Results 1 to 3 of 3
Thread: Road crankset?
    Road crankset?
    Is anyone using a road crankset for their single speed? I was looking at Shimano road cranks the other day, and they're available is 110 BCD, are fairly light, and stiff. It seems like a pretty viable alternative.
    one chain loop
    Reputation: fishcreek's Avatar
    road cranks are designed for narrow chainstays. it is doable but you might use the longest bb spindle available just to clear the stays.
    everything sucks but my vacuum cleaner.
    I had problems using 105s on my Peregrine. They would only clear with the stays with the EBB forward. Q factor was much to narrow, but it has straight stays when it really should have S-bend. On my Monocog I'm using 130bcd Vuelta road cranks (cheap as ****) with a 110mm spindle and have no clearance issues because the stays are S-bend. Both cranks are 175mm. Basically, it depends on your frame, crank, and SS hub style. A cassette hub is going to give you more chainline options, especially coupled with a square tape crankset. You can put the chainline right where you want it.
