Results 1 to 2 of 2
    Jun 2005
    Need Help turing my HardRock into SS.
    I have a Steel 2003 Hard Rock, the parts are pretty much junk but I love the frame. I have made the decision to try and turn it into a SS after my Derailler recently broke.. Question is can I do it and what would be the most efficient way to do it? Are there any kits I could buy and plug in?
    Thanks in advance.
    See link to Bike.
    http://www.specialized.com/bc/SBCBkM...3o8g5be.j27010
    FRAME Cr-Mo mainframe, double-butted and manipulated downtube, forged dropouts with eyelets
    REAR SHOCK N/A
    FORK RST Capa CL, 80mm travel, steel steerer
    HEADSET Threadless 1 1/8" sealed loose ball with alloy cap
    STEM Alloy, 25 degree rise
    HANDLEBARS Steel, 40mm rise, 9 degree sweep
    TAPE / GRIPS Specialized Kraton "Revo"
    FRONT BRAKE Tektro linear pull, stainless steel pipe
    REAR BRAKE Tektro linear pull, stainless steel pipe
    BRAKE LEVERS Tektro TS 327, alloy, "Revo" compatible
    FRONT DERAILLEUR Shimano C-051, 31.8mm clamp, bottom pull
    REAR DERAILLEUR Shimano Altus
    SHIFT LEVERS Shimano Revo RS-41, twist shift
    FREEWHEEL Shimano MF-HG37, 7 speed, 14x28t freewheel
    CHAIN Shimano IG-31
    CRANKSET Shimano FCC-051
    CHAINRINGS Shimano 48sx38sx28s
    BOTTOM BRACKET square taper, 68mm shell, 113mm spindle, sealed cartridge
    PEDALS Dual sided, composite, clip compatible, w/reflector
    RIMS Alex Z-1000 , 26"x1.5", ground side wall, black
    FRONT HUB Joy-Tech, 32 hole, ground race double sealed loose ball
    REAR HUB Joy-Tech, 32 hole, double sealed loose ball
    SPOKES 14g stainless steel, brass nipples (Front: L266/R266 Rear: L265/R264)
    FRONT TIRE Specialized Ground Control, 26"x1.95", wire bead
    REAR TIRE Specialized Ground Control, 26"x1.95", wire bead
    TUBES Specialized Schraeder valve
    SADDLE Specialized Sport ATB
    SEAT POST Alloy 30.4mmx300/350mm, micro adjust
    SEAT BINDER Cr-Mo socket head binder bolt
    NOTES Chain stay protector, reflectors, clear coat, owners manual
    you go ahead
    Feb 2005
    Take my advice with a grain of salt... I'm not a true SSer yet (almost done building a frame up at the moment).
    1) I don't know your crankset, but if it's three peice, then take off the small and inner chainrings. I think you can buy shorter bolts to accomodate this or you can buy a bashring to replace the big ring.
    2) Take off all of your shifters and derailleurs.
    3) Remove rear wheel.
    3) Take off the casset and pick out the appropriate cog that you'll be running. Maybe start out with 16T cog, assuming your middle ring is 32T.
    4) Get some more casset spacers from your shop or from another casset.
    5) Slip these on and allign the cog and the chainring with the spacers.
    6) Buy a chain tensioner like the Soulcraft or Singleator and use it to tension your chain.
    7) Go to the Singlespeed FAQ page to double check all of this.
    It's at the top right of this page.
    Have fun
    You can also buy lots of parts to make your SS work better, but this is the cheapest way.
    Webcyclery.com walks you through the process of buying these things. Easy but a little too pricey.
  1. Newbie needs help with SS setup
    By Little Willy in forum Singlespeed
    Last Post: 02-07-2005, 10:05 AM
  2. Newbie needs help with SS setup
    Last Post: 02-05-2005, 07:02 PM
  3. Singlespeed: More or less efficient?
    By grumpstumper in forum General Discussion
    Last Post: 01-13-2005, 01:01 PM
  4. ss fun at the tourne
    By mergs in forum New York - New Jersey
    Last Post: 11-29-2004, 09:58 PM
  5. to SS or not? that is the question
    By Nimai in forum Singlespeed
    Last Post: 04-28-2004, 11:46 AM
