Results 1 to 28 of 28
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Quick road bike advice...
    Looking to buy a used road bike out of the paper.
    They guy wants $150 for this puppy..
    any thoughts?
    Reputation: SSSasky's Avatar
    Tough to tell
    Seems pricey to me, but it all depends on the area and what else is available.
    I managed to snag a 3X butted Ishwata Norco frame for $100CDN, which is like $75 to you yanks.
    If it's in better shape then it appears, and the components are decent (depending on which one's you'll keep of course), it's probably an okay deal.
    The chromed headtube is nice. It could make a real nice, if slack, conversion.
    rejected
    Reputation: gspot's Avatar
    I smell a fixie project...
    didn't you just sell a road bike on ebay....
    Quote Originally Posted by gspot
    I did. But is was nifty Alu that felt a tad noodley and shakey.
    I wanted to sell it so I wouldn't break it.
    I think old steel might suit me better, plus, I'd be up about $600 on the deal.
    I'll offer the guy $100 and see what happens.
    Not because I'm fast.....
    Reputation: 2farfwd's Avatar
    Miyata
    Quote Originally Posted by Padre
    any thoughts?
    Hey Padre,
    I have found nicer old road bikes for cheaper by searching the thrift shops and swapmeets when I lived in OC. The Goldenwest College swapmeet usually has some good stuff to be found.
    Miyata road bikes I believe tend to run a little short in the toptube length too, so at your height, I would make sure it is long enough for you.
    I saw this on Ebay that looks somewhat interesting for a project:
    http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
    Good luck!
    Reputation: shiggy's Avatar
    Dec 1998
    This bike may not be any stiffer than your old Al frame unless the steel tubing is fairly thick wall.
    mtbtires.com
    Dec 1998
    Quote Originally Posted by SSSasky
    ...The chromed headtube is nice. It could make a real nice, if slack, conversion.
    Paint, not chrome.
    Slack? Looks normal road to me.
    mtbtires.com
    paintbucket
    Reputation: wooglin's Avatar
    Miyata made some real good, undervalued frames. Don't know if that's one of them. It looks like a freewheel bike, in which case all you need to buy to fix it is a cog and a new chain, assuming everything else works ok. I think 160 is a bit steep, but I'd be tempted because bikes in your size are hard to come by.
    I do think it would make a great fixed gear bike though.
    When the going gets weird its bedtime.
    Quote Originally Posted by wooglin
    Yeah, that's the thing, there are always 56cm bikes and the like around, but never anything like this, at 62cm.
    Where do I go to get info on that fixed conversion? Sheldon?
    paintbucket
    Sheldon is a good place to start. And the fixedgeargallery.com has some how-tos on the main page and good folks in the forums.
    Penis Goat!
    Reputation: GirchyGirchy's Avatar
    The first place I went is the Fixed Gear board over at RBR...very good info over there. You can ask your original question (whether or not it's worth it) on the Retro/Classics board, I think they'd be able to help you out.
    You'd need a new rear wheel for a conversion. I'm kind of in the same boat as you, and have decided to go SS until I can purchase the components to build up a fixie wheelset. I asked about converting a freewheel wheel into a fixed wheel over on the Fixie board, and several replied they've had problems. It just doesn't sound safe to me.
    Quote Originally Posted by GirchyGirchy
    Cool. That is my tentative plan for when I find the cheapo bike.
    Thanks for the input everyone.
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    All you can find is 56cm frames??? All around here is 60cm+ frames!!??!! I'll ask around if any of my tall friends have any big frames they would like to donate... would just a frame do - or would you prefer a complete bike that you can convert to a ss?
    Later
    FF
    "If I'm leading, I'm bleeding."
    paintbucket
    I think that's a function of how you use the bike. If you're going to be skidding it then a track hub with a lock ring is just about a must. But if you'll be using it for road riding then its not as necessary. I run two brakes, I ride road, and I don't skid. So I just converted a road hub. If and when that becomes unsafe due to how I ride, I'll switch. Until then I'll just be cheap and run what I got.
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    Does it fit? Nothing worse than an ill-fitting road bike, no matter how cheap.
    Hard to tell alot about the frame, but the components look decent enough. Possibly Modolo brakes, Suntour (or cheaper SR or Sugino) cranks, SR Laprade post. Maybe a Cinelli stem (if so, likely 26.4 diameter, which is not compatible with today's 26.0/25.8 and (obviously) 31.8.
    Quote Originally Posted by Fast Freddy
    Later
    FF
    I'm looking for a complete bike to run SS. I need to be able to get out and spin on the road to get some time in training for the VQ on the road. After that, I'll try fixie style, me thinks...thanks for the offer!
    Reputation: sachase's Avatar
    Jan 2005
    Fixed freak
    I love riding fixed, so much more control. I bought an old centurian (diamondback before it was diamondback I believe) frame for $25 on ebay (56cm) the whole set up cost me around $250 when all was said and done, I got lucky and my bike shop had not only an old fixed hub, but attached (well seized on I should say) was a campy track cog. It took a while to figure out the spoke lengths but It's a sweet ride. One (front) brake, cow horn bars, Frame and fork were imaculate for being as old as they were. I'll post a pic later, The only problem I ran into was the rear hub was short, so I opted to bend the seat and chain stays in a little but I love it, I wouldn't do the SS thing, you should just jump right in to the fixed, the SS thing is a step that is not nessesary. But to each his own, Who am I to tell someone else how to ride.
    Custom Independent Fabrications Ti Deluxe
    Carbon Niner Air 9 SS/rigid
    Carbon Niner Jet 9
    Ritchey Swiss Cross Disc
    Quote Originally Posted by sachase
    I have heard that road SS is incredibly boring. Not sure if that's true.. but if I pick up an ancient road bike, the chances that the drivetrain functions well are slim to none. I won't have the money to make it fixed at first, so I might have to run it SS at first. We'll see.
    Not a regular
    From one tall freak to another, if you are looking for a road bike, look for bikes that have 60cm + top tube lengths. Most basic brands - and especially Euro brands - have short top tubes. I had an early '70s Masi Gran Criterium 62cm that "only" had a 59cm t/t. It was a beautiful bike, but just never great. One of the best frames I had was a late 80s Klein Quantum 61cm with a 60cm top tube. They even made a 63cm frame for the ultra-tall. An old Klein would be a pretty dang cool road frame for you and a good choice for a s/s conversion. The only drawback is the press-in bottom bracket if you are into changing cranks. But once it's set, its set.
    Reputation: scanjok's Avatar
    I think too much
    Just my opinion, but I think $150 is too much. I went to a bicycle salvage in Tucson, AZ (called b.i.c.u.s.) and got me a Miyata frame for $20. I stripped all the parts and left them at the store and took home the frame. The only money (besides $20 for frame) was $120 for Suzuie(sp) and Cog. It has been a fun investment. I have used it for road rides and commuting. Its my first fixie build and its actually inspired a few of my friends to build up some fixies. I recently puchased another cheapo MTB frame to build up a SS Polo bike.
    Here is a pick of my Miyata after I completed it. (sanded and painted flat black with the luggs still silver)
    Quote Originally Posted by scanjok
    Sweet ride.
    I was going to offer the guy $75, but maybe I'll shoot for $50?
    Another thing, I was hoping to use the bike to get some spinning rides in as training for the VQ. A fixie, at this point, I think might be too much pain, when I'll still be recovering from long SS efforts.
    Reputation: fixgeardan's Avatar
    Sweet ride.
    a little tip the spinning is the trick to quick recovery it flushes the legs!!
    Good job!
    heres a pic of my road fixie built a couple of years ago very cheap
    an old lugged nishiki rides great
    frame,fork,headset,stem $50 LBS
    seat&post junk drawer
    m-bars $18
    cranks&brakes thrift store schwinn
    chainring,cog,pedals junkdrawer
    wheels off wall welded free hub has worked great
    12 pack paint job from painter at work
    Steamroller
    Reputation: Mattman's Avatar
    Ride it then resell it
    Padre, If it fits try to get it for $100 or so and then ride it, SS it, whatever. If you don't like it or find a better one you can resell it pretty easily for $100-150 I would think. I have sold 2 road bikes that were not as nice for $75 and $150 easily in the last year. If you ride it for a few months and take a $25 loss you still came out OK. Be carefull about buying a 27" wheeled bike, they are out there too, but a bit hard to find decent tires for, and if you convert it to 700s you'll likely have to find a set of long reach brake calipers. I'll keep my eyes open, I seem to have a talent for finding nice old road bikes cheap.
    Two Wheeled and Too Big
    Jan 2005
    Throw away that derailuer
    Once you start you won't go back.
    Carbon Niner Jet 9
    Steamroller
    Those bars again
    I keep seeing pictures of these cool bars, then I realise it's just another of your bikes with the same bars which you have a pile of, and the rest of us can only wish for........Tease!
    Nice ride, My old Nishiki is also a sweet riding frame though mine is not as old and not lugged.
    Who turned out the lights
    Reputation: Francis Buxton's Avatar
    Padre, my general frustration with Ebay has been that I can't ride a 60cm. All the 56 frames/bikes go for decent coin, but the 52's and 60's are crazy cheap. I did, however, recently purchase a 56 Univega (pink to boot) for $25 that included cranks/bb/headset/seatpost. Traded a friend a Koga-Miyata frame that didn't fit for a buildup of a track wheelset, bought some bullhorns from another friend for $10, and a new Kinesis aero fork for $50 on Ebay, and I've got my new brakeless road fixie for under $200.
    Padre, that bike has everything you need on it, so $100-150 might not be too bad. Just strip off all the stuff you don't want. You may be able to re-use the rear wheel. Just pay a local shop $20 to re-dish it. If it won't work, you can always buy new spokes and have it rebuilt on the same hub and rim for not a lot of coin. And sometimes you can get away with running a less than ideal chainline, but it's not always advisable.
    Personally, I would forgoe the whole ss road thing. It's just not fun. Not at all. All the work of the fixie, but none of the fun. You don't roll into the hills with the same inertia that you do when you're fixed. I don't think I can explain it, you just have to feel it. Buy a 15/16/17t rear cog and re-use the 42 up front on that Miyata and let her rip. You won't regret it one bit.
    Here's my tip for running a fixed cog on an old freewheel hub (that I got from others): put the cog on with no lockring and ride around the block. Stand on the pedals a lot, but do not EVER backpedal. You need to get that cog seated on the hub with leg force from riding. Then, come back into your shop and put one drop of blue loctite on the lockring, and put it on as tight as you can. Let it sit overnight, and you can ride the bike damn near forever without backing the cog off. Of course, cog changes aren't easy....
    Quote Originally Posted by Francis
    Thanks for the good insight Francis.
    I'll update you on what happens.
  1. Mountain bike jargon/ lingo
    By bstguitarist in forum Beginner's Corner
    Last Post: 05-26-2005, 12:02 PM
  2. Advice on road bike sales/stuff
    By Padre in forum Singlespeed
    Last Post: 10-07-2004, 01:35 PM
  3. parts advice needed for a fixed road bike
    By hu-man in forum Singlespeed
    Last Post: 08-25-2004, 04:44 PM
  4. CCP Stories
    By General Coonskins in forum Singlespeed
    Last Post: 06-30-2004, 10:03 AM
  5. Training-what time logged on a MTB is equivalent to time on a road bike?
    By dawgcatching in forum XC Racing and Training
    Last Post: 04-28-2004, 09:23 AM
