Results 1 to 18 of 18
    Feb 2006
    rear derailleur hanger
    Is it safe to remove it from my conversion? Thx
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    yup. grind that sucker off!
    "Knowledge is good." ~ Emil Faber
    Reputation: jmmUT's Avatar
    And if it's the removable type-go for it. Doesn't matter. Did that with a bike I magic geared
    Jan 2009
    if the hanger is part of the service that your axle clamps onto, you should leave it on there. you can grind the hanger part off if you want, but leave the dropout part on there.
    Feb 2006
    the hanger is removable but the axle clamps onto it, so which is the right answer?
    Feb 2013
    Re: rear derailleur hanger
    Leave it on!
    Sent from my DROID RAZR using Tapatalk 2
    Feb 2006
    cut it i guess
    Feb 2013
    Yes
    Feb 2006
    thx
    meh... whatever
    Feb 2006
    Quote Originally Posted by Markleo View Post
    one chain loop
    Reputation: fishcreek's Avatar
    Why though? Its not like someone will criticize you for having a hanger left in there.
    everything sucks but my vacuum cleaner.
    Reputation: Andy R's Avatar
    Nov 2008
    Quote Originally Posted by fishcreek View Post
    And if you ever want to sell the frame it will limit your potential market if you remove it.
    Do 15 feeble grinds.
    feeble grind BMX - YouTube
    meh... whatever
    Feb 2006
    Quote Originally Posted by Andy R View Post
    or not. they're less than $10 to replace.
    Feb 2006
    btw the wheel axle "sits" better when removing the hanger. when i have it on i need to push the right stay with a screwdriver in order for the wheel to sit properly. does it really matter if i remove it?
    Jan 2009
    after another 50 miles or so, the chain will stretch a bit and it won't matter. I would leave it on and grind off the hanger bit if it's bothering you aesthetically. or leave it on in case that frame ever gets gears again, or you have to bolt on some sort of tensioner.
    my first SS mtb as a conversion that worked by a "magic gear" but that only worked for a few rides until the chain stretched. chance are, you're going to feel the urge to buy a dedicated SS frame or bike in a few months, so don't ruin that frame for someone else.
    Out spokin'
    Dec 1999
    Don't make the wrong mistake.
    =S
    disciplesofdirt.org
    Feb 2006
    i kind of enjoyed "killing" it!!
  1. Rear Derailleur Hanger Help
    By jclyle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-16-2013, 04:57 PM
  2. Rear Derailleur Hanger
    By bloodninja in forum Beginner's Corner
    Last Post: 11-26-2012, 07:11 PM
  3. help with rear derailleur hanger
    By wootenator in forum Motobecane
    Last Post: 05-13-2012, 10:06 AM
  4. Replies: 11
    Last Post: 09-14-2011, 07:29 AM
  5. XT rear derailleur hanger
    By amirwhite in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2011, 09:35 PM
