Results 1 to 16 of 16
    Reputation: SS-Phil's Avatar
    Redline Monocog + [insert fork here]
    Hello everybody,
    I'm currently riding a Redline Monocog, which I like a lot. However, I found out that a rigid fork is too much for me, so the next big investment is going to be a suspension fork. I do mainly All Mountain/Aggresive XC type riding and racing, so the forks that I see suitable are either a Manitou Black Platinum, or a Marzocchi MX Pro ETA. So, I was wondering if either of these forks will mess up my geometry too much. About how much higher would the front ride if I were to put on a 120 mm Black Platinum?
    Thanx for any help,
    Phil
    blame me for missed rides
    Reputation: weather's Avatar
    i measured the monocog rigid fork (2003), it is about 425mm a to c. that's about a 80mm fork sagged. 100mm forks should be ok. i won't go anything more than that though.
    Ok, thanx a lot. So I think I might get a Black Elite, 100 mm, with lockout. About how much would this push the front end up?
    Thanx for your help,
    Phil
    it'll push the front end up about 15mm (when the fork is sagged 25%).
    Inrideo est vita
    Reputation: SSteel's Avatar
    The Black Platinum is nice because it has adjustable travel. You can set it between 90mm and 130mm or any point in between.
    Canadian distribution: X-Fusion Shox, Rand Momentum lube and Canadian Shield fenders.
    TheRide.ca
    Facebook
    theHeadlessThompsonGunner
    Reputation: SDizzle's Avatar
    Blacks are short as far as most sussy forks go, so you might get away with a bit less than 15 mm. I think you'll be fine with a 100 mm Black, but you'd be better (geometry-wise) with 80, or the RTWD (> 2004) cranked down to 90 mm.
    "I've courted brain damage like some courtesan of darkness."
    -The Good Doctor
    So maybe an 80 mm Skareb instead? Does anyone have experience with Skarebs? how do they handle small drops and jumps and such?
    KRN
    KRN is offline
    Reputation: KRN's Avatar
    No more then.....
    100 MM of travel on the Redline I have a 04 & I run a ManitouSX fork with 3 inches of travel with is whats recommned (damn cant spell) the Maniotu sx is more then enough for what I ride which is singletrack & tech. But racing good luck not sure on that one.
    Reputation: gonzostrike's Avatar
    Manitou SX-R w/ 80mm travel worked well with my Redline Monocog, but the 28mm stanchions were squirrelly in the chop.
    I'd suggest something with 30mm stanchions and 80mm travel.
    Like what?
    Dude, where's my gears?
    Maybe a Fox Vanilla 125 RLC set to 80mm?
    aren't most pre-04 Black's tunable to 80mm? black elite is a pretty good performance per dollar. about 230 bucks from supergo i think.
    Steamroller
    Reputation: Mattman's Avatar
    Quote Originally Posted by SS-Phil
    Hello everybody,
    Thanx for any help,
    Phil
    I had a Monocog and it was my understanding that it was supension corrected for a 100mm fork. You have to allow for the sag in the suspension fork. when comparing the length against a rigid. I now have a solo-one and I have the '04 MX Pro ETA 105 on it and it works great. I would recommend this fork to you. I think you'll find the length fine the extra 5 mm is insignificant the longer travel is nice for decents. When you lock it out the travel decreases and the front end lowers which is good for climbing. A remote lever would be all I would like to have added.
    Two Wheeled and Too Big
    the redline rigid fork has EXACTLY the same axle to crown length as an 80mm <b>sagged</b> marzocchi fork.
    Right now, I'm leaning more towards the Fox Vanilla. I can run it on 80 mm for general trail riding, and then I can jack it up to 100 or 125 if I do some jumping/freeriding/urban.
    Am I getting too bulky?
    Reputation: Bikehigh's Avatar
    Like what?
    FWIW, I've got an '01 X-Fly 80 on my MonoCog.
    I gotta roll, can't stand still, got a flame in my heart, can't get my fill.
  1. Replies: 5
    Last Post: 04-14-2004, 08:19 AM
  2. rigid fork question: Alu, steel, carbon...
    By jh_on_the_cape in forum Singlespeed
    Last Post: 03-24-2004, 05:18 PM
  3. Worth upgrading Redline Monocog?
    By SingleSpeedPA in forum Singlespeed
    Last Post: 03-22-2004, 08:16 PM
  4. Redline Monocog Flite
    By seely in forum Singlespeed
    Last Post: 03-16-2004, 07:16 PM
  5. Redline Monocog w/Wheelset $199
    By Snowmonkey in forum Where are the Best Deals?
    Last Post: 02-25-2004, 02:49 PM
