Results 1 to 35 of 35
    Opinion on rotors
    I have decided to try some BB7's on my bike and take off the hydros that are on it now. They are Tektros and I really have not had any problems with them, it's just that through the last pad changes I have not been able to get rid of the squalling when I get on them.
    I was going to get some Shimanos, but I have too many hobbies and needed to cut costs. I had BB5's on my first bike and got along with them great, the BB7's should work fine for my riding style and terrain.
    I started by buying some Avid speed dial 7's and Jagwire cables today and will probably get the brakes and rotors next week. What rotors do you all suggest? G2? G3? HS1? Any others or are they all going to work fine.
    Could I just use the rotors I have now or should I go with new? Will they still squeal? If there isn't any grooves or wear I imagine they would work OK, right? They are 160mm, can't remember which brand.
    Thanks much
    WillWorkForTrail
    Jun 2012
    You could try the rotors you currently have. The thing is this - I've found a lot of brake noise is due to the rotor design. Take that for what it's worth, but before you go too far, maybe you should try just replacing your rotors. Stay away from Avid rotors - you can try the new centerline rotors, or I particularly like the Ashima Airotors. Just a thought.
    Evolutionsverlierer
    Reputation: acer66's Avatar
    Oct 2010
    What Cotharys said.
    Quote Originally Posted by Mr Pig View Post
    Avid is spelled wrong, there should be an 'O' in there.
    Reputation: CCSS's Avatar
    I'm a huge fan of the cheapie Alligator Serration rotors. You can get them (I think from Pricepoint) for about 15 bucks each. In my experience on many bikes and with many different kinds of brakes (Marta SLs, Elixir CR, Elixir XO, XT, XTR) these things are one of the few examples of "better, cheaper and lighter."
    achiever
    Reputation: redwarrior's Avatar
    I ran BB7's with Avid rotors for a few years & absolutely could not get them to be quiet. Period. Never again... I hope you have better luck than I did.
    I should've mentioned that the original reason I tried the Alligator Serration rotors was to kill the turkey warble from my Avid brakes... They were the only thing that worked.
    Doing some checking, it looks like I could get Shimano Deore M615's for 20 bucks less than the BB7's. Surely Jenson would swap my order if I called before they ship.
    openwound
    Reputation: voodoochild's Avatar
    I think you'd really like the shimano hydro's. I'm running them on all of my bikes. If you're not in a great hurry I purchased my xt's off of ebay for the best price I could find. They ship from asia and it takes at least a week.
    As for rotors, yeah, the alligators are fine rotors and cheap, too. Avid's are fine, too (IMHO). The trick is to ensure that your caliper is as perfectly square to the line of travel as you can get it. I use a couple of feeler gauges, one on either side, as I'm installing the caliper. Really helps me to get 'em set with no noise.
    -- let's ride
    I could save a little and get the SLX, but am hoping to hear the 615's will work as well as the Dracos have or better.
    My BB5's were silent and the Tektros started out that way. On a pretty day in the woods I really dislike squalling.
    Reputation: Brian Grimes's Avatar
    Feb 2015
    I'm not an expert on disk brakes for bikes, but I have lots of professional experience with ones on cars. If they were quiet, and changing the pads made them loud, then the pads are the most likely culprit. First thought is a manufacturing tolorance that has the surface of the pad not flush with the rotor.
    Is there a way/room to put anti-squeal on the back of the pad assembly where it makes contact with the caliper and/or piston, and see if that fixes the problem?
    Living in the moment is always better on two wheels.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    HSX is great for your intended setup. However, if you can pony-up the cash, the Avid Centerline rotor(Guide RSC) is the absolute BEST.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by Brian Grimes View Post
    thats an interesting idea, i'm familiar with that application on cars. though i'm not sure that is the cause on bike brakes. could be, worth trying maybe.
    one technique for quieting noisy brakes that my LBS clued me into is using two different compounds on opposite sides of the caliper. so one metallic pad and one organic pad per caliper. works great.
    the way it was explained to me was that it disrupts the harmonic vibration of the rotor. that could be total BS, but sounded reasonable. either way solved my problem.
    Rigid SS 29er
    Fat Lefty
    SS MonsterCross
    SS cyclocross
    all steel
    Reputation: OFFcourse's Avatar
    Hold out and get the SLX, I've run Tektros and BB7's. They had about as much power as each other but I didn't have to touch the Tektros ever The BB7's were just a PITA could never get them running quite right. I've got shimano brakes on all my bikes now.
    May 2005
    I would advise not using other brand's rotors with Avid brakes. I used a TRP rotor with a BB7 caliper and the pads contacted the rotors further in towards the hub than the machined braking surface of the rotor. Also, I recently switched back to BB7s on my commuter bike that had Formula K18 hydraulic brakes (I have multiple bikes) and I hated it so much that I swapped the brakes back a week later. BB7s work well enough, but the modulation just isn't as nice as a good set of hydraulic brakes.
    I called Jenson this morning and did a stop and swap on my order. After reading hundreds of great reviews I decided to go with the Shimano Deore M615's. They are going to be perfect for my SS and style & terrain of riding.
    Do you think my Tektro rotors will be OK? Could I use them for a few weeks and then get different rotors? Does that screw anything up? I was just going to sand them with some 1200 grit lightly and brakleen them. If not I will wait until I get the new rotors to switch out brakes.
    I'm a fair mechanic, is it much trouble to cut hoses on these for a good fit?
    Thanks everyone for the replys.
    ^I'd just get the Shimano rotors, and call it good....^
    It's pretty straight forward to cut the cables and unless you **** it up you won't need to bleed them either they should include the wee bits needed for shortening the cables.
    Just take it slow and follow the instructions on the tech doc, assuming you can find the right one of course.
    Reputation: Andy R's Avatar
    Nov 2008
    Quote Originally Posted by Glynn Sluder View Post
    No, it's pretty easy - you should get another two inserts and olives with your new brake set. Once you've determined how much you want to shorten the hoses by (measure twice, cut once!) what I do with Shimano brakes is this -
    Set lever reach adjustment fully "out".
    Remove the wheel and pump the pistons out an extra stroke or two - until they're about 1mm apart.(with pads fitted)
    Set the master cyl. as horizontal as possible and top it off - replace the cap.
    Slide the rubber shroud down the hose and undo the hose retainer and slide that down the hose too.
    "Carefully" remove the hose from the master cylinder and, without shaking or knocking the hose around, cut it where you've previously marked it (with tape). Use either good cable cutters or a small block of wood and a Stanley knife blade - it sometimes helps to get someone else to hold the hose if you use the wood/knife blade method.
    At no point touch the brake lever!!
    Slide a new olive down the hose, clamp the hose in the yellow plastic blocks with vice grips and tap in the new insert.
    Refit the hose to the master cylinder, push the pistons back to allow the wheel to be fitted , pressurise to reset the pistons, check for leaks and test.
    You can re-use the inserts if you cut them out of the short ends of hose but, with Shimano, not the olives, as they're the crush type, not the split type.
    WillWorkForTrail
    Jun 2012
    Don't use brakleen on your rotors. Just use rubbing alcohol. Don't get carried away sanding either. Just clean them and try them. They should work fine. Basically, rotors are rotors unless they're lighter or shed heat better or are bigger, or whatever. Don't sweat the rotors too much.
    Feb 2010
    Get new rotors. The pads leave a deposit on the rotors. Mix rotorand pad combos and you will get noise. Shimano with ice tech rotors. Soup.
    Reputation: croatiansensation's Avatar
    Feb 2005
    Quote Originally Posted by Cotharyus View Post
    This, as long as you properly prep and re-bed them with the new brakes you shouldn't have any noise issues. I have a set of Avid rotors that I have used with Avid Elixirs and my current set of Shimano SLX brakes, and they were noise free once I bedded them in correctly.
    Once again I appreciate the time spent replying, this is a great set of forums.
    Reputation: Hairnet's Avatar
    Jul 2013
    Quote Originally Posted by CCSS View Post
    It has a name!? hahahahhahaa
    Los Angelino looking to escape the clamor.
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    pads are generally the problem and not the rotors in my experience (with every brand), I would try a different pad compound or sand the pads you have. If they were working good previous to pad change I would stick with them, mechanicals are a step backwards and like all brakes require good setup to make them quiet.
    I've been inside too long.
    So much for being a fair mechanic. I got all set up with every tool I would need but proceeded to commit a comedy of errors. Guess I was just a little uptight. Final straw was actually dropping one of the cylinders that push on the pad out. I had taken the pads out to keep them clean in case of an accident (ha) and the spacer I used fell out when I went to close the pads some.
    There is no pressure what so ever and nothing moves when I pump the lever. Is it just a huge amount of air in there or did I screw them up? The cylinder went right back in from where it came but there was fluid loss.
    I just put the front brake on, it needs cut about 6 inches but I'm not touching it yet. I really want to ride this weekend so I have to either find a shimano bleed kit local or take it to the LBS soon.
    What do you all think?
    Jan 2014
    my HS rotors and BB7s howl like banshees. I'm thinking about trying centerline rotors, since they quieted my XX brakes instantly.
    Nov 2008
    Well, first of all -there's no need at all to remove pads if all you're doing is shortening a hose without re-bleeding, you're doing nothing at the caliper end.
    However - where you're at now - you have the piston back in, hopefully with no seal damage. You will have lost a lot of your brake fluid though, so that's why you can't get any feel at the lever. Wash off the caliper (soapy water will do fine) to remove any spilt fluid.
    If you can't get a Shimano bleed kit (and fluid) you can bleed them with just a syringe, a short length of tube and some Citroen LHM fluid. Do NOT use DOT 4 or 5.1 - these brakes need mineral oil.
    In short, bleed them from the caliper back up - same principle as pressure bleeding car brakes - connect a syringe of fluid to the bleed nipple (with the length of tube), open the nipple a little and slowly force fluid back up through the caliper and line to the lever (with reservoir set horizontal and cap removed).
    Fluid will overflow from the reservoir so you'll need something to collect this - a plastic bag hung on the bars with some kitchen roll in it is as good as anything. If you have another syringe you can, of course, keep drawing off a little fluid as the reservoir brims.
    Bleed until the fluid colour (if using LHM) has changed from pink to green, so you're not mixing makes of fluid (not that it would probably matter, but it's not good practice).
    Nip up the bleed nipple and see if you have any sort of a lever - if you have, all well and good, if not open the nipple again and draw a little fluid back to the syringe - tap the brake line with a spanner or something (helps dislodge trapped air) and pull the lever in slowly and let it release quickly a few times then send a bit more fluid into the system, close the nipple and test for a lever again.
    Once you can get a decent lever feel put the spacer block in the caliper and squeeze the lever as hard as you would when braking - release the lever, remove the spacer and check, using paper towel, that you have no leaks from the piston seals.
    If all is dry then all well and good, if not then it's probably new caliper time as it would indicate that the seal is damaged. Make sure that the caliper is perfectly clean and dry before you do this test, of course!
    Hoe all this is some help to you!
    Reputation: KevinGT's Avatar
    Dec 2012
    FWIW, I was running Avid Elixir CR brakes with a Hayes rotor in the back and it sounded like a fog horn. I switch to the old Avid rotors that came with my BB7s and they were much quieter.
    Reputation: socal_jack's Avatar
    Dec 2008
    Use the G2s with BB7s, no issues unless I accidentally contaminate disc with lube from chain etc while doing something like changing tire. Usually requires brake cleaner for disc, sometimes pads can be rehabilitated with brake cleaner also but anymore I just throw a new set on. The only other noise source I've seen is if the inside pad gets to low and disc gets pushed into the housing.
    Dec 2012
    Quote Originally Posted by KevinGT View Post
    Scratch that. 5 minutes into my second ride and the foghorn was back. F SRAM. They make garbage. Truvative BB bearings failed after 200 miles and their brakes are junk. My Shimano drivetrain and brakes have been flawless with nearly zero maintenance over 2000 miles.
    Armature speller
    Sep 2004
    I changed to Jagwire pads on my Elixir CR's and the noises stopped. The previous pads squealed their brains out from the moment they were installed.
    My Shimano's with IceTech rotors make a hell of a racket when damp. When wet, they're OK.
    Dec 2012
    Quote Originally Posted by NordieBoy View Post
    Thanks for the advice. I'm just not interested in messing with them any more. Too much work to try to get the same performance I get with ZERO work out of my XTs. Wet, damp, dry, new pads, old pads, recently bled, never bled, doesn't matter. Same, silent, excellent performance.
    Dec 2011
    What Kevin GT said. I've had several Formula hydro brakesets and BB7's and the XT's I have now just plain work. Regardless of tuning and maintenance level, they just keep on functioning, powerful and quiet.
    Feb 2010
    IceTechs with sintered pads are noisy in the wet. Not so with the organic pads, so if you have noisy Shimano brakes, make sure you're using the organic pads. I had one set of XTs shipped to me loaded with organics, the other set with sintered. Didn't notice a difference at first (the organics were on the bike with a 180/160 IceTech rotor combo, the sintered on 160/160 IceTechs), but during my off season maintenance I discovered the difference. This year, the race bike is using sintered pads on 160/140 Hope floating rotors and the power seems on par with organics on 160/160 IceTechs. They are a little noisier though, and made a hell of a racket while the new pads bedded in.
    Saving lives with knives.
    Reputation: frank daleview's Avatar
    I finally got my avid elixir brakes to stop squawking by switching the calipers to shimano SLX. I am still using the avid rotors. It turns out the avid calipers are the problem and not the rotors.
    Formerly known as iceaxe
  1. Replies: 14
    Last Post: 04-24-2017, 12:30 PM
  2. Centerlock rotors vs 6-bolt rotors+CL adaptors?
    By discohospital in forum Brake Time
    Last Post: 01-15-2015, 05:49 AM
  3. disc brakes opinion avid/shimano/rotors
    By leaderbiker in forum Brake Time
    Last Post: 01-04-2015, 04:44 PM
  4. Alligator rotors just as good as Avid rotors?
    By Lindahl in forum Brake Time
    Last Post: 09-19-2013, 02:08 PM
  5. Replies: 2
    Last Post: 03-26-2013, 05:31 AM
