Results 1 to 24 of 24
    Gimme free stuff
    Reputation: tims5377's Avatar
    Oct 2010
    recommend SS chain
    I was messing around trying to get a smaller cog on, had to shorten the chain, when I was putting it back together the side of the link bent and got all f-ed up... basically I need a new chain. What would you recommend? I would like a cheaper one, yet still quality obviously.
    Guerrilla Gravity BAMF
    Smash
    Reputation: jtrops's Avatar
    Have you searched? This comes up all of the time.
    I'll get the ball rolling:
    Unless you are seriously weight conscious the KMC 610hx is hard to beat for the money. The last one I bought was $11. They are crazy strong, and wear very well.
    Reputation: jetboy23's Avatar
    As long as your chainline is good you should be able to use just about any chain. I have used and, in the short amount of miles, not broken Sram 951, 971, KMC 8.93, and Z610HX. The Z610 seems to be the least flexy and problably the strongest. Although, i think the pin strength of the Sram chains are near or equal to the KMC chains i listed. The Sram chains are lighter, too.
    It's really what you prefer. I currently feel that my 610 chain is wearing better than the others i listed. But, at the <$15 pricepoint, its not expensive to opt for the 951, 8.93, or z610. KMC makes an even stronger 3/32 chain for under $15. the K810. Their Kool chains are supposed to be really strong. After i wear out my two Z610s, i will stock up on K810.
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    i have no "data" to prove a motherphucking thing however, i will continue to buy the KMC z610hx chain, period
    Shameless plug. I have two KMC new 8 speed chains in the for sale section. Get them both for $25. They worked great for me but am rocking belt drive this year so the reason they are for sale.
    OB1 Kielbasa
    One is good!
    bored ex-shop rat
    Reputation: velopax's Avatar
    Good job!
    I have used a KMC Z610HX for some years, this chain is rock solid, now I
    swithed to a KMC Z1HX, KMC claims this chain is even stronger.
    Life is like a ten speed bicycle. Most of us have gears we never use. Charles M. Schulz (1922 - 2000)
    Combat Wombat
    Reputation: BrianU's Avatar
    Quote Originally Posted by velopax View Post
    Have been using the 610 for years, but I would not mind checking out that new chain you listed. Unfortunately did not find anyplace selling it on this side of the pond.
    Reputation: azjonboy's Avatar
    sram pc870, 8 spd. bullet proof.
    If you're lucky enough to be in the mountains,
    you're lucky enough.
    Sram pc-850
    351 is offline
    I use the KMC as well, not for any reason other than it was $10 and durable.
    bored ex-shop rat
    Good job!
    Quote Originally Posted by 351 View Post
    Yes! that's the best part, even the better ones are less expensive than
    a midrange derailleur chains
    SSolo, on your left!
    Quote Originally Posted by jetboy23 View Post
    As long as your chainline is good you should be able to use just about any chain...... The Z610 seems to be the least flexy and problably the strongest. ....It's really what you prefer. I currently feel that my 610 chain is wearing better than the others i listed. But, at the <$15 pricepoint, its not expensive to opt for the 951, 8.93, or z610. KMC makes an even stronger 3/32 chain for under $15. the K810. Their Kool chains are supposed to be really strong. After i wear out my two Z610s, i will stock up on K810.
    Yes, ran KMC 610 and it was great, but love the KMC K810SL-CP it lasted longer than any other chain I ever used and it never gave any problems....looks cool too with hollow pins and cut out plates. Definitely less flexy side to side than others!
    KMC USA
    Get off the couch and ride!
    My husband has used KMZ 410's without any complaints. It looks like you can get them for $4 to $9. I've only used the SRAM PC-1 so I have nothing to compare it to, but I like it and you can find them for under $10.
    The 410 is a good chain, but it's not the strongest. I have gone through many of them. I am a big fan of SRAM chains on my derailleur bikes, but I seem to wear them out quickly on my SS, and IGH bikes. To be fair I haven't used the PC-1 since I'm all 3/32" now.
    If you are looking for a 1/8" chain I would go with the KMC 510hx. It's the same chain as the 610hx, just a bit wider.
    Got Mojo?
    Reputation: BikeMojo's Avatar
    Jan 2005
    Quote Originally Posted by azjonboy View Post
    +1
    PC68. Oldschool SRAM 8sp. No problem.
    aLaN AT BikeMojo DOT com
    Birthday Collector
    Reputation: ATBScott's Avatar
    I'm a big advocate of the 1/8" SS equipment... And KMC chains - been running 410's for a long time with no issues at all. I trashed two PC-1's in a month or so - and that was it for them - and I like SRAM chains on the geared bikes. So if you're staying with 3/32" the KMC 610 and 410 or 510 if you are running "fat teeth".
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    Odd, because I seem to destroy Sram chains with the quickness. Somewhere in the 100 mile range they start to break.
    playin hooky
    Reputation: struggleT's Avatar
    I have always run SRAM 8-speeds on SS, but based on posts above maybe I'll try the Z
    Single Speed Junkie
    Reputation: crux's Avatar
    Have used Izumi Super V chain for a few years now and really like how smooth they run.
    you can find them for 4 bucks... how do you not go with the kmc 410? it is every bit as good as a PC-1.
    With SRAM chains you have to remember two things:
    1. The PC-1 is a horrible chain and should never be used.
    2. You can use a chain tool to cut the chain, but you must use a Power Link to join it.
    Reputation: Nubster's Avatar
    Where do you guys that use these chains, get them? I found them on the KMC site but was just wondering if there was any place cheaper. From KMC, the Z610HX is $11 with $8 shipping and I can't find anything on the Z1HX.
    Also, anyone know what this chain actually is? It is simply listed as a SS chain.
    Kona Big Unit SS
    Kona Private Jake SSCX
    DiamondBack Release 3
    It's available on Amazon for $12 with free shipping.
    Thanks. I looked last night but didn't see that deal but I did end up getting a couple from Amazon and saved $4 over ordering from KMC. Thanks.
    Kona Big Unit SS
