Results 1 to 3 of 3
    Dec 2008
    Single speed convert...
    Winter is coming and I wanted to build a bike for the snow. I needed something that can fit fat tires in the rear so I scored a Surly 1x1 frame off of craigslist!
    Build as follows:
    -18" punkin orange 1x1 frame
    -gold king headset
    -tora 302 solo air fork at 85mm
    -raceface evolved DH 175mm cranks, 36t FSA steel chainring w/ FSA bash
    -gusset single speed conversion kit, 18T rear
    -xt 6 bolt hubs w/ mavic 719 disc rims
    -160mm juicy 3's front and rear
    -60mm raceface stem w/ EA30 handlebars and Funn clamp on grips
    -wtb pure V saddle w/ no name seatpost
    -Fire FR 2.4 tires front/rear
    I did my first ride today on some local single track. I am coming off of an Iron Horse 7 point 7 that I built up, so this is a HUGE change for me. The SS is interesting, took a lap to get comfortable with how the rear end bounces off of things. It stayed planted better than I thought it would, I guess these massive tires at 25 psi R and 20 psi F really helps absorb the impact. It seems resonable for climbing, but found myself out of saddle standing on the pedals more so than a geared bike. Decending was fun w/ the low BB and rear end. Cornering was fast and solid, probably due to the massive tires at low pressure. I only had the front wash on one off camber corner due to leaves falling onto the trail, at least I didn't loose it like someone else did!
    Gearing needs to be thought out for the snow, I am thinking what I have now will be too tall for being under constant resistance w/ snow. I was thinking 36/20 would be a decent combo. If not I might have to go to a 32/18 or 32/20 for the snow. What is everyones experiance with this? The trail is fairly flat and extremly twisty through the woods of Minneapolis.
    On a side note, lap two I went ahead and started to push the bike. Wow you can get moving on these things! I found it harder to maintain momentum over the rougher stuff and had to pedal in places my FS bike would just coast right through. I really like the smoothness of the drivetrain. That chain runs really smooth with larger sprockets and less bending of the links.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    I hope you continue to enjoy that bike. Rigid SS is like finding 20 year old Shannon Tweed fluffing your pillows in a wonderbra.
    Mtbr Forum Sponsor - Homebrewed Components
    Quote Originally Posted by umarth
    the fact that Shannon Tweed is older than my mom makes me slightly disturbed that she is the first woman to come to your mind when fluffing is involved.
  1. Which bike to convert to single speed?
    By ajg2560 in forum Singlespeed
    Last Post: 09-08-2008, 10:32 AM
  2. single speed convert
    By brucexc in forum Singlespeed
    Last Post: 05-02-2007, 07:36 PM
  3. Convert saint hub to Single Speed hub
    By Doro in forum Shimano
    Last Post: 03-18-2007, 05:21 AM
  4. cheapest convert to single speed?
    By taikuodo in forum Singlespeed
    Last Post: 09-29-2006, 08:29 AM
  5. Single speed convert
    By cstem in forum Arizona
    Last Post: 04-19-2006, 09:39 AM
