02-03-2012
#251
a'huntin' gearies
From old to new
Before...
170mm Shimano SLX cranks with Cycle Undergound custom 33t chainring and KMC 710SL chain.
And after...
170mm Middleburn RS7 with 32t Uno chainring and KMC X9L gold chain. Made a little boo-boo when installing the self extractors, but it doesn't really bother me.
__________________
I see hills.
I want to climb them.
02-04-2012
#252
Kicker of Elves
Rep Power: 4 Rep:
user gallery
Nice, Stevob!
02-04-2012
#253
Rep Power: 0 Rep:
user gallery
why KMC X9L chain? Is it strong enough for ss?
02-04-2012
#254
a'huntin' gearies
Originally Posted by 120
Nice, Stevob!
Thanks 120.
Why not KMC X9L chain? Is it not strong enough for ss?
Do you know something I don't?
__________________
I see hills.
02-04-2012
#255
Rep Power: 0 Rep:
user gallery
It's a 9speed chain, not SS specific
02-04-2012
#256
Not a SS setup...
It's a 1x10, but so far I really dig it. And if/when the bearings go, I should be able to replace them with some Enduro BB30 bearings.
02-04-2012
#257
Rep Power: 4 Rep:
user gallery
What does that mean? I have a PC991 chain on my SS.
02-04-2012
#258
a'huntin' gearies
Sweet. If it decides to morph my bike into a 9 speed somehow, I'll send some positive rep your way.
__________________
I see hills.
02-05-2012
#259
Rep Power: 0 Rep:
user gallery
LOL, it means that it's a chain designed to work with cassette and derailleur.
Chains like that have inner and outer link plates designed to enhance shifting.
It's high possible that a chain like that in SS setup will drop under loads. Unless you have perfect chain line.
02-05-2012
#260
a'huntin' gearies
looks like I'm living dangerously for a while then.
nothing unusual there
chainline and tension's good mate.
__________________
I see hills.
02-05-2012
#261
Rep Power: 5 Rep:
user gallery
To get the best chain line and q-factor adjustment possibilities, are there any modern good and stiff alternatives to square taper/isis/octalink?
02-05-2012
#262
one chain loop
so using a SS specific chain will NOT drop under load even if you have a bad chainline? explain.
__________________
everything sucks but my vacuum cleaner.
02-05-2012
#263
Rep Power: 4 Rep:
user gallery
I know what it literally means. I've never had a problem with using old 9sp chains. Next one on my SS will be an old 10sp chain. Perfect chain line is pretty easy to obtain with a single speed specific bike or any cassette body hub.
Any chain will drop if it's loose or has a bad chain line.
02-05-2012
#264
F=ma, don't be a da/dt
X0 is probably the narrowest external bearing mountain crank at 156mm. If your stays are narrow, you could try roadie cranks.
02-08-2012
#265
one chain loop
more cranks
Turbines with p nut's ring
XTR with Dan's ring..
__________________
02-08-2012
#266
Rep Power: 0 Rep:
user gallery
XTR with an old Jericho 34t ring, have a new HBC ring on order
02-09-2012
#267
Rep Power: 4 Rep:
user gallery
960SS Mod
960SS Mod cranks with HBC 34t ring ready for a new Niner Carbon. I hope to see photo's of them installed and the build is completed
02-09-2012
#268
Did you paint the crank yourself?
It looks like some (or all) of those rings could be Chris King??
Did they come black, or did you paint those as well?
__________________
Santa Cruz Tallboy carbon
Lynskey Pro29 SL SS
Cervelo S2 Ultegra
02-10-2012
#269
Rep Power: 4 Rep:
user gallery
The finish on the arms, rings, and CK cogs is a very hard ceramic material.
02-10-2012
#270
Peludin
These ones look nice! and that ceramic black coat certainly adds a super-clean finish!... but for my liking they are far, far, far from your beautiful polished/bling XTR 960SS like those posted two weeks ago! Variety is the spice of life!
02-10-2012
#271
Rep Power: 4 Rep:
user gallery
The difference my friend is in choices of frame. The black 960's would not complement the Ti Crisp nor it them, but the polished with Ti will be fantastic. The black set was made for a new black carbon Niner and should be killer stealth, BAB (bad ass black), like GT's ZaskarX in 2000.
02-12-2012
#272
Rep Power: 0 Rep:
user gallery
1st pic post
hone + saint 38t + 5050
02-13-2012
#273
Rep Power: 9 Rep:
user gallery
Those are the sweet.
02-13-2012
#274
Rep Power: 4 Rep:
user gallery
02-15-2012
#275
Rep Power: 4 Rep:
user gallery
Hollowgram SL 175mm arms with Ti HBC 32t ring and Token BB30 Tiramic ceramic bearings. I put this together to get a weight for these...534g...now that's light for an alloy crank.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
