Rank these forks please
Help me pick between these inexpensive forks...
Surly 1 X 1
Dimension Disc specific
Planet X
Goods or bads?
My requirements are: I need to run a 2.4 (or more) up front, and has to be disc specific.
with steerer tube of at least 8 inches...
Also, my frame is set up for 80mm and I'm not sure the Dimension is 80 or 100mm corrected.
Any other suggestions would be welcome! I have to get this rigid fork thing out of my head once and for all and I wanted to try it out with a cheaper fork to see what it's all about.
Surly 1 X 1
Planet X
Goods or bads?
I've had 1 and 3, and you won't have problems fitting a fat tire in there. Riderx has/had 1 and 2, and he runs/ran 2.4 Motoraptors.
Cubicle Fugitive
Kona P2?
I'm not sure what the a-c measurement is off the top of my head, but it is inexpensive, available as a disc specific fork and I have a 2.6 tire in mine with room to spare.
Sofa King We Todd Did
The Kona Project 2 disc fork is your answer. It's rather inexpensive, light as a feather, corrected to about 80mm, and will swallow a big fat honkin' tire with no problems.
Where does one purchase such a fork?
Is it Steel?
How much is "inexpensive"?
voodoo child
Steel. 410mm (axle to crown). 60 bones at bikeman.com
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." -Antoine de Saint-Exupery
Cubicle Fugitive
P2 Disc at www.bikeco.com (nm)
What's the problem? The fork does come with disc mounts. There is a v-brake version and a disc version.
I need DISC mounts!
http://216.119.92.126/Merchant2/merc...egory_Code=FK2
baker
Recovering couch patato
Where did you see the 100mm corrected Dimension? Even the 410mm IMO is shorter than most 80mm forks after sag. Mine is around 1100g, rock hard and probably bombproof.
"Mr. Britannica"
Light as a feather? I think not. Kona claims 760gm or so, but having weighed one (uncut, v-brake) I can say it's alot closer to 1000gm. I guess it's all relative.
Cubicle Fugitive
Was that on the triple butted or the standard version?
I need DISC mounts!
Surly. It fits your needs, 80mm corrected and bomb proof.
Surly 1x1 replacing an 80mm fork. With a fat tire, the geometry is unchanged. Ran a maxxis mobster 2.7 - really 2.5 - no problem. Currently have a continental Deisal 2.5 - really 2.4. Well made, easy to install, no worries. Surly answered all my emails quickly before I bought.
By WATTO in forum Clydesdales/Tall Riders
Last Post: 04-22-2005, 01:25 PM
By ShooterMcGavinYo in forum Downhill - Freeride
Last Post: 03-21-2005, 07:24 PM
By EgonSpengler in forum Kona
Last Post: 01-26-2005, 10:17 AM
By SpinWheelz in forum Singlespeed
Last Post: 12-05-2004, 05:15 PM
By Wily in forum 29er Bikes
Last Post: 09-30-2004, 11:14 AM
- You may not post replies
- You may not edit your posts
Forum Rules
