Results 1 to 10 of 10
    Dec 2016
    Are single speed conversions not for stronger riders?
    I mentioned in another post that i trued to do a makeshift single speed out of my bike with the derailleur and tighten the chain as much as i could get it.
    It still wanted to skip and especially under high torque.
    Now i just hope that it wont skip when i put on the gears back on again.
    I haven't tried all the conversions yet and there might be one that works, but probably the chain will skip if it is even the slightest bit loose.
    But the bike store mechanic tested it and it worked fine for him being smaller and probably weaker than me.
    I have height, leverage and strength which turns into a lot of torque.
    Can a stronger rider use a conversion kit?.
    And if so what kinds are the best for me?.
    Mar 2014
    I used a conversion kit. Worked fine. I'm 6'3" and was close to 300lbs at the time. Just had to make sure the alignment was spot on and got the chain tension right. I used the DMR kit.
    Reputation: Timon's Avatar
    if the tensioner is snug and the chain is aligned, it shouldn't matter.
    6'5, strong...have run tensioners with little issue.
    Reputation: chuckha62's Avatar
    It's all about the chain tension and wrap around the rear cog. If you use a regular chain tensioner, pushing up on the chan (increasing cog engagement), you won't skip.
    One gear is all you need.
    wanna ride bikes?
    Oct 2013
    I'll add that if your getting skipping, and your chainline is good, are you using an old chain with a new cog? or any old component mixed with new components? It's best to use all new stuff.
    The short answer is no, it's not because your too strong.
    Rigid SS 29er
    Fat Lefty
    SS MonsterCross
    SS cyclocross
    all steel
    Cycologist
    Reputation: chazpat's Avatar
    And it doesn't have to be all that tight, it should have a little slack. Some SSers use oval rings.
    There are two types of people in this world:
    1) Those who can extrapolate from incomplete data
    Jan 2009
    the chain is not skipping because you are "too strong." it's skipping because something in the drivetrain is worn out or mis-aligned.
    Thorn in your Sidewall
    Vassago Jabberwocky
    Armature speller
    Sep 2004
    Using a single speed cog or a geared cassette?
    MTB B'dos
    Reputation: LyNx's Avatar
    As the others have said, sorry, it's not your super human strength You either have a bad chainline or worn components, or you've set it up wrong/badly or maybe trying this on an FS
    Reputation: theruns's Avatar
    Jul 2016
    If you used a single speed chainring or narrow wide chainring upfront with a single speed cog (not ramped or pinned) then you wouldn't have any problems. It's a pretty different animal than just locking down your derailleur. Just make the full conversion, you'll be glad you did!
  1. Idaho Hot Springs route - any single speed riders?
    By A1an in forum Idaho, Montana, Wyoming
    Last Post: 09-23-2016, 01:09 PM
  2. Dedicated Single Speed Frames VS. Conversions
    By Magnum Ti in forum Singlespeed
    Last Post: 12-07-2014, 07:29 PM
  3. To 29 single speed or not to 29 single speed? My first post.
    By Citizen144 in forum General Discussion
    Last Post: 07-11-2014, 08:15 PM
  4. Why is my endurance not getting stronger??
    By Rack Man in forum Beginner's Corner
    Last Post: 01-21-2012, 07:04 AM
  5. North Dallas Single Speed Riders
    By Harleytoo in forum Texas
    Last Post: 05-23-2011, 10:40 PM
Members who have read this thread: 110
