Results 1 to 10 of 10
    Bonking ... not feelin' well removing Derailleur cable hangers
    Anyone know of a good way to remove Derailleur cable hangers? Let me tell you, using a cutting wheel is not a good way!
    I'm sure I saw this posted somewhere at one time or an other. Can't seem to find it though. Oh, well.
    SCOTT
    You can't be lost if you don't care where you are.
    Reputation: ernesto_from_Wisconsin's Avatar
    and why...
    Quote Originally Posted by bikesforpeace
    SCOTT
    why would you want to remove it? I had a friend who cut his off a nice Bontrager...and now regrets it.
    I'm not sure you get
    Quote Originally Posted by ernesto_from_Wisconsin
    What I mean are the little tabs that hold the cable housings. I have no need for them since there's no more shifting and I thought it would be cool to rid of them.
    nah
    nah, just leave them. They're momentos of when you could shift. Makes geared riders more inquisitive as to why you opt to ride SS.
    If you have a sttel bike, ugh. But if you have an ALU frame, go for it.
    Fat, but working on it...
    Reputation: IAmCosmo's Avatar
    You can use a cutoff wheel, but a Dremel will probably take a while. Find an auto body or machine shop around you with an air powered grinder with a cutoff wheel. That will take them off in no time. If course, if you have a steel frame, the frame will need to be painted, powder coated, or clear coated after you are done...
    meatier showers
    Dec 1999
    SCOTT
    If your bike is steel, they are probably silver soldered on. Take your frame to a framebuilder and (s)he can easily remove them with a torch. You were planning on repainting your frame anyway, right?
    If your bike is aluminum, let the grinding begin. Don't go too deep, she moaned.
    --Sparty
    disciplesofdirt.org
    cretin
    low tech
    hog them off with a hacksaw, and smooth out the weld/braze residue with a flat mill file.
    i've done it, and i'm a chimp!
    Contrarian
    Reputation: AndyArmstrong's Avatar
    Wasn't the lack of opposable thumbs a problem?
    Candlestick Maker
    Reputation: baker's Avatar
    SCOTT
    Dremel, a steady hand, patience, and some touch up paint worked for me.
    I removed the cable stops, derailleur hanger, canti brake bridge, rack and
    fender mounts.
    baker
    shakey shakerson
    Quote Originally Posted by baker
    fender mounts.
    baker
    Thanks for the ideas. My frame is steel and I will be painting it assuming I don't ruin it first! I think I'd better have someone else do this. A steady hand I'am not. A friend used to call me Shakey Shakerson.
    Anyone else ride the Ironman in MN today? I should have started this little project sooner it would have been a good day for a debut.
  1. Derailleur Hangers...
    By Soupboy in forum Ellsworth
    Last Post: 04-13-2004, 07:19 AM
  2. 03 Dakar XC Pro Derailleur Hangers
    By whiskeyjacks63 in forum Jamis
    Last Post: 04-12-2004, 07:54 AM
  3. Spare derailleur hangers (type D1)
    By Johnny2Good in forum Kona
    Last Post: 03-22-2004, 02:33 PM
  4. Ghost Shifting
    By mtnfiend in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-07-2004, 11:59 PM
  5. Retro cable hangers
    By loonyOne in forum Vintage, Retro, Classic
    Last Post: 02-28-2004, 11:42 PM
