Results 1 to 15 of 15
    Jun 2010
    Rennen Chainrings and Cogs
    Picked up a Rennen Chainring the other day instead of HBC. Very pleased with it so far.
    rennen design group :: 104BCD chainring
    Pros:
    Integrated chainring threads! (REALLY hate them)
    10 days from order to my door.
    Decimal gearing
    Neutral:
    3/16 thick before tapering to teeth (possible frame clearance issues if running over a 32T on some frames.)
    Cons:
    Costs slightly more than competitors.
    Reputation: trumpus's Avatar
    ...so enlighten me to the benefits of the decimal gearing. I've been looking at the Rennen cogs/chain rings as an alternative to HBC (I am impatient) and was wondering if I needed to consider a decimal ring or not...
    Also, whats the deal with the threaded chain ring bolt holes? What's the purported benefit?
    Jun 2010
    Quote Originally Posted by trumpus View Post
    Decimal Gearing:
    rennen design group :: Decimal Gearing
    Click the link on the bottom left for a podcast.
    Benefit to threaded holes is very obvious if you've had to replace CRs before! No more dealing with chainring bolt wrench. Mine either come loose sometimes or are a ***** to remove.
    Dec 2004
    Decimal gearing is more geared towards the BMX community, dialing in the gearing for racing depending on the track layout....
    Not that it would be a bad idea for SS...
    That being said I run a Rennen chaing ring and love it...
    Good quality stuff....
    Attached Thumbnails Attached Thumbnails Rennen Chainrings and Cogs-106_0367.jpg
    A Gentleman and a MTBR'
    Great Redline!!
    Dec 2004
    Thanks...
    Sep 2004
    My Rennen on my cruiser bike. Nice chainring. Ordered online, got it two weeks later to my door.
    Attached Thumbnails Attached Thumbnails Rennen Chainrings and Cogs-rennen.jpg
    Reputation: Captain_America1976's Avatar
    Mar 2005
    I recently ordered a chanring and cog from them. It took about 3 week to get the order. I am very happy so far. I love the integrated chainring bolts. It helps tremendously with keeping the chainring centered. I was in a constant battle with the Blackspire ring. The bolt holes were slightly bigger than the bolts. It didn't matter how tight I got the bolts the ring would never stay put.
    Reputation: D.F.L.'s Avatar
    Don't waste your money on decimal gearing. On a timed drivetrain, such as a chain or cogged belt, it's the number of teeth, not the Pitch Diameter, that determines your gear ratio.
    a 40/20 combo is always going to rotate the rear wheel 2x for every front revolution. Always.
    40.1/20 is the same as a 40/20. 1 crank rev = 2 wheel revs. Always always, always.
    Rennen is confusing friction drive technology (rubber/leather belts on smooth pulleys) with timed. Huge mistake on their part.
    If you want more friction and wear, the decimal gearing might be just the thing.
    Wow. Those Rennens are nice. Tall teeth, clean look. I have been running a Surly Stainless cog and chainring on my 26"; and before then a Salsa ring and before then a way awesome Rocket Ring which was cheap and good.
    Oaktown Honkey on Strava
    Captain America, thanks for wrecking my day!
    Just yesterday I finally decided to actually center my Blackspire 104 32 after two years. Now you tell me it won't stay put! Suckimoto! TMI TMI TMI
    Yeti Clyde, Nice bike
    Reputation: AK47's Avatar
    I've found their aluminum cogs to be on the soft side and wear quickly. I won't buy again, and will stick with stainless steel from King or Surly so it lasts longer...
    Dec 2004
    Quote Originally Posted by D.F.L. View Post
    More decimal gearing talk....
    Rennen Tech Talk in Pull - VintageBMX.com
    Quote Originally Posted by AK47 View Post
    I would agree. They are extremely light, but not too strong.
