Will Ride For Beer!
Single Speed rear tire. What do you run, and why?
I have converted my Kona King Kahuna to a single speed. Right now I have a Maxxis Ignitor on the rear. It works but loses traction in the steep loose stuff. I also tried an old Botrager 29-2 with even worse results. What do you use< and why?
Basura Blanca
I'm running a Maxxis Ikon, after slicing the sidewall on my (non-EXO) Ignitor during a ride down in Tucson. I'd read that the Ikon, offered in the EXO sidewall like the Ignitor, was essentially a lighter, faster-rolling replacement for the Ignitor. I've been pleased w/ how well the sidewalls have held up to the rocks, and it's got decent volume and rolling resistance for a rear tire. Hooks up well, although the short chainstays on my bike help with that. My only gripe is that it's wearing faster than I expected. I may look at a Geax offering next time.
- Joe
We rejoice in our suffering, knowing that suffering produces endurance, and endurance produces character.
Too many to list.
Really like the Ikon Exo.
Am also a huge fan of the Nano.
Geax AKA was pretty good, but wore out waaaayyy too fast.
I prefer low profile knobbies for here in So. Cal.
I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
Bucky the Cat
I just installed an Ikon on the rear of mine, Nevegal on the front. Haven't tried the combo yet but should work well for my area.
Kona Big Unit SS
Kona Private Jake SSCX
DiamondBack Release 3
Dive Bomber
I use ardent, better traction much much faster and lighter than nevegal.
Good grip for steep climb, so far so good never slip even on wet rocks or concrete.
On the front or rear? Main reason I went with the Nevegal up front on my bike is that I have two new ones just hanging in the shed. I hate to see them go to waste. That, and even though they are slow, they sure do hook up like nobody's business and here with loads of mud, rocks, and roots, they are proven performers. Once I need to buy new fronts, I'll probably go with something that is a faster tire though.
Kona Big Unit SS
Damn Fool
Depends.... In the summer, I like either a rocket Ron or a Conti race king. Once the weather turns wet ill turn to something a bit more beefy. I've got a WTB prowler waiting on the wall for fall time. Previously I had a WTB moto captor on the back end for when things got nasty
It's not about being better than others, it's about getting the best out of myself.
Kenda Slant6 currently. Rolls much better than the Ignitor I had on there, a bit more volume too.
Dive Bomber
Nevegal on rear is what I don't like but for front works fine and doesn't even feel slowing me down, It's still a great tire for my uphill training - I use ardent for race and it's a blast the difference is very noticeable.
I am not doing good on any off-road even with the best off-road tire out there, it's just I don't have skills for it.
Prefer big volume tires, and for durability the Ardent 2.4 EXO have been the best. Heavy, yes, but fast and durable. Been tearing up sidewalls of the lighter tires, Saguaro, Ra-Ra, Race King, and am now curious to try the Ikon EXO.
Wondering if the Ikon is a high volume 2.2 like the Saguaro & Race King. Any thoughts here?
Anyone tried a 29er Racing Ralph 2.25 on the rear set up tubeless?
I'm running Specy Fast Track TL Ready. They're good for geared bikes but when I stand up and mash, it looses grip quickly.
Heavy WTB Weirwolf UST that I got off chainlove for <20 bucks. Traction is good and it is doing tubeless with negligble air loss on a Stans rim with two scoops of sealant.
I prefer big volume tires too but this 2.1 has done better than expected and has been reliable.
Find the Ikon to run a little on te small side.
Mounted to a Creat and an Arch....they seem a bit narrow.
Bucky the Cat
I try and use whatever I can find on sale. Our local trails destroy tires!
conti x-king protect 2.2 front (670gr) & maxxis crossmark ust 2.1 rear (850gr) - both tubeless.
Will be trying a x-king protect on the rear soon.
I run the Ignitor front and rear - tubeless - best traction I have found on our dry, loose trails in the Canadian Rockies. Hubby runs the Ikon but they are not as aggressive so I would suspect you will not get better traction with them. I have run the Racing Ralphs tubeless as well and like them - faster than the Ignitor, but not as much traction.
Yes, mounted on a Flow. It's not very big volume so I ran it @ 32 psi, on trails has good grip, and is r-e-a-l-l-y fast. Notice that as a rear, the Ra-Ra's wear out quickly.
Thanks, mtbikej for the answer re: Ikon volume/size.
Hans Dampf 2.35 is a biggun, calipers say it's more like 2.4 run tubeless on a Stan's Crest. Heavy at 920 g (my scale), he likes his strudel, but no complaints on climbing traction here. My Unit came stock with ignitors, they were OK I thought, but not so much now that things are super loose and dusty...
Riding and lovin it.
For the Chicago area ( clay, rocks, slick soft mud) I've been running tubeless Captain Controls 2.2f 2.0r for the last year with great results.
Conti Race King 2.2 F/R. They came on my bike when I bought it. They work so I haven't bothered to change them.
This. On my WTB Dual Duty they seem taller than they are wide. Ok for volume, but, nowhere near my 2.4 Ardent. I think i measured the tread around 54mm. I do like the weight, grip, and roll the Ikon delivers. Just not as much as the Ardent's roll, grip, and volume. My Ardent tread width is 60mm. I run them in the front and just bought a carbon fork to offset the tire weight because i like the Ardent that much for SoCal.
OPer, if you're not hooking up with your Ignitor in the back, you will need to look into big knobs or your technique. I like faster rolling in the back and will accept a loss of grip for it. Although, i spin out less due to the bigger gear i climb on the SS compared to my gearie. I also power my rear wheel into the earth more on the SS while climbing and mashing to get more grip. Currently got a Racing Ralph in the rear.
I am running RaRa's on my rigid ss.
Fast rolling and light.
Front 2.4, rear 2.25. Tubeless, of course.
They work well for me here in Westchester County, NY...
SPP
2.3 WTB ExiWolf Race, Gorilla tubeless at 28PSI. It's what I have available...
Fairly fast rolling and good traction.
I like the crossmark 2.1 as a rear tire except for its sidewall tearing tendencies. Three people, including myself, have gashed crossmarks, non-ust.
Right now on my light wheelset I am experimenting with a conti speed king 2.3 as a rear tire and so far so good.
On my heavy wheels I have been running CST PRO caballero 2.4's for years. At least 5-6 years and I am stocked up to keep running them. I don't know why I enjoy that tire so much.
I have run the Crossmark as well and liked it ... definitely gotta run it tubeless with the right pressure and not so good if it's muddy.
SPP
Is that Bill rated?
Rear tire? I don't know as I ever want for knobby style climbing traction, but still want a little knob for directional stability and definitely soft rubber for our wet roots and rocks. My top tire so far has been the Python NG 2.3 MRC Medium, Sticky, fast, and just enough edging knobs to keep me pointed. Running low on my stock and it seems to be hard to find now. Sigh.
veinte nueve pulgadas
Another vote for the Ikon. If has enough bite, good rolling resistance, and excellent durability. I ripped through a sidewall in the rockiest of rocky terrain (shouldn't have had an Ikon there), but in general, it has been a great tire for me.
I just bought 2 RR TL 2.25 and will hopefully try them soon; I'll let everyone know how they work. My biggest issue is breaking traction when mashing uphill in loose over hardpack. I've been very happy with the RR on my FS bike. My SS has Specy Fast Traks 2.0, I wouldn't reccomend them on a SS, just to narrow.
Is there a Tubless Ready version of the Ikon?
A Gentleman and a MTBR'
I currently run a 2.3 Kenda Small Block 8 in the rear, which has been pretty underwhelming so far.
Powered by Pulvoron
Kenda Karma rear and Nevavel up front. I really think you have to just sense it, especially single speed. Every pedal stroke on a climb I can either hammer or let off on the crank pressure for the rear tire to catch.
FilipinoMafia - Ohio Chapter
Bronson 2.2 on the rear - replaced an Ardent 2.25. Seems to stay hooked up on the loose-over-hard of my local trails. Ardent 2.4 up front. Bike is a Kona Big Unit, which is essentially same frame as KK from original post.
ardent 2.4. why because i bought 2
Guerrilla Gravity BAMF
Smash
Mountain King 29x2.2 for now. Decent grip, but tiny volume. About to throw on a Geax Gato 2.3, should be nice a big to match the Ardent 2.4 up front, except the Geax was $32.
I replaced the Ikon 2.2 with a Spec Captains 2.2 not too long ago. Been very satisfied ever since. I put a good couple hundred miles on the Ikon, great tire, but the traction especially on loose/ small rocks tech sections uphill (especially dry weather) is not my cup of tea.
That said, I'm selling the Ikon 29x2.2 still in great shape. PM me if interested.
Run Racing Ralph 2.4 on the rear, does wear a little fast but has hooked up fantastic and put me on the top step of the podium 6 times this year.
Too many to list.
I noticed the same with the aka, so I went with the Saguaro, its a bit heavier but the tire lasted over a year of ridding and the more aggressive tread helps with standing on hills.
Maxxis Crossmark UST. I don't ride my SS when it's really muddy and the Crossmark does well in all the conditions I ride. I wanted a tire that was as efficient as possible and had good traction.
That's what I was running and it was just barely ok. I went to a Geax AKA and for the first time I knew what the word "traction" meant. I did like the weight and speed however.
IME, worst to best
ardent 2.25 (good front tire)
rampage (good front tire)
aspen (good for nothing)
ignitor (never great, never bad)
nano (didn't feel faster than a crossmark and less traction)
exiwolf LT 2.3 (if you need the volume)
crossmark (my old reliable)
Ikon EXO (king)
2017 Diamondback Haanjo
2016 Pivot 429T
2011 Kona Unit
Front Minion 2.35 / Rear SB8 2.10
I'm not much of a climber but the SB8 is very sensitive to air pressure. It's grip is OKish on where I ride (roots/rocks/dirt), but wheel spins on steep loose gravels with rocks when I stand and mash. Tried the 2.35 Minion (ST) for the rear and give good grip, but with my tiny engine, I ended up pushing the bike more than I would accept. LOL
On my previous FS gearies, I find that the Xmark is pretty decent, also sensitive to air pressure though.
 Originally Posted by Ryder1
Ikon EXO (king)
Love them.
I know most folks hated the Bonty XDX, but I always thought that if they could have improved the tread wear, it would have been a very nice tire. Good volume, sidewalls were tough and they latched onto the rim like none other that I had tried (at the time). I raced the hell out of the XDX in SS enduro on front and back. Obviously not great up front, but I was all about the efficiency. I also now have a lot of well worn XDXs in the garage that serve are gravel road tires.
The Ikon is my new go-to tire. Good tread wear. Good enough bite without major sacrifice in efficiency. Not a terribly cheap tire, but sub $60 @ Tree Fort is good enough, given how long they last.
Yeah. Kenda Small Blok 8 was sort of a tire of choice around here, in West Michigan. I'm not really sure why. I was also underwhelmed with them.
I pretty much go for whatever. I only change tires once a year. Hard to really have much opinion on it!
I've been running schwalbe nobby nics front and rear. Work well for new England. Great traction, low Illinois resistance, but I'm finding they wear out too fast.
noob
i have RoRos because those are the spare tires i had in the garage
2007 Fisher Rig
2011 Trek Paragon
2013 Trek Madone 2.1
I found the RaRa as a rear is pretty good...Grips well, rolls fast. With a snakeskin sidewall, easy to setup tubeless. Unfortunately like pretty much all Schwalbe tires, it doesn't last all that long and it's not cheap. The RoRo is an awesome lightweight tire, but the sidewalls are so thin they should only be on demo bikes...
If weight isn't a concern (or speed)...The nevegal is pretty damn hard to beat traction/durability/pricewise.
If you don't buy GEAX GATO TNT 2.35, you are blowing it!
Use Slime Pro, not that other guys stuff! One thing I am really realizing in the last year is that in dry weather, the rider has way more to do with the success of a tire than you would think. Every tire I try is my new favorite tire! I really like alot of them. Ignitor 2.1, Nevegal 2.35, Rampage, Gato 2.35, Mezcal 2.35(26 inch summer tire), Conti Mt King 2.4. Just rode my girlfriends 1986 Bianchi w/ Velociraptors! they worked great! Oh, I loved the Hutchinson Toro 29 x 2.3. The Python, not so much.
Karma-Rampage
I run the Karma 1.9 in the rear and the Rampage 2.3 upfront. Just a nice combination of bite and low rolling resistance. If I did more nasty descents, I would have to beef up the back a little more.
+1 for Ignitor on the rear but with a tube. Ikon on the front works well for me. 29er through and through for a single speed
Ikon EXO 2.2 (+'s = fast/light/grippy) (-'s = volume/durability at lower pressures)
Saguaro TNT 2.2 (+'s huge volume/rolls fast/SUPER durable at low pressures/excellent wear) (-'s = A real ***** to mount on my rims/on the heavy side)
Used to have 2.3 Exi's front and rear, but when I got my Arches, I put a 2.4 X King up front and a Race King in the rear. The Race King definitely rolls really fast (I use them on my Fargo that I commute on as well as mtb on since they are so fast). There are times when I could use more grip on climbs, but usually when its deep fine powder or kitty litter grains (I'm in southern california). However, I can usually make it through those sections if I weight the rear a little more then normal. I love the huge (tall, not wide) volume of the race kings on the rear as I can get a little more absorbance out of them when I run them around 25 (tubeless, and I'm a lumbering buffalo so I can't go to low). So I guess long story short, Race King is a great rear most of the time, but I am curious about a X King in the rear as that might give a little more bite and they aren't that much slower on dirt. Also, I have found the regular race king to rear pretty well so far especially considering the sandstone and other rocks and pavement my rides usually include.
Im rollin wayyyy old skool with the Dart / Smoke combo 2.1. Nothing like having a paddle tire on the back!
I ride these year round and here in central NC the winter gets pretty loamy and sticky clay mud that like to pack into tires. I hope to eventually find something on a deal since my SS is my "budget" ride and Id like to add some volume up front for some cush. Maybe some Slant6 combo with something else to ride in the dry months??
ACCESS Stealth 3.0 carbon 29'er
GT-R Pro
Surly 1x1
Surly Disc Trucker
I used to run Ardent on the front and Crossmark on the rear, then moved the Ardent to a different bike and am running a 2.0 Larsen TT in the back and the 2.25 Crossmark up front.
Great combo, braking sucks on the Larsen but it rolls really fast and is more heavily armored since it's a tubeless version.
I'm running Kenda Nevegal 2.35/Small Block 8 2.35 F/R, I absolutely love this setup and it has worked phenomenally for me for the past 3 seasons on my singlespeed. My SB8 is on it's last limb, treadwise, and I'm noticing it much more now with it being dry, especially on dust and rocks. It will get replaced shortly along with another Nevegal up front. The Nevegal has decent tread, but each knob is completely rounded off and some of them are ripped up, so I might as well do rubber front and rear at one time. Plus, Kenda changed their tire logos so I want them both to match Have been running tubeless for this season and would never go back to tubes.
What PSI are you running on the SB8? Mine's just been skipping and skidding, and spinning out on climbs in the loose gravel/dust over hard dirt conditions lately. I'm tempted to try the panaracer fire XC pro I have sitting in my closet as a rear.
I run a Maxxis Ignitor, 29x2.1 usually at around 35psi, it's the tire that came with the bike, but I never felt the need to replace it, seems like a great tire.
Whats the lowest PSI I could run the Ignitor without getting into trouble, I run with tubes.
I used to run a SB8 and needed to go to the low 20s to have traction in the conditions you describe (I weigh 165).
I usually run somewhere between 25-35 psi, depending on the conditions or what trails I'm riding that day...
That's been similar to my experience; low enough for good traction starts to get a little lower than I'm comfortable with, not to mention excruciatingly low for the ride to and from the trails. When it's good dirt, the SB8 is fast, it's just finicky
Panaracer Rampage. I start with a new one in the front, and a half worn one in the back. Then get a new one for the front and switch the front to the back when the back one gets too smooth. Sometimes I'll put the rear in 'traction' mode unless it's in pretty good shape.
That works well for me with what I ride.
I tried futzing with other tires, but in the end I always go back to this.
Tubeless, 28 psi, and I'm 220 lbs.
Do they get any faster with wear? I love it up front for safety, but it seems slow for out back.
Rampages, yes they get faster. That's why I like to put the half-worn ones on the back. Still has great traction for cornering. Having two new ones on at once makes you work a little harder.
Maxxis Ignitor 2.1 29er tubeless at about 20 psi on the rear. Good year round traction in the PNW. Used the IKON during the summer last year. Not good for the loose stuff when things dry out in my experience. I need deeper knobs to dig in on the SS. Dropping the tire pressure makes a world of difference.
I ride at ludicrous speed
Bontrager fr-3's front and rear in the 29 x 2.35 flavor. Heavy but wicked fast due to the center ridge. Out here in the sagebrush and lava rocks I still haven't managed to shred a sidewall. My buddies at the lbs refer to them as tractor tires because they grip in everything from snow and mud to loose gravel and hardpack. Best all around tire I have ever ridden, just make sure you spend the extra change on the team issue, as the sidewalls seem to be stronger as they are the TLR tire.
RaRa 29x2.25 tubeless. I like it really fast, good traction in our dry rocky colorado trails. Wears a bit quick but I'm more of a performance junky over a last forever type guy.
- You may not post replies
- You may not edit your posts
Forum Rules
