Results 1 to 6 of 6
    Reputation: []D[][]v[][]D's Avatar
    Newbie SSer needs drivetrain help......
    I finally took out the SS I recently built up for its maiden voyage. I'm running a 32x18 drivetrain and a Surly Singulator. About 5 minutes into my ride, I snapped the chain. What's the trick with setting up a drivetrain with a singulator.....how tight do I need the chain to be. I thought I had it nice and tight but it snapped on only a moderate incline. I've attached a pic of the bike that shows where the singulator was set up.
    Thanks in advance for your help!
    Never play leap-frog with a unicorn!
    Out spokin'
    Dec 1999
    Quote Originally Posted by []D[][]v[][]D
    ...I snapped the chain. What's the trick...
    You've got it about right. Your chain must have had a weak link. Judging from the way your Singlator is set up, I don't think it had anything do to with your chain snapping.
    I've got a Singlator on one of my SS's -- it's just like yours yet no problemo on this end.
    --Sparty
    disciplesofdirt.org
    all hail der Fuhrer Bush
    I don't think it snapped re: tightness
    I have limited experience with single-pulley singulators, but from what I've experience, there's usually only one chain length that works well, esp. in Push-Up mode, the better way to set them up, because pushing up increases chain wrap on the cog, thus reducing the chance of skipping.
    Two links (1") too short and the chain's too short to connect it, period. Two links too long and the singulator runs into the chainstays before it tensions the chain. Least that's my experience.
    More likely your chain snapped because (in order of likelihood): Your installation was faulty and the pin where you broke it wasn't centered when you pushed it back in place, or your chainline isn't perfect so the chain got tweaked laterally, or the chain had a bogus link when you unwrapped it which definitely happens, or it's just bad luck/karma as chains sometimes just break even new ones it happens infrequently but it happens.
    Contrarian
    Reputation: AndyArmstrong's Avatar
    Any tension provided by the Singulator will be tiny compared with the tension you put in when you're heaving on the cranks. It's likely it was a faulty chain. Did you lose the chain at all before it snapped?
    Ebo
    Ebo is offline
    Quote Originally Posted by bulC
    I tend to agree with your opinion of running the tensioner in push up mode. I used a Spicer half link in order to use the push up mode. No problems since. His setup just doesn't look like it would work without problems in the push down mode. Not enough chain wrap. 2cents.
    Penis Goat!
    Reputation: GirchyGirchy's Avatar
    Quote Originally Posted by Ebo
    I agree. From the looks of the picture, it appears you could take out one more link to get it tighter...if not, go with a half link. I had problems with cog slippage when I had my Singleator in a position similar to yours. I've since changed to a large chainring and now I can run the Singleator in push-up mode, check out my post on this board for pictures.
  1. Totally basic question (cross-list from the drivetrain list)
    By squirrellyrabbit in forum Beginner's Corner
    Last Post: 04-09-2004, 11:20 AM
  2. Mixing XT and SRAM 8 and 9 speed drivetrain....
    By kingen in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-03-2004, 07:23 AM
  3. XTR compact spider??? 2x9 drivetrain
    By seatstay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-15-2004, 09:14 AM
  4. Overwelming for a newbie, where to start?
    By noonievut in forum Beginner's Corner
    Last Post: 02-22-2004, 05:39 PM
  5. Newbie SS'er has two questions....
    By []D[][]v[][]D in forum Singlespeed
    Last Post: 01-26-2004, 01:22 PM
