Results 1 to 3 of 3
    replacement ring for raceface evovle single
    as the title shows i have a raceface evolve xc single spped crank that came with a 32 tooth. but because of issues with asthama i now need a 30 tooth so i can spin a little more but since it has a 104 bolt spacing mylbs is having trouble finding the substatution for me. so i told him i would ask all the geeks on mtbr and see what i could come up with thanks again in advance everyone
    jester
    Go one tooth larger on your cog?
    Reputation: boomn's Avatar
    What FKMTB07 said.
    30 tooth chainrings are rare and expensive for 104BCD cranks. They are usually custom made and might even involve grinding down the crank arms a bit so the chain doesn't rub
    Larger rear cogs are usually cheaper in comparison and easily available.
