Results 1 to 9 of 9
    theHeadlessThompsonGunner
    Reputation: SDizzle's Avatar
    New question here. Rigid fork for Chameleon
    I'm going to get a rigid fork for my Chameleon, but can't decide which Surly to get--1 x 1, KM, or Instigator. The weight of the Instigator frightens me a bit, but I'm replacing (not permanently-- just for some rides) a Z1, and am more concerned about the head angle than anything else.
    Any suggestions? A to C measurements would be really helpful, if anyone has them. It's also worth noting that finesse is not really my strongsuit, so a fork that can take a beating would be nice, at least until I'm really comfortable on a rigid, and better at choosing lines. That said, I haven't seen too much broken Surly stuff.
    "I've courted brain damage like some courtesan of darkness."
    -The Good Doctor
    blame me for missed rides
    Reputation: weather's Avatar
    I vote for instigator. it's corrected for 100mm sussy forks which is exactly what chameleon is designed for.
    My Chameleon came with an instigator on it.Seemed ok but I added the Fox!
    my experience with Surly 1x1.......
    Good fork. I was replacing an 80mm JudyT2. With the 1x1 and a Maxxis Mobster 2.7" tire my head angle remained the same as with the boinger fork sagged (me on the bike). The fork is shorter but the wheel is larger in outside diameter - 27" instead of 26". Surly was great in replying to my emailed questions, and shipped immediately. 413mm axel to crown, 2.34 lbs, 260mm steerer. A no worries company and product.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by SDizzle
    I use a KM fork as a replacement for a XFly 100. Like it very much. The KM's a-c distance is basically the same as the XFly w/o sag. The Instigator is designed for a 100 mm with sag. It is also heavier (it is more of a jump fork) than the KM and should stronger and ride rougher.
    Surly has the actual a-c specs for their forks on their site.
    mtbtires.com
    ... and if we just ... I dug around...
    and could only find the specs for the KM fork. It's about 50 mm shorter than my Z1, which I've been running with a lot of sag, anyway. I think I'll go with the KM; I just don't need the girth of the Instigator fork, and can't imagine bending/breaking such a considerable piece of steel, anywhoo. Thanks, ya'll.
    -The Good Doctor
    rejected
    Reputation: gspot's Avatar
    Idea! Axle to crown lengths....
    from bikeman.com
    Surly KM 29er fork...
    468mm axle to crown distance with 43mm Rake.
    Surly Instigator Fork...
    447mm axle to crown distance with 43mm Rake.
    Surly 1X1 Fork...
    413mm axle to crown distance with 45mm Rake.
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Get the Instigator fork.
    Any suggestions? A to C measurements would be really helpful, if anyone has them. It's also worth noting that finesse is not really my strongsuit, so a fork that can take a beating would be nice, at least until I'm really comfortable on a rigid, and better at choosing lines. That said, I haven't seen too much broken Surly stuff.[/QUOTE]
    The 1x1 HA is soooooo steep. It's like a road bike. I think the KM would be too tall for the Chameleon frame. I ran my KM on my Instigator frame.. was great.. since I usually run a z1. On the chameleon though.. i would go with the Instigator fork.
    Te mortuo heres tibi sim?
    i've got a monkey fork on mine; works great. i think a bit lighter than the instigator, but taller too.
    i've got a second one uncut/unused right now. you wanna check it out? then you could see how it feels, and if it's too tall, go for the instigator.
    the one on my ionic, i dremeled the v-brake mounts off,since i'm using a 26" wheel anyhoe. scroll down a bit to the riding hall with eric thread and take a look at it.
  1. Klein fork on ebay
    By nilepoc in forum Vintage, Retro, Classic
    Last Post: 07-26-2010, 03:00 PM
  2. Help me Tune my 04' TALAS RLC Fork
    By 2tricky in forum Shocks and Suspension
    Last Post: 07-03-2004, 11:08 AM
  3. Fork/ XTR Caliper Fitting
    By Lambone in forum Brake Time
    Last Post: 01-17-2004, 05:36 PM
  4. cut fork tube
    By mihurka in forum Shocks and Suspension
    Last Post: 01-16-2004, 09:54 PM
  5. 5Spot/Maverick fork?
    By Deano in forum Maverick
    Last Post: 12-31-2003, 02:11 PM
