Results 1 to 13 of 13
    And He was Not
    Reputation: Enoch's Avatar
    S/S Road gearing
    I'm building a S/S road bike, What would be good gearing ? I ride a 40 mile loop and it's got 2000 feet of climbing. I run a 2:1 on my MTB. and I'm in decent shape. I figured I would ride it single for a while then go fixie if I like it. Need some good starting ratio's.
    paintbucket
    Reputation: wooglin's Avatar
    About 72" (e.g., 42x16) is the standard starting point for a road fix. Similar to how 2:1 is for a trail bike. Then adjust from there. I run a 45x18, which is about 69" I think, and on a trail SS with 26" wheels I run a 32x18.
    When the going gets weird its bedtime.
    Reputation: SSSasky's Avatar
    I run ...
    42:15 in a relatively flat area ... works well for me, and i can back pedal relatively comfortably (although it took a few months for my knees to get used to that kind of force)
    rejected
    Reputation: gspot's Avatar
    I run 44x16 in flat a$$ boston.
    all hail der Fuhrer Bush
    my fact differs from yours
    Quote Originally Posted by wooglin
    And I would be equally adamant that a fixed gear of around 65" is the de facto standard for road training, couple inches higher if flat terrain, couple lower if dirt roads. So let's say 63"-70". At least since the '70s when I began racing and began associating with racers who rode fixers in the winter to maintain fitness and improve their spin, it was 65". I've read similar advice re: 65" in any number of books and magazine articles. Although your analogy that 72"/road is to 52"(2:1)/trail is consistent, as I don't know anyone who rides that high a trail gear.
    45/18=67.5" with a 27" wheel; 65" with 26" wheel..
    32/18=46.2" with 26" wheel.
    Don't pay the $85 fee to ride land you own! Resist!
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    This question came up on a road site awhile ago. By far, the most common gearing that people used was 65", achieved by either 42x17 or 39x16 (on 700c wheels).
    paintbucket
    Quote Originally Posted by bulC
    I wasn't adamant, just suggesting a start point. And now that I've checked Sheldon's page a 42x16 is more like 70". And still a good starting point. I'm lower right now because I'm supposed spin not mash in the winter. All the old roadies say so. Even bulC.
    And He was Not
    24 mph
    I stuck a 44/17 on it with a tensioner.The 44 was on some MTB cranks and it was the only ones I had that were 175mm long. It seemed pretty good around the neighborhood. It spins out at about 24 mph. I think I can go 44/16 with no tensioning device, but I don't know if I can stand it for 40 miles.
    Thanks for the feedback.
    paintbucket
    Quote Originally Posted by Enoch
    You might think about some shorter cranks. Pedal strikes on a fix are no fun.
    And He was Not
    Got "em
    I've got a couple of 170's and a set of 172.5's. I'm still riding it as a single right now, but if I go fixie, I heard this could be a issue. I'm also sure I'll miss that extra leverage. but I'll cross that bridge when I get there.
    "Mr. Britannica"
    If you go fixed, you won't want to be using a tensioner.
    Where's Toto?
    Reputation: endure26's Avatar
    Cool-blue Rhythm
    If you go with a freewheel, you can run a lower gear because you can always coast the downhills. If you go fixed, you need to run a gear high enough to allow your legs to keep up on the downhill. I live in a fairly hilly area (not 2000 ft of climbing though) and on my winter fixie I run a 46x18. On my SS cross bike, I run a 36x18 for off road riding. I drop it down to a 36x16 or 17 when I flip it to fixed for road riding. You won't want to run a tensioner with a fixed gear as it will cause it to wrap if you back pedal -- with the f/w it's fine.
    And He was Not
    Quote Originally Posted by roadiegonebad
    For sure on the tensioner, I may also run into some chain length versus ratio problems with the fixie also. the frame only has verticle drop outs. but I got it cheap so I figured I'd try it with a free hub first.
  1. Thinking about giving up road riding
    By farmertan in forum Passion
    Last Post: 12-26-2004, 08:25 PM
  2. Mountain bike/road conversion question?
    By tmccrohon in forum Passion
    Last Post: 12-12-2004, 08:05 AM
  3. Passion Hit - Roadie Style! (LONG)
    By parkmeister in forum Passion
    Last Post: 06-09-2004, 03:11 PM
  4. What's faster? 26" s/s or 29" f/s geared?
    By ssmike in forum Singlespeed
    Last Post: 02-18-2004, 11:56 AM
  5. What's faster? 26" s/s or 29" f/s geared?
    By ssmike in forum 29er Bikes
    Last Post: 02-18-2004, 10:13 AM
