Results 1 to 11 of 11
    Shimano Warranty
    Hi Guys, just thought I'd let you guys know, I just had some Shimano Cranks denied a warranty because I wasn't using Shimano chain rings on it. I had a new old stock M760 XT crank that I bought just under 2 years ago and had one of the chain ring tabs crack off it. It has only ever had a 32 Tooth ring on it so plenty of ground clearance. I was told by Shimano NZ that using a non - Shimano chain ring has increased the stress on the tab and caused it to crack.
    I'll be replacing the crank with a SRAM that has a replaceable spider and was wondering if anyone else had ever had an issue with Shimano tabs due to running a non Shimano ring.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    I've had the same set of M760 cranks for 6 years now. Only recently put a non-Shimano chainring on it. However, there ARE aftermarket rings that are downright incompatible. Some of the newer Shimano rings wont even work.
    What ring were you using?
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    nothing to see here
    Reputation: Stevob's Avatar
    Can't really argue with that. Bad luck.
    I see hills.
    I want to climb them.
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    lesson learned: put a shimano ring on before attempting warranty resolution.
    I used a G Ring and 2 Hope rings, all worked fine and yep, I guess lesson learnt. Fit a Shimano ring to send it away.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    No issues using Blackspire and FSA singlespeed (or DH) rings on LX and Saint cranks (with bashring).
    I recall seeing pics of 4 bolt cranks where a tab broke and chainring folded in SS use. I feel a bashring is additional insurance against this, whether I need the ring for log and rock protection or not (which I do, due to pretty crappy technique in crossing logs).
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    SSolo, on your left!
    Quote Originally Posted by Floor Tom View Post
    Wow, terrible warranty support...who'd a thunk?
    Quote Originally Posted by ElwoodT View Post
    Yes.
    Get off the couch and ride!
    Reputation: Shalom's Avatar
    Nov 2008
    Ja, same thing happened to me. But couldn't be bothered attempting a warranty. The distributor in NZ is ......difficult.
    Reputation: NZPeterG's Avatar
    ... and if we just ... Shimano New Zealand!
    Quote Originally Posted by Shalom View Post
    So true and Sad at the same time!
    If only we had good support in NZ we may stop Buying from overseas at lower prices then in NZ
    Pete
    Nov 2008
    Precisely. I do not mind a slightly higher price if the service is there to back it up.
    Reputation: Captain_America1976's Avatar
    Mar 2005
    I have a tab crack on a SLX crank. It had a Blackspire ring. Warranty was done through LBS with no issues.
  1. Replies: 11
    Last Post: 06-03-2013, 09:08 AM
  2. Replies: 37
    Last Post: 07-01-2012, 09:11 AM
  3. Shimano warranty?
    By gregmazo in forum Shimano
    Last Post: 04-12-2012, 03:44 PM
  4. Warranty coverage for Shimano shoes?
    By Joe Mama in forum Apparel and Protection
    Last Post: 01-09-2012, 12:30 PM
  5. Shimano M475 vs Shimano HB RM65 rims on Rock Shox Dart 3?
    By pingzingr in forum Wheels and Tires
    Last Post: 07-18-2011, 10:25 PM
