Results 1 to 19 of 19
    move on up...
    Reputation: Forged1's Avatar
    Dec 2011
    Single speed gear question?
    I have seen the SS light!
    So I recently converted my EL mariachi to SS and to try it out I just put a 22 tooth sprocket on the back. The 39/22 ratio works out to be close to 32/18 around 51.4 gear inches. I could put either a 24 or 25 tooth rear cog and achieve close to the recommended 32/20 ratio a lot of people recommend but My question is, is there any real advantage to going with a smaller front chainring and smaller rear cog? TIA
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Ground clearance.
    SPP
    Rigid.
    Reputation: AlexCuse's Avatar
    Re: Single speed gear question?
    Smaller rings offer a bit of extra clearance for rocks/logs and a small amount of weight savings.
    Larger ring should wear slightly better, and a lot of people swear they feel smoother. I could see that being the case but never tried a bigger ring.
    Yeah I only carry cans cause I'm a weight weenie.
    move on up...
    Dec 2011
    Good point SPP! Thanks
    Just Ride
    Reputation: Cormac's Avatar
    I'm currently running 32/18. At some point I'm gonna go 34/18 probably when I get new cranks. I'm iffy about going bigger than 34 for ground clearance that has already been mentioned.
    SS ==> Nut up or Shut up!
    Mar 2006
    Quote Originally Posted by Cormac View Post
    You won't lose much clearance going from 32 to 34...
    39 is a different story.
    SPP
    Rigid.
    SSolo, on your left!
    Quote Originally Posted by AlexCuse View Post
    Yes, and larger ring/cogs with same ratio feels smoother to me.
    Get off the couch and ride!
    29er and 26er
    Mar 2012
    I currently run a 36x22 on 26" wheels. From time to time I have clearance problems going over logs. Every fraction of an inch helps...
    Just Ride
    Quote Originally Posted by SlowPokePete View Post
    SPP
    maybe I should look into 36/20? Though from 32 to 36 would be an obvious difference in clearance? I know 32 to 34 would be minimal.
    Jan 2011
    Quote Originally Posted by p08757 View Post
    That's what she said!
    I seriously just bash the logs with your chainring.
    Crossing Logs | Farnsworth Engineering
    I bash logs all the time and my chainring seems fine. Then again my 36 tooth chain ring is a litter wider then most others.
    The MONSTER chain! | Farnsworth Engineering
    I have also seen plenty of people clear pretty crazy high logs on lightweight XC bikes with 42 tooth outer rings and no bash gaurds. If your technique is good you don't really need to worry about much.
    move on up...
    Dec 2011
    Thanks for all the input guys, it looks like 36 tooth is the smallest 120 BCD chainring I can find. So I will wait till I wear this one out and replace it with a 36T. This current combo seems really smooth to me, besides I need to upgrade the cranks on my mukluk so I can run 1X10!
    How do you like the 32/18?
    2013 Specialized Carve SS
    Reputation: blackgriffen_1's Avatar
    May 2010
    Larger chainring cog combo will definitely be smoother, longer-wearing, heavier, and afford you less ground clearance. Also, something to consider with swinger/slider/track dropouts, the larger combo matches up to chain length differently than a smaller combo.
    It's possible that when you drop down to the 36 chainring, your matching cog might create a gear combo that, given the shortest chain possible, will also move your dropouts more forward. This matters only if you care about slamming your wheel for wheelie antics.
    I do!
    Just Ride
    Quote Originally Posted by Covi101 View Post
    It's great! Perfect for most of the trails in the area. A 34/18 would be nice for a little more speed on the flats. But I could still climb with it.
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by Forged1 View Post
    "Gear inches" aside, I wouldn't say the 39/22 is close to the 32/18, which is basically a straight 2:1 ratio(using the 2 teeth over a 26" setup). As far as a 32/20, as always gear choice is based on what you ride and ones individual fitness level. Hard to get a comparative answer unless the question is narrowed down to specific area trail/conditions.
    On the ground clearance, are you going to be riding any different trails with the SS setup than you would not normally be riding with the geared setup? Again something you would know given where you ride. And as for 120bcd, I take it that's your big ring spider dimension? Why not just run a bashring there and get a 34-36t SS specific ring with the cog you have for starters, then adjust down in teeth to where it works. Cogs are cheap.
    Wait whuuut, who did he tell you that!?!?....
    Reputation: asphaltdude's Avatar
    Quote Originally Posted by JMac47 View Post
    39/22 = 1.77272727 ratio
    32/18 = 1.77777778 ratio
    Pretty much the same.
    Ride more!
    Mar 2013
    Ddd
    Mar 2006
    Quote Originally Posted by asphaltdude View Post
    Comes out almost equal in inches, too.
    SPP
    Rigid.
    Reputation: rynoman03's Avatar
    Nov 2012
    FWIW I currently run 36/18 104 BCD. It's pretty good in the flats but any steep technical stuff I have to push my bike. I have a 32t Surly i've been itching to try lately to see if I like this gear combo any better.
    Crazy thing is I commute on the 36/18 setup to the local YMCA quite frequently. It's a pretty good gear combo. I would just like a little bit more low end sometimes.
  1. Single Speed Gear Ratio For Steep & Rocky
    By Wwaterman in forum Arizona
    Last Post: 04-05-2012, 09:50 PM
  2. 29er Frames: Single Speed & Gear Compatible
    By S.O.B. in forum Singlespeed
    Last Post: 01-24-2012, 11:00 AM
  3. single speed hub to six speed gear
    By oldphaty in forum 29er Bikes
    Last Post: 06-25-2011, 01:29 PM
  4. Single Speed gear ratio recommendation?
    By tom traynor in forum 29er Bikes
    Last Post: 04-19-2011, 06:33 AM
