Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Mar 2013
    Old Trek Singletrack coaster conversion.
    Hello there Mtbr peoples. Long time lerker, first complete bicycle build.
    Have an old Trek Singletrack 930 I picked up cheap thats in bad condition. Would like to go coaster ss if possible.
    Id like to get any opinions or suggestions.
    one chain loop
    Reputation: fishcreek's Avatar
    unless it has a horizontal dropout, forget the coaster brake idea.
    everything sucks but my vacuum cleaner.
    Harshing my mellow, man..
    Quote Originally Posted by fishcreek View Post
    why? chain tensioner will work fine with it.
    one chain loop
    like a derailleur mounted tensioner? i dont think so, unless you want to die.
    Mar 2013
    I'm currently looking up tensioner options. Anyone know anything about the fitment of these things? Universal? Also anyone recommend a rear wheel? Looking at cruiser bike wheels on Amazon.
    Reputation: Beatniqwood09's Avatar
    Pretty sure tensioner wont work.
    Magic gear would though!
    Mar 2013
    What won't work with it?
    What is magic gear?
    one chain loop
    there are tons of reasons why you should abandon the idea of going coaster brake UNLESS you have a horizontal drops. and i can go all night tell you about it but im pretty sure half of the words used you wont understand. just run a tensioner and v-brake, problem solved.
    A chain tensioner only applies force opposing the forward direction, so when you attempt to pedal backwards to actuate the coaster brake you'll only end up bending the tensioner back around and dropping the chain rather than stopping.
    The only tensioner that might work would be a stiff rigid one that doesnt use a spring
    Magic gear:
    You can probably find somewhere on the internet(or just measure) the length of your chainstays. Given that number there are a few SS gear ratio options that will fit in verticle dropouts w/o a tensioner
    Edit**
    Pretty sure there are some other issues with it involving coaster brakes requiring a very specific amount of slack in the chain
    I with fish, probably not a good idea
    Mar 2013
    Will definitely be running new set of v brakes. So are you saying a tensioner will or will not work? Thanks for the help.
    Mar 2013
    Quote Originally Posted by Beatniqwood09 View Post
    Magic gear:
    Edit**
    Great explaination, thank you very much.
    one chain loop
    ^thanks for explaining. I agree on most things you said but even running a rigid tensioner will not work. You have to treat coaster like fixed gear condition.
    Magic will work BUT keep in mind that coaster hub chainline has no adjustment. So you have to buy an appropriate bottom bracket spindle length to make it work.
    So couple hundred bucks later, you can enjoy your coaster bike for few hundred miles until your chain sags. Worth it? No.
    Some interesting results I found on google. Dont know where to get either of them. But they dont seem like they would be too hard to fab up
    Attached Thumbnails Attached Thumbnails Old Trek Singletrack coaster conversion.-jkyhs.jpg
    Mar 2013
    I dig that top one. Also have to address the chain line with the crank as mentioned above. Definitely considering moving on to a different frame because Im wanting a coaster brake bike.
    I have ran a tensioner successfully on a bike with a coaster brake. I'm telling you, from personal experience, that it can be done and was done successfully. I didn't crash, lose my brake, or drop my chain once.
    Mar 2013
    Quote Originally Posted by locobaylor View Post
    What kind of tensioner did you use?
    Quote Originally Posted by steve_ohgoodness View Post
    orgin-8
    Products Description – ORIGIN-8
    Pics or it didnt happen...
    Just messin... but really
    Reputation: Andy R's Avatar
    Nov 2008
    By the looks of it, you'd have to use a 120mm hub, as the converter plates fit inside the existing dropouts and put up with your frame angles being about one degree steeper.
    I'd just get another frame if you're set on the idea.
    Mar 2013
    Quote Originally Posted by Andy R View Post
    I'm definitely set on a coaster bike so I'll be looking for a different frame like you suggested. Could anyone recommend a mtn frame with horizantal drop outs? Are old Specialized horizantal by chance?
    Most older bikes either have vertical or semi-horizontal drops.
    The only bikes with true horizontal drops (ie track dropouts) are SS specific frames, OR anything with some sort of sliding/pivoting dropouts (not sure about coaster brake compatibility with sliders can anyone comment on that?)
    You could get one of these Save up to 60% off new Mountain Bikes - MTB - Gravity 29 SS Single Speed 29er Mountain Bikes
    and then rebuild the back wheel with a coaster
    I'm curious what the fascination is with coaster brake? I think I haven't ridden a bike with coaster brake since the early 1980's. Does it add some challenge to the trail? Is it somehow mechanically superior to just v brakes? I rode a fixed gear mountain bike off road a couple of times and was pretty challenging. I'm just wondering if coaster brake gives a similar challenge.
    Mar 2013
    Quote Originally Posted by wjphillips View Post
    For me it's just a nostalgic riding experience.
    AKA AZ.MTNS
    Reputation: Dirty $anchez's Avatar
    A pre-war Schwinn or the like is the quickest route to your coaster brake dream.
    Its just fun.Old Trek Singletrack coaster conversion.-100_0464.jpgOld Trek Singletrack coaster conversion.-100_0459.jpg
  1. Refurbishing of a trek singletrack 930 shx
    By CrzyTuning in forum Vintage, Retro, Classic
    Last Post: 08-10-2012, 09:50 AM
  2. Trek 930 Singletrack vs. Schwinn Moab?
    By uRabbit in forum General Discussion
    Last Post: 06-16-2012, 06:24 AM
  3. Nexus 3 Coaster Brake vs. Non-Coaster Version
    By scooby214 in forum Internal Gear Hubs
    Last Post: 03-19-2012, 03:21 PM
  4. What year is my Trek 930 Singletrack?
    By Drummerboy1975 in forum Vintage, Retro, Classic
    Last Post: 02-03-2012, 04:20 PM
  5. Trek 930 singletrack
    By Pattersonmotorsports13m in forum Singlespeed
    Last Post: 07-31-2011, 04:34 PM
Hot Deals
Contests
Latest Mountain Bike Articles
