up so it's going up.
    Ebo
    Ebo is offline
    Up works better....
    ST (a SS newbie)
    Grab a 18mm open end wrech and set the spring tension. Make sure you don't over tension it though, because that could cause the spring to pop out of the set hole and then you lose all tension. If this happens, just take it back apart and bend the spring back straight where it pokes into the set hole. As far as chain length goes, certainly make sure its as short as it can be. Otherwise the Singleator will be pushing the chain up too far. I used a Spicer half-link to solve this. Good luck.
    semi-evolved simian
    It shouldn't be loose enough to slap the frame. You gotta put a bunch of tension in the spring before you tighten the mounting bolt right down. Grab an 18mm cone wrench and use it on this part of the singleator:
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    Push up with zip tie as back up
    Is what I used to do.
    down should work if your chain is short enough.
    Ah, that did the trick. Thanks.
    Reputation: ernesto_from_Wisconsin's Avatar
    why not...
    Quote Originally Posted by Mine'sAPint
    ...save some money and get ENO? It's more cost effective, it won't brake, and it's hassle free.
    Reputation: nilepoc's Avatar
    Quote Originally Posted by ernesto_from_Wisconsin
    You mean you can't stop with it. I knew there was something wrong with the ENO hub. It was just to perfect. Damn.
