    QR skewer barely holding on with a chain tensioner...
    So my rigid 26" SS is done and built and the only problem I have now is the skewer barely holds on the rear wheel. The sette chain tensioner adds an extra .25" or so and I can only finger tight the QR on.
    What skewers are you guys using for this situation? I'm guessing 135mm (is this the standard for mtb rear or is 130?)
    Reputation: farrisw1's Avatar
    135mm should be the ticket...I've always used either Salsa or some bolt on hex key skewers and they both have worked great...
    What kind of a bike do you have? Some older bikes came with 130mm spacing. Standard now is 135. You can always take off the rear wheel and measure.
    I use Shimano (XT) skewers and haven't had any slippage issues.
    the frame is a jamis dakota. I'm thinking the skewer I'm using just might be abnormally short.
    I'm going to measure and probably try a different skewer off my HT later on today
