Results 1 to 7 of 7
    Spud State Rider
    Reputation: Doug_ID's Avatar
    Removing ENO Cranks ?
    Well, I had my torque wrench on the crank bolts and tightening to 30 ft pound per the WI instructions when the crank bolt head snapped off
    The crank arm feels pretty solidly attached to BB spindle at this point. Is there a correct method of removing crank arms off the square tapered spindle. I don't want to damage the crank arms.
    Thx!
    Reputation: boomn's Avatar
    Quote Originally Posted by Doug_ID
    Thx!
    there should be a different set of threads on the arm itself in the bolt opening; a crank remover threads into these and pushes against the spindle to remove the crank arm
    Spud State Rider
    Quote Originally Posted by boomn
    Ah yes.......duh
    Thx!
    Out spokin'
    Dec 1999
    Ah yes.......duh
    Thx!
    If there was a washer under the head of the bolt that broke off, make sure you remove this before proceeding with crank removal. Otherwise you'll just work the puller against the washer, thereby stripping the threads in the arm.
    --sParty
    disciplesofdirt.org
    --sParty
    good point. I've, uh, certainly never done that to a brand new crank
    Out spokin'
    Dec 1999
    ...and I certainly have. To a 1972 Campagnolo Record crank. Fortunately I questioned the difficulty of turning the crank puller in time to see the error of my ways, sparing the arm from damage. But it was close. And a good learning experience.
    --sParty
    disciplesofdirt.org
    Spud State Rider
    no washer in this case....they came right off no problems.......thx
