Results 1 to 17 of 17
    Reputation: beewee's Avatar
    Pics and info of fixed 1 speed's
    I know, there are other threads with fixed mtb's, but lets start a new one! Please share info about your bike: gearing, build etc...
    Here is my Raleigh. LOVE this as a fixed off roader! Had many, but none ride like it.
    XTR 180 cranks, 32 c-ring
    Tomi Cog 20t
    King bb and hs
    WTB/ Bontragered tubeless tire set up with Paul Hubs
    XTR lever/ Avid bb7 ft brake- no rear brake
    Thomsom stem and post
    Easton DH carbon bar
    New Belgium headbadge!
    Beewee
    Needed Less ~ Did More
    Reputation: Singlespeedpunk's Avatar
    Well my current one is as follows:
    Solitude Cycles custom frame
    On One 29er forks
    Cane Creek S3 headset
    Salsa Stem
    On One Midge bars
    Cane Creek levers
    Oury grips / cork+cloth tape
    Cane Creek Thudbuster ST post
    Brooks Swift Ti
    Sugino XD cranks
    Surly 34+36t rings
    Phil Wood BB
    Time ATAC or Caged pedals+powergrips
    Phil Wood hubs; disc front, double fixed rear.
    Surly/Phil 20+18t fixed cogs / Miche lockrings
    PC58 chain
    DT TK7.1 / 7.1D rims and DT spokes
    Slime tubes and what ever tyres suit (Michelin AT / WTB Exi / Weirwolf)
    Avid BB7R 180mm front disc
    Dia-Compe rear canti, brake booster and Kool Stop salmon pads.
    Pics later....about to go for a ride on this bike!
    SSP
    "Put any one on one of these singlespeed bikes and they could not help but have fun"
    Otis Guy talking about klunkers c1976
    I have red hair
    Reputation: RedGreen's Avatar
    Quote Originally Posted by beewee
    Tomi Cog 20t
    King bb and hs
    Beewee
    Awesome bike, you guys have some balls riding with a fixie off-road like that I have the same bike (but with coasting ability), and was wondering how much yours weighs with the upgrades??
    About 19 lbs currently
    I have red hair
    19 lbs!! Nice!! I'm hoping to get mine down to sub-20, but not sure if I can with two brakes and not a whole lot of money
    Here is a cheap Nashbar fame I rode fixed for awhile. I think I've heard it referred to as a "Southpaw fixie". I called it a really inexpensive tandem crank and something different. I broke the drive side chainstay early this winter, replaced it with a Origin8 Spy frame and swapped on a different crankset.
    Here is the Bonty that started it all for me as far as fixies off road. Finally found a use for my old 26" bike:-)
    Not technically a mountain bike...
    Stock Surly Steamroller with the exception of:
    Charge Spoon Saddle
    Cane Creek S-3 Headset
    Kool Stop Salmon Brake Pads
    700x38 WTB Interwolf Tires (good tires, but I want to try something a little bigger... possibly Speedmax 40's or Mythos Slick CX 42's)
    Kalloy Low Rise Bars (cut down to 18" wide)
    Lizard Skins North Shore Grips
    48x19... Good for the road, a little steep for trails. (going to get a 44t chainring someday)
    Training for vacation
    Reputation: gte819s's Avatar
    beewee
    more pics? Which fork and Hbars are you running?
    On the XXIX stock fork and Monkey Lite DH bar, uncut.
    On the old Bontrager a custom Retrotec I had Curtis build me with Bonty geometry and a Nitto bar.
    What would you like more pics of?
    Reputation: scooter916's Avatar
    beewee, did you used to be the shimano/niterider rep?
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    steel lugs
    Here's yet another one. 26"@ 34/19 as it's rather hilly around here. Hope you like it.
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Fixed with a Fixxer
    I broke those cranks and, and have since replaced them w/ some Cannondale branded cranks off the ebay. I couldn't get the bars from slipping so put straight bars back on it too. It's geared 34x19 which is about a 52" gear.
    Taking the fenders off my commuter and putting on 35's is fun too.
    Offroad I run a 40x19 which is about a 57" gear.
    How do you guys bunny hop and such? Couldn't imagine going fixed off-road.
    CB2
    CB2 is offline
    Jam Econo
    Quote Originally Posted by p nut
    After you clear the obstacle with your front wheel, as you shift your weight forward, and arc over the object your rear wheel leaves the ground and you can put your pedals parallel to the ground until the rear wheel contacts again...or you just hope you don't bash your pedals on it.
    Gabe.....
    Reputation: Smokebikes's Avatar
    Here's mine...........all purpose built off road fixies.
    "Roll your own..........." http://smokebikes.com/
    Quote Originally Posted by scooter916
    In the flesh
