• 11-22-2012
    00gauge
    Is Niner EBB (BioCentric II) Niner-specific?
    I am building my first SS based on a Chinese carbon with BB30. I've been pouring over the available EBB options and it seems that Niner BioCentric II is the best design. Their site says it's "designed to work with Niner frames." Is there something specific to Niner frames that would make using their EBB impossible on another frame?
  • 11-23-2012
    jetboy23
    The size. I don't believe it will work on a BB30 bottom bracket. Only one off the top of my head that works with BB30 would be the Beer Components eccentric. Might be others, but, i'm not sure.
  • 11-23-2012
    Spinning Lizard
    FYI - that is the last design I would want. Read the multiple threads (Niner forum) on how many problems people have with them.
    Had one myself 2 years ago and would never want one myself again, With all of the constant creaking and then getting stuck. No thanks.
  • 11-23-2012
    phsycle
    Biocentrics need 55mm ID so BB30 will not work.
    For what it's worth, I've not had any issues with my Biocentric I EBB on my One 9, personally. Maybe just good luck, since others seem to be having issues.
  • 11-23-2012
    trevrev97
    I have had three Niners with the EBB and a fourth one is on its way, never had one problem with it. But to answer you question, no it won't work.
  • 11-23-2012
    Spinning Lizard
  • 11-23-2012
    trevrev97
    I manage a bike shop and have build more than a few of these Niners with the EBB (including several of my own), and I believe proper prep, and installation goes a long ways.
  • 11-23-2012
    gdkeys
    My Biocentric EBB creaked after installation due to the use of carbon paste assembly grease. A thorough cleaning and re-assembly using Park general purpose grease resolved the problem.
  • 11-23-2012
    Spinning Lizard
    I agree, but why choose to go through all that hassle if not riding a Niner?
  • 11-23-2012
    trevrev97
    True dat! I agree. I just get defensive when people slam the EBB design when I rather like the design and have yet to see why people hate it so bad.
  • 11-23-2012
    ZXFT
    People hate the EBB because people are too stupid to do it right.
    Work in a bike shop sometime and you'll see the outrageous things people do to "fix" their bikes.
  • 11-23-2012
    dubdryver
    Because it is one of the cheapest, lightest EBB solutions on the market. Unfortunately the BB ID is very specific to fit the Biocentric.
    I believe Beer Components and Problem Solver have the only solution for BB30 to EBB on the market. Phil Wood may have something in the works, but I am not sure.
  • 12-05-2012
    blum585
    The main reason I don't like the EBB is that everytime you change gearing it jacks with the crank position - which means it jacks with the seat position. I've often wondered why Niner has not moved so a properly designed slider system.
    I do agree 100% that if the EBB is properly installed it's reletively problem free.
  • 12-08-2012
    tuvok
    Have any good examples? Hopefully none of them are something I've done. Spoke with someone at an LBS about sliding dropouts vs. the Niner EBB, and he was pretty adamant that with proper prep, installation and maintenance the EBB was the better system.
  • 12-08-2012
    idaz
    If I were set on an EBB that wasn't of a split shell design I'd probably look towards Jeff Jones use of one rather than the Niner EBB. I rode the first gen biocentric EBB and while it had periods of blissful silence it did take some effort to keep it that way.
    Following all of the Jones' threads here on MTBR I have yet to hear of anyone complaining about, let alone mentioning, a creaky BB. One of Jones' recent blog posts featured his use/design of the EBB/BB shell.
    Cheers,
    M
  • 12-08-2012
    dubdryver
    Funny, I use to work in a bike shop (money wasn't enough) and now I see many mechanics that are incapable of improvisation or "making things work in a less conventional way" There isn't a whole lot of thinking out of the box going on anymore, and duct tape has became less and less useful (Figuratively speaking).
    An example.
    A gentleman brings in a pair of $350 Specialized S-works shoes that he bought there, and the cleat is rusted solid into the shoe. Both the floor salesman and the mechanic protested that they should have been greases before installed and there is nothing they can do...they have to be replaced. I quietly told the guy what to buy at the shop (cleats and baseplate) and told him how to fix it with a vice and drill/bit.
    I've even been present when another shop mech said that it wasn't possible to install a Niner Biocentric on anything but a Niner when the website states otherwise. There is just specific dimensions that have to be met when machining it out.
    Not everyone always has the money to just go out and "replace with new" to make it work, there is always an improvisation that can be done..some work great, some not so much. Its always better to do it right, but sometimes its not possible...and then there is ofcourse those that bring their bike in that are just hopeless and don't understand the complexity of the fix or how screwed up it is. That happens too...
  • 12-08-2012
    ZXFT
    I'm 99% sure this wasn't to "fix" a bike, but I saw a hub PACKED with dirt... Completely devoid of any grease and filled to the bearing cones with dirt. No one knew how so much dirt could get in a hub without some one pulling out the axle and stuffing dirt in. And before you give me the "mountain bikes are dirty/see a lot of abuse" stuff, it was on a road wheel! :eek:
    Triathletes... :D
    On things done improperly: I saw someone who was riding an over-tensioned front wheel because the person who built it (hopefully not a bike shop) used too short of spokes on one side. This led to cracking in the rim at the eyelets and eventual failure of the wheel. Easy mistake to make if you don't know how to build wheels, but stupid nonetheless.
    Go talk to the mech's at your LBS and I'm sure they'll be glad to tell you horror story after horror story.
  • 12-08-2012
    ZXFT
    Sometimes I do outrageous things to fix my bike though. The oddest thing that has prevented my EBB from making a sound is silver conducting paste that is designed for computer use. Plus, how many people can say they have silver on their bikes?
    Fwiw, I ride a Niner One 9 2010 (I think) with the one bolt biocentric. It's the scandium, easton tubing one.
  • 12-09-2012
    tuvok
    From casual reading about Niner EBBs it seems that particular part is the inspiration to no end of experimental tweaks and tricks. Biggest problem with this type of situation (besides coming up with a "solution" that might damage the bike) is that unless you have lots of DIY stuff kicking around it can get a bit spendy as you have to buy stuff to try new things.
  • 04-12-2015
    jaymzbrm
    guys, do you know the ID for the biocentric II?
    thanks!
  • 04-13-2015
    mcoplea
    +1 on the Niner EBB I and II being flat out awesome. I have owned 3 SIR's and have not had any issues. As others have said, proper set up is the key.
  • 04-16-2015
    2:01
    thanks!
    I'd imagine it's the same as BIOC I, since they are interchangeable.
  • 04-16-2015
    KevinGT
    For what it's worth, I bought a One9 earlier this year and posted on the Niner forum for the current recommendation for installing the EBBII. A Niner employee replied with detailed instructions. I followed them to the letter and the thing hasn't budged or made a sound in 3+ months. I haven't touched it in that time and it's been in some really nasty conditions.
    The current recommendation is to clean the bottom bracket and EBB and install without any prep whatsoever on the mating surfaces. Use a generous amount of grease on the bolt threads AND the posts that mate the two pieces together.
    According to the Niner guy, lack of grease on the posts is the cause of the vast majority of creaking.
    http://forums.mtbr.com/niner-bikes/w...ii-944611.html
  • 04-16-2015
    2:01
    I still use Oatey's joint compound. I haven't cleaned it since June of last year. Still going strong.
  • 05-03-2015
    frank daleview
    Same here, road my One9 at iceman (mud fest) last year and not a peep out of the interface. It is dare I say flawless.
    I recently just installed one of the Wheels Manufacturing EBBs into my wife's specialized carbon SJ. It uses a PF30 and that also has been working very well.
    http://forums.mtbr.com/singlespeed/w...ic-949407.html
