Results 1 to 18 of 18
Thread: Now 72 POE!
    Did I catch a niner+?
    ... and if we just ... Now 72 POE!
    So I bought an inner drive from White Industries for my amazing 20t freewheel. Specifically the trails inner drive, which will give me 72 points of engagement. <strike>Most say this is Chris King quality at about the quarter the price!</strike>
    Super easy to do, took about a minute.
    Pieces:
    I had already removed outer casing of FW
    Old inner drive:
    New inner drive:
    Tada!
    Just the same.
    And a new fun top cap:
    Instant Engagement
    This post helped me do it.
    Where'd you get that cap? I want one!!
    Out spokin'
    Dec 1999
    Quote Originally Posted by Mr Pink57
    ... Most say this is Chris King quality at about the quarter the price!
    Huh. I did not know Chris King offered freewheels... even @ 4x the cost.
    --sParty
    P.S. ... and if not, just to make it a fair fight, where's the rest of your hub and how much did that cost?
    disciplesofdirt.org
    Executive User - UK
    Nov 2008
    Thats 1/4 King quality at a 1/4 of the King price!
    --sParty
    I have a Paul WORD hub and it was $119
    I got it on ebay from Fast Freddy
    http://stores.ebay.com/Fast-Freddy-Four
    That's his store, he has a lot of other ones. Its not plastic or cheap nice quality.
    Damn Fast Freddy!! I have the single speed one... going to order that one too!!!
    Out spokin'
    Dec 1999
    Okay, I admit to giving you a bit of a hard time here, but you said you paid $119 for your hub. I found a WI trials FW online for $90 (list $120) so you're into this for at least $209 (I assume you paid something for your 20t FW cog, too).
    I found a CK SS rear hub online (Cambria) for $399.
    So it's looking less like 1/4 the cost and more like something above 1/2 cost. Factor in the weight savings and... well... I dunno.
    I see you did a strikeout on your initial 1/4 cost comment. Again, I wasn't coming after you, just thought I'd put things in perspective.
    --sParty
    P.S. 72 POE is cool.
    disciplesofdirt.org
    master blaster
    Reputation: veloreality's Avatar
    haha
    --sParty
    I paid $55 for the 20t locally and I know you were just razzing me.
    Just got back from a ride and the extra poe is nice in technical areas, that were it seems to shine most. For all out speed though I think the 36poe is better.
    OP, how much did the new driver cost from White? Also, do you happen to know the weight difference?
    I did a weight comparison a while back, and there was virtually no weight savings of one over the other.
    Out spokin'
    Dec 1999
    Quote Originally Posted by bad mechanic
    Huh. Not being a weight weenie, I don't weigh stuff (don't even own a scale besides the one in my bathroom) but I expected the CK hub + cog + spacers + lockring to weight less than the Word hub + WI FW. Dunno why I thought this... I guess I imagined that WI FW to be a bit of a boat anchor, strictly relatively speaking -- no offense intended whatsoever.
    I do know the WI FW enjoys superior design & construction. If I ran a FW compatible hub, I'd be running a WI FW no question.
    --sParty
    disciplesofdirt.org
    Mtbr Forum Sponsor - Homebrewed Components
    --sParty
    i think he was refering to the weight difference between the 36 and 72POE, not the CK vs WI.
    Why do you think so?
    Out spokin'
    Dec 1999
    Quote Originally Posted by ISuckAtRiding
    Okay... I was talkin' about the whole shootin' match, since the price comparison was on the whole shootin' match. So I just assumed...
    I mean some folks are willing to spend a hole bunch mo' money in order to save a few grams. You know what I'm sayin'?
    --sParty
    disciplesofdirt.org
    Sorry, I was referring to the whole shebang, CK vs. WI. They're very comparable weight wise, and will leapfrog each other depending on options. If you want to save weight going with a cassette, you need to step up to a truly lightweight hub like the DT 240.
    You can see below how they compare out of the box. The weight of the Paul hub will drop an additional 15g or so by simply using White washers. So you can see, there really isn't much difference in weight between the two systems.
    CK SS disc - 401g
    CK 18t cog - 37g
    Spacers - 6g
    lock ring - 4g
    Total - 448g
    Paul WORD disc - 280g
    White 18t freewheel - 181g
    Total - 461g
    Quote Originally Posted by Orkje
    Less drag is what I noticed right away with a 36 POE.
    The WI is a bit of a boat anchor. My roommates XT cassette weighs far less then it, not sure on this Hope Pro 2 hub weight but I think his rear is about the same as mine in weight and he has a full 9 speeds.
    Ah, I see. I'm running a standard WI on both of my bikes but I don't let the weight trouble me. I absolutely love the reliability!
    The weight is deceiving. The WI 20t weighs about 200g, while the a 11-32t XT 9 speed cassette weighs about 255g. The WI feels heavier because the weight is concentrated in a smaller area.
