Results 1 to 17 of 17
    Paging Black Sheep Ti Mustache bar users
    I think miSSionary uses them anyone else? Any reviews? I am using the Mary bar right now but these look interesting. They seem like they would offer lots of hand postitions and they are a lot cheaper than the Jones Bars.
    Really I am that slow
    Reputation: SlowerThenSnot's Avatar
    I've got some coming soon
    When I get em i'll let everyone know how they are.
    Read my BLOG!
    just a guy who loves bikes and exploring
    Reputation: miSSionary's Avatar
    Jun 2005
    Quote Originally Posted by Higbee
    Higbee,
    Yes, I have them and can't say enough good things about them!! I went to Mary's right before I got Jame's bars. I loved the Mary's but now I only want to ride the enduros!! They are lots of fun and offer MANY hand positions...they even feel as if they add gears climbing with the new leverage you will find...Can't recomend the bars enough, GO GET SOME!!
    SlowerThanSnott, you will love them too!!
    Black Sheep...where it'ss at!!
    "I'm not known for my patience. Patience is a polite quality and often appropriate, but it rarely gets things done. Impatience, however, is the hunger for results and intolerance for excuses and delays." LA
    Thanks for the info. Any difference in set up compared to the Mary's, other than the lack of rise? Longer stem maybe? It seems like there is a bit of forward sweep from the pictures I have seen.
    WAWE
    WAWE
    This thread is useless without pix!
    Jun 2005
    I have not had to change my neck or anythiing using Mary's or James' bars. He says they have 30 degrees of sweep though putting them beside Mary's they seem the same.
    Jun 2005
    [QUOTE=aosty]
    This thread is useless without pix! QUOTE]
    Well than enjoy!!
    Reputation: Nater's Avatar
    miSSionary,
    How wide are those bars at the widest point?
    Thanks...
    Jun 2005
    Quote Originally Posted by Nater
    Thanks...
    I believe they are 28" at the widest point, I'll have to measure to double check tonight (bike's at home, I'm at work). They are almost dead-on length and sweep of the Mary bars, if you tried them you would realize their potential over Mary and Jones bars, I love them all but the cruiser sweeps (80 degree back bend) are where I do all my climbing now and the bars make it feel as if I have...gasp...multiple gears!!
    WAWE
    [QUOTE=miSSionary]
    Quote Originally Posted by aosty
    Well than enjoy!!
    jja
    jja is online now
    Reputation: jja's Avatar
    forward vs backward
    So what's the feel of a backward sweep vs. a forward extension like bar-ends or the old Scott bars? I got along with Scott AT-4s for a long time, but the new bike went with flat bars and cheap bar-ends. The bar-ends disintegrated after 1 ride and now I'm adapting to straight bars. I haven't decided what to do next.
    Jun 2005
    Quote Originally Posted by jja
    I am not sure but good question. I pose this; If you had some bar ends to try then turn them around so they face backwards. I never thought of this until I got my bars but for me it is like the leverage you'd get standing between two beams. If you tried to pull and climb with a bar in front of you it would not be as easy as climbing between two rails (like stair railing). I have been riding risers for endurance stuff for two years, I like this option as with the others I could hardly get other hand position. I used risers because of my hands going numb. I haven't gone numb with Mary bars or these enduros, but the enduros have like a million hand positions. Also, if you look you can put your hands inside the brake levers for hauling down smooth stuff. Try them...they are the new jones bars, lol!! Seriously though, I am using this style for as long as I can, good stuff.
    Reputation: calzonical's Avatar
    Aug 2005
    miSSionary - do you notice any difficulty maneuvering the wider bar & wrap-around through switchbacks?
    Jun 2005
    Quote Originally Posted by calzonical
    Well a little. When you are doing switchbacks I was taking my bar and turning it to rest behind my knee cap and sortta falling into the turn (this sounds much worse than it is). After riding for a while (they are strange in that aspect at first) I realized I could turn the bars to whatever side after I extended my leg a little straighter on the side I was turning into. Truth be told I still do tight switchbacks by putting the bar behind my knee...not the safest but truly does work. The designer, Jason (James is the builder), says his ends touch the frame on switchbacks and then the bike kinda "falls" into the turn like I am stating mine does when I put it behind the knee. You raised a great question I forgot to cover but really the first 20 miles or so are kind of strange on tighter stuff but after that you won't realize you have that much bar around you. On the downhills if you grab the bar normal by the levers you will find that the rest of the arm to the elbow will rest on the bar making a VERY comfortable position. Hope that helps!!
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    How much?
    I tried to get on Black Sheeps site but couldn't get anything but the shirts and hats. Can anyone link me to the info on their site! Thanks!
    frog
    Jun 2005
    Quote Originally Posted by 1 cog frog
    frog
    They are $175, you should be able to get on the site with this address;
    http://www.blacksheepbikes.com
    Cheers,
    miSSionary
