Results 1 to 10 of 10
    Reputation: Johnnydrz's Avatar
    One chain with 16/17/18/19/20t cogs???
    I presently have a 16t and an 18t setup on my bike. I'm using a DMR tensioner which I like. Around here, some of our trails will "require" 19 or 20t sprockets if I want to ride instead of walk. From what I see now, there is a substantial length difference chain needed between 16 and 18. I haven't received my 19 and 20 yet, but I'm wondering if there is a way to set up a chain with a special quick-link/whatever combo that would make things easier when changing cogs, from 16 to 20 let's say. I don't really want to push the tensioner way down so that it almost looks like a derailleur... The only other solution I see is using 2 different chains, one for 16/17/18 and the other one that would fit the 18/19/20 cogs. BTW, only installing one cog at a time.
    Thanks in advance,
    Johnnydrz
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    why not just get a derailleur?
    "If women don't find handsome , they should at least find you handy."-Red Green
    Reputation: boomn's Avatar
    Two different chains is a very easy way to do it, especially if you have powerlinks in both chains for easy install
    I have heard of people using a small section of chain with an extra powerlink to quickly and easily length the chain by a few links.
    Another solution is to buy a second chainring as well. 34x17 is the same ratio as 32:16 and should be able to use the same length chain as 32:19
    Linoleum Knife
    Reputation: forkboy's Avatar
    Quote Originally Posted by nuck_chorris
    Because the spoke cards could get caught in it, silly.
    Tension the chain with a ghost ring, and carry a second smaller ghost ring for when you change gears?
    Quote Originally Posted by boomn
    1+ That's what I'm doing. Rocking two powerlinks and a short chain in between. Works perfectly.
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    I don't run a tensioner, so this may or may not help, but I can run an 34/18-22* on my karate monkey with the same chain.
    I had originally set the bike up with a 19 centered front to back in the dropouts, and had an extra quick link in the chain so I could easily shorten or lengthen the chain but found I could run that range without touching the chain.
    *Chain needs some miles on it, 22 won't fit with a brand new chain.
    Quote Originally Posted by sunset1123
    mmmmm....Ghost Ring*drools*
    Retro Grouch
    Reputation: aka brad's Avatar
    Paul Melvin
    Quote Originally Posted by Johnnydrz
    Thanks in advance,
    Johnnydrz
    You want the Paul "Melvin", it works like a tensioner but can take up the slack for a difference of 4-5 teeth (rated for 20!)
    Just one more rep and I get the toaster!
    Dinner for wolves
    Reputation: buddhak's Avatar
    Quote Originally Posted by D1PHAM
    Ya mon!
    Responds to gravity
