Results 1 to 27 of 27
    Mtbr Forum Sponsor - Homebrewed Components
    question for those with aluminum sliding dropouts
    well my bianchi has seen better days so i'm about to pull the trigger on a new frame. It'll either be an Ibis Tranny or a custom built Siren.
    Both will be the same price for me, so that has no bearing on what i do. Also, i do not want this to be a discussion on carbon vs aluminum or steel vs ti or KY vs Astroglide.
    Both bikes will also be a 26er as well, case closed.
    Basically, assuming i go with the Siren, what i want to know is how do people like their aluminum sliding dropouts? Has anyone killed them? If so, what happened?
    I am VERY hard on my stuff, and i am afraid that if i tighten them enough to not move, they'll eventually get mangled. I have a problem with my wheel moving backwards on decents, so i have to tighten the crap out of stuff. To give you an example, i've had to tighten my rear skewer so much to keep the wheel from moving backwards that my axle has managed to wear itself a considerable way through the inside of the dropouts on my Bianchi over the years. They're nearly hitting my hub now.
    Really I am that slow
    Reputation: SlowerThenSnot's Avatar
    pm'ed yah
    Read my BLOG!
    just a guy who loves bikes and exploring
    Reputation: bryan_d's Avatar
    Quote Originally Posted by SlowerThenSnot
    pm'ed yah
    Why not post the solution on the thread so that others who have the same problem can find a soluton? Do we really want to see more threads of the same past privately answered questions?
    Bryan d
    Just keep pedaling, don't stop pedaling.
    Quote Originally Posted by bryan_d
    Bryan d
    he didnt have a solution, he was offering me a deal on one of the frames i was looking at. I assume he just didnt want to spam up the thread, but knows i barely check my pms.
    Quote Originally Posted by ISuckAtRiding
    Well one can argue that no solution (AKA buy something else) is a solution no?
    Thanks for clearing that up,
    Bryan d
    PS - frame with sliding drop-outs are on the way
    Ovaries on the Outside
    Reputation: umarth's Avatar
    You know you want a steel 29er.
    Vote for Siren and 650b. You gotta know the geometry you prefer by now....
    Sounds like you're running a rear QR skewer with horizontal sliding drop outs???
    Change to a bolt on rear axle and/or get some tug nuts. I've been through two aluminum Bianchi SS frames, with bolt on rear axles with or without tug nuts, never had a problem.
    Quote Originally Posted by rglsr
    i have tug nuts. the problem is that i have to overtighten them so the wheel doesnt move backwards. no nut tuggers will fix that.
    Quote Originally Posted by umarth
    lol
    well, both frames will fit a 650b i believe (definitely at least the Siren as it will be custom). I dont want to go with a 650b just yet because of the tire selection and the fact that i'd need new wheels. But seeing how much fun my cx bike is on the trails, i bet i'll like the 650b's.
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    why sliding drops?....why not black cats, EBB, Eccentric hub, paragon, etc.. if you're goin' custom?
    Click Here for Forum Rules
    Quote Originally Posted by CHUM
    paragons are sliding drops and they dont do aluminum, i dont like ebb's or eccentric hubs, and the black cats are also steel only i believe.
    QR skewer + horizontal drop outs (with or w/o tug nuts) = Slip-o-rama
    Bolt on rear axle always worked for me.
    no bolt ons for me. tried them before, didnt help, and i hate carrying around (and having to use) a wrench, especially in a race. Trust me, i run a pretty beefy QR, and it is TIGHT.
    Again, the wheel does not move when it is tight. The problem is the overtightening has embedded the axle into the dropouts so far that it is getting close to hitting the hub.
    Regardless, i am not going with track ends again, so it is a moot point.
    well, looks like i'm going with the siren. Should be awesome!
    B- Does great work, love my john henry! if i ever go squishy hes high on my list as well
    Read my BLOG!
    Yea, Brendan definitely makes some nice frames. Cant wait to get it, this will be my first decent frame.
    Reputation: kcaz's Avatar
    Wow, talk about a fast lead time. You must be psyched.
    Quote Originally Posted by kcaz
    Yep!
    As for the lead time, this frame has been in the works for over a year.... it was just a matter of me deciding what i wanted on it, and how i was going to "pay" for it (we traded labor for labor). So i was the holdup.
    I should have it next week!
    Yep!
    Nice!!
    Read my BLOG!
    How are you going to set it up? What color?
    r7 100mm in the front
    dt swiss xr1540 wheelset
    thomson post and eventually a wtb rocket v stealth saddle
    small block 8's front and rear
    tubes
    xtrm960 crankset
    HBC gears
    Salsa grips with the little chilli peppers
    custom headset and cog spacers
    avid bb7 brakes and SD7 levers
    crappy bars and stem for now
    Basically everything that is on my current bike.
    Should come in around 21-21.5lbs, and sub 20 when i get around to buying decent stuff (never).
    The color will be a darker metalic pink. Most of the parts will be anodized purple. Should be really ugly!
    I am very proud to have you on the SS forums, if it turns out half as garish as I have imagined.
    I'd like to see pictures of the custom headset. Too bad it is not a steel bike. It'd be a little more real.
    oh it will be fugly for sure.
    I'm not making a custom headset, i'm just making a custom headset spacer. i guess i wasnt clear there (what else is new).
    Reputation: PoisonDartFrog's Avatar
    Ok, let's get one thing straight. With sliding rear DOs, a chain tug (aka Surly Tuggnut, etc) only makes sense on the chain-driven side. The pedaling stress on the right hand side tends to pull the wheel forward, so to maintain chain tension some sort of tug device is needed to prevent the wheel from sliding forward.
    However, a chain tug on the non drive side, or left side, is pointless. No there are there no pedaling stresses pulling the wheel forward. In fact, disc brakes do just the opposite. They tend to lever the wheel backwards out of the frame.
    That said, I have tried a number of different QR skewers on my SS with horizontal DOs. RAVX tend to work the best for me. They seem to be about 3/8" longer than most other skewers, allowing plenty of engagement, especially with thicker SS DOs and a tug device. I can get them plenty tight.
    should've bought the ibis! carbony goodness FTW
    If steel is real then aluminium is supercallafragiliniun!
    some teaser pics... i know the color and build arent for everyone, but that's why it's for me!
    26" wheels, although it is 650b comptatible and i guess i have a set of wheels waiting for me.
    21" seat tube, 24" top tube (custom for my goofy ass proportions)
    aluminuminum
    seatpost and seat are temporary
    did an 80 mile race this weekend for it's first shakedown ride and it fit great and performed flawlessly.
