Results 1 to 7 of 7
    Shortest chain length?
    Hi folks, I need some help here - I did some searching, but didn't find much on this topic.... although I'm sure I'm not the first with this situation.
    I just built up a Kona Honzo and want to get the shortest effective chainstay length I can. i.e. I want the rear axle slammed as far forward in the sliders as possible.
    I'm currently running 33x21 (yes, I'm weak), the rear axle is in about the middle of the sliders. The ratio of a 30x19 is close to the 33x21, with smaller chainring and cog I should be able to shorten the chain, although I'm not sure how much.
    Will this get me what I'm looking for? Any downsides to changing the ring/cog - reduced chain/chainring/cog life?
    one chain loop
    Reputation: fishcreek's Avatar
    edited: lose one link and shorten the CS length by third of an inch.
    everything sucks but my vacuum cleaner.
    May 2005
    That is a perfectly reasonable gear ratio for riding in the mountains. Anyway, I run 32 x 21 on my Honzo and the sliders are very close to all the way forward. Sounds like dropping a tooth up front would hurt your ego, but I thought I'd mention it anyway.
    Jan 2011
    Use a half link to shorten the chain a small amount
    Thanks for the replies! No ego here, but I'd like to keep something close to the ratio I'm currently running, as I already spin out readily enough. These three ratio's are all very close:
    33x21=11.93 feet per crank revolution
    32x20=12.15
    30x19=11.99
    32x21=11.57
    33x20=12.53
    32x21 and 33x20 aren't far off either. I have a 20t cog, so I could give 33x20 a try without spending any money - just not sure how much shorter the chain could be by dropping a single tooth.
    Dropping teeth on both chainring and cog should allow a shorter chain, I'm just not sure how much shorter. Going 32x20 saves me the cost of a cog. Going 30x19 would require purchasing both. Additionally, my understanding is that smaller rings/cogs increases wear on the ring/cog and chain - not sure how much though.
    nothing to see here
    Reputation: Stevob's Avatar
    Your effective chainstay length changes by approximately 3mm for every tooth on the cog or chainring.
    I see hills.
    I want to climb them.
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    Quote Originally Posted by fishcreek View Post
    I think that's half an inch there, fish.
  1. Shortest steer tube length on a RIP?
    By kragu in forum Niner Bikes
    Last Post: 12-31-2012, 01:48 AM
  2. Shortest a-c rigid fork length for 29" wheel ? 410mm ?
    By phoenixbikes in forum 29er Bikes
    Last Post: 08-03-2012, 07:32 AM
  3. 2012 S-Works Epic proper chain length. (new chain)
    By EpicFSR in forum Specialized
    Last Post: 07-26-2012, 01:53 AM
  4. Chain length for 1x9 or 10
    By micky in forum All Mountain
    Last Post: 02-11-2012, 06:35 PM
  5. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
